Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   thumping sound in drum (http://forum.appliancepartspros.com/dryer-repair/545221-thumping-sound-drum.html)
oceanfit 02-04-2014 11:53 PM
My dryer makes a klunking sound every complete rotation. Its almost as if the drum is lifting and falling at the shaft. I can turn the drum by hand with ease and still hear the sound. Could this be the assembly-shaft (ball hitch) or the the rear drum bearing? thank you.
GMBILL 02-05-2014 03:24 PM
Front Felt Glide Assembly AP2150497 Upper dryer drum front felt seal with three glides sometimes wear out/off and causes the welded seal in the drumb to thump against the front assembly. Additional part to check is the rear drum bearing kit AP2142648.
denman 02-06-2014 02:53 AM
Also check the drum seam.
Sometimes they can split.
