Discuss
No Heat
 in
Dryer Repair
My dryer stopped heating. I changed thermal fuse and heating element and still have no heat. I did check continuity
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat
  #1 (permalink)
Old 01-29-2014, 02:30 PM
Junior Member
Tracy Lynch is on a distinguished road
Default No Heat
Model Number: red4440sq0   Brand: Roper   Age: 1 - 5 years
My dryer stopped heating. I changed thermal fuse and heating element and still have no heat. I did check continuity of heating element and had open line and found one of the coils came apart. everything I search for this problem says it should be one of these parts, but obviously not. could you please tell me what the problem could be?
Related Models
Roper RED4440SQ0 29"ELECTRIC DRYER
Roper RED4440VQ0 29" ELECTRIC DRYER
Roper RED4440VQ1 29"ELECTRIC DRYER
Roper RED4440VQ2 29" ELECTRIC DRYER
Roper REE22303 24" FREESTANDING RANGE Easy-Clean Oven Coil Cooktop
Roper REE23000 ELECTRIC RANGES AND OVENS
Roper REE31300 ELECTRIC RANGES AND OVENS
Roper REE32302 30" ELECTRIC RANGE COIL COOKTOP E-Z Clean Oven
Roper REE33000 ELECTRIC RANGES AND OVENS
Roper REE34001 30" ELECTRIC RANGE
Amana REF120905C5E ROOM AIR CONDITIONER
Amana REF120905C5E RE ROOM AIR CONDITIONER
Amana REF120905C5ER ROOM AIR CONDITIONER
Amana REF120905C5ER R ROOM AIR CONDITIONER
Amana REF18090C5E ROOM AIR CONDITIONER
Amana REF18090C5E REV ROOM AIR CONDITIONER
Amana REF18090C5ER ROOM AIR CONDITIONER
Amana REF18090C5ER RE ROOM AIR CONDITIONER
Amana REF24080C5E ROOM AIR CONDITIONER
Amana REF24080C5E REV ROOM AIR CONDITIONER
Amana REF24080C5ER ROOM AIR CONDITIONER
Amana REF24080C5ER RE ROOM AIR CONDITIONER
Thermador REF30 30" ELECTRIC RANGE
Thermador REF30QB PRIOR TO S/N 9708
Thermador REF30QB S/N 9708 & UP
Thermador REF30QW PRIOR TO S/N 9708
Thermador REF30QW S/N 9708 & UP
Thermador REF30RS PRIOR TO S/N 9707
Thermador REF30RS S/N 9707 & UP
Frigidaire REG34NL1 Frg(v2) / Electric Range
Frigidaire REG34NL2 Frg(v4) / Electric Range
Frigidaire REG34NW1 Frg(v1) / Electric Range
Frigidaire REG34NW2 Frg(v3) / Electric Range
Frigidaire REG36AA2 Frg(v4) / Free Standing Electric Range
Frigidaire REG36AA3 Frg(v4) / Electric Range
Frigidaire REG36AA4 Frg(v9) / Electric Range
Frigidaire REG36AA5 Frg(v3) / Electric Range
Frigidaire REG36AA6 Frg(v8) / Electric Range
Frigidaire REG36AF2 Frg(v5) / Free Standing Electric Range
Frigidaire REG36AF3 Frg(v3) / Electric Range
Frigidaire REG36AF4 Frg(v8) / Electric Range
Frigidaire REG36AF5 Frg(v2) / Electric Range
Frigidaire REG36AF6 Frg(v7) / Electric Range
Frigidaire REG36AH2 Frg(v6) / Free Standing Electric Range
Frigidaire REG36AH3 Frg(v5) / Electric Range
Frigidaire REG36AH4 Frg(v10) / Electric Range
Frigidaire REG36AH5 Frg(v4) / Electric Range
Frigidaire REG36AH6 Frg(v9) / Electric Range
Frigidaire REG36AL2 Frg(v7) / Free Standing Electric Range
Frigidaire REG36AL3 Frg(v2) / Electric Range
Frigidaire REG36AL4 Frg(v7) / Electric Range
Frigidaire REG36AL5 Frg(v5) / Electric Range
Frigidaire REG36AL6 Frg(v10) / Electric Range
Frigidaire REG36AW2 Frg(v8) / Free Standing Electric Range
Frigidaire REG36AW3 Frg(v1) / Electric Range
Frigidaire REG36AW4 Frg(v6) / Electric Range
