property manager dude
#1 Posted : Monday, February 3, 2014 1:17:41 PM(UTC)
dryer fires up once , then just runs and runs ...
fairbank56
#2 Posted : Monday, February 3, 2014 1:49:55 PM(UTC)
fairbank56
Groups: Expert
So, your saying the timer doesn't advance? Does the burner come on? If so, does it cycle off/on during the cycle? Does timer advance on it's own when set to AIR FLUFF cycle?
Eric
#3 Posted : Tuesday, February 4, 2014 6:16:25 AM(UTC)
this model has no timer in any of the heat modes only "Auto Dry" the timer is only for "fluff" (no heat) and it does advance . When you first turn it on igniter glows , gas turns on and it fires up for a short time , after first cycle it just runs and runs no fire up ,,once in a while it will randomly fire up , then same , just run and run ...
fairbank56
#4 Posted : Tuesday, February 4, 2014 8:08:27 AM(UTC)
fairbank56
Groups: Expert
Yes, it does use the timer in auto modes. In the early part of the cycle, the only time the timer advances is when the cycling thermostat cycles the burner off. This occurs after the clothes start getting dry. When the burner comes back on, the timer stops advancing. In the latter part of the cycle, a timer contact applies power to the timer motor all the time and the timer advances continuously til end of cycle. You need to do some electrical troubleshooting to determine what's going on. Could be a faulty cycling thermostat or failing gas solenoid coils.
Eric
Icemaker won't cycle automatically (Refrigerator & Freezer Repair)
by elmunc 4/23/2022 8:57:29 AM(UTC)
Whirlpool WDF520PADM7 won't cycle (Dishwasher Repair)
by MikeSC47 1/7/2021 9:37:06 AM(UTC)
Washer won't cycle to rinse or spin (Washer Repair)
by Jags 1/16/2016 10:59:08 AM(UTC)
Washer Won't Cycle through (Washer Repair)
by alli2 9/17/2014 3:42:22 PM(UTC)
Washer won't cycle through rinse/spin unless lid opened?? (Washer Repair)
by myersbrady 8/3/2014 6:54:44 AM(UTC)
J-Air Dishwasher won't cycle (Dishwasher Repair)
by MGJ 7/27/2013 10:20:40 AM(UTC)
Kenmore Washer Won't Cycle -Fails Tachometer Test (Washer Repair)
by Richy1 5/20/2013 7:11:15 PM(UTC)
Won't cycle through all modes (Dishwasher Repair)
by Press68 5/12/2013 7:04:43 PM(UTC)
Dryer Won't Cycle Heat off (i.e. only has high heat) (Dryer Repair)
by chrisski26 3/21/2013 10:35:38 AM(UTC)
Freezer won't cycle off (Refrigerator & Freezer Repair)
by snyderrita 7/26/2012 12:13:22 PM(UTC)
Maytag Dishwasher Timer won't cycle by itself (Dishwasher Repair)
by datoon1 3/3/2012 1:59:53 PM(UTC)
Kenmore washer won't cycle through (Washer Repair)
by miss amber 2/13/2012 3:21:48 PM(UTC)
Machine won't cycle completely... (Dishwasher Repair)
by murftj 1/31/2012 7:56:42 PM(UTC)
Dishwasher won't cycle out of Washing (Dishwasher Repair)
by Tupperpup 1/2/2012 3:05:04 PM(UTC)
dishwasher won't cycle (Dishwasher Repair)
by needingsomehelp 6/18/2011 8:33:52 AM(UTC)