Frigidaire REG36AW5 Frg(v1) / Electric Range
Frigidaire REG36AW6 Frg(v6) / Electric Range
Frigidaire REG36CAA2 Frg(v9) / Free Standing Electric Range
Frigidaire REG36CAA3 Frg(v3) / Electric Range
Frigidaire REG36CAA4 Frg(v8) / Electric Range
Frigidaire REG36CAA5 Frg(v3) / Electric Range
Frigidaire REG36CAA6 Frg(v8) / Electric Range
Frigidaire REG36CAF2 Frg(v10) / Free Standing Electric Range
Frigidaire REG36CAF3 Frg(v2) / Electric Range
Frigidaire REG36CAF4 Frg(v7) / Electric Range
Frigidaire REG36CAF5 Frg(v2) / Electric Range
Frigidaire REG36CAF6 Frg(v7) / Electric Range
Frigidaire REG36CAH2 Frg(v11) / Free Standing Electric Range
Frigidaire REG36CAH3 Frg(v4) / Electric Range
Frigidaire REG36CAH4 Frg(v9) / Electric Range
Frigidaire REG36CAH5 Frg(v4) / Electric Range
Frigidaire REG36CAH6 Frg(v9) / Electric Range
Frigidaire REG36CAL2 Frg(v12) / Free Standing Electric Range
Frigidaire REG36CAL3 Frg(v5) / Electric Range
Frigidaire REG36CAL4 Frg(v10) / Electric Range
Frigidaire REG36CAL5 Frg(v5) / Electric Range
Frigidaire REG36CAL6 Frg(v10) / Electric Range
Frigidaire REG36CAW2 Frg(v13) / Free Standing Electric Range
Frigidaire REG36CAW3 Frg(v1) / Electric Range
Frigidaire REG36CAW4 Frg(v6) / Electric Range
Frigidaire REG36CAW5 Frg(v1) / Electric Range
Frigidaire REG36CAW6 Frg(v6) / Electric Range
Frigidaire REG38BLL1 Frg(v2) / Electric Range
Frigidaire REG38BLW1 Frg(v1) / Electric Range
Frigidaire REG38BNL1 Frg(v2) / Electric Range
Frigidaire REG38BNL2 Frg(v2) / Electric Range
Frigidaire REG38BNL3 Frg(v4) / Electric Range
Frigidaire REG38BNL4 Frg(v1) / Electric Range
Frigidaire REG38BNW1 Frg(v1) / Electric Range
Frigidaire REG38BNW2 Frg(v1) / Electric Range
Frigidaire REG38BNW3 Frg(v3) / Electric Range
Frigidaire REG38BNW4 Frg(v2) / Electric Range
Frigidaire REG39WLL0 Frg(v2) / Electric Range
Frigidaire REG39WLW0 Frg(v1) / Electric Range
Frigidaire REG433MDW2 Frg(v1) / Electric Range
Frigidaire REG433MDW3 Frg(v2) / Electric Range
Frigidaire REG433MDW4 Frg(v3) / Electric Range
Frigidaire REG433MDW5 Frg(v1) / Electric Range
Frigidaire REG433MNW1 Frg(v1) / Electric Range
Frigidaire REG433MNW2 Frg(v1) / Electric Range
Frigidaire REG433MNW3 Frg(v1) / Electric Range
  #2 (permalink)
Old 01-29-2014, 05:16 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Does the timer advance when in timed dry function? If not, check that you have 240vac at dryer power cord connection block on back of dryer behind small panel. With dryer unplugged, make sure those connections are clean and tight and there is no burning/melting of wires or terminals there. If ok, problem could be timer, motor switch or a faulty connection in the heater circuit. You say you replaced the thermal fuse. The thermal fuse is in the motor circuit, motor would not run if it was bad. Are you talking about the thermal cutoff on the top of the heater box? Did you check continuity of the hi-limit thermostat at bottom of heater box?
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave will not heat anymore. Everything works but the heat and turntable dont. Rumpylee Microwave Repair 0 12-08-2013 12:10 AM
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
