Discuss
Amana NED7200 TW
 in
Dryer Repair
It suddenly stop producing hot air. What do I do? Related Models Maytag  NED7200TW10  29" ELECTRIC DRYER Maytag  NED7300WW0  27"
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana NED7200 TW
  #1 (permalink)
Old 01-28-2014, 08:48 PM
Junior Member
Hulky07 is on a distinguished road
Default Amana NED7200 TW
Model Number: NED7200TW   Brand: Amana   Age: 5 - 10 years
Related Models
Maytag NED7300WW0 27" ELECTRIC DRYER
Maytag NED7300WW1 27" ELECTRIC DRYER
Maytag NED7500VM0 ELECTRIC DRYER
Maytag NED7500VM1 ELECTRIC DRYER
Maytag NED7500VW0 ELECTRIC DRYER
Maytag NED7500VW1 ELECTRIC DRYER
Maytag NEDNS249F REF - SXS/I&W
Maytag NEDNS249FA REF - SXS/I&W
Maytag NEDNS249FH REF - SXS/I&W
Maytag NEDNS249HA REF - SXS/I&W
Maytag NEDNS249HH REF - SXS/I&W
Norge NEF3G1 RANGE- F/S STD ELE
Norge NEH2H0 RANGE- F/S STD ELE
Norge NEHA86-1 RANGE- S/C F/S ELE
Norge NEHW86-1 RANGE- S/C F/S ELE
Bosch NEM732 UC
Bosch NEM735 UC
Bosch NEM736 UC
Bosch NEM932 UC
Bosch NEM935 UC
Bosch NEM936 UC
Maytag NENS207G REF - SXS/I&W
Maytag NENS207GA REF - SXS/I&W
Maytag NENS207GH REF - SXS/I&W
Maytag NENS208GZA REF - SXS
Maytag NENS208GZH REF - SXS
Maytag NENS208GZW REF - SXS
Maytag NENS227F REF - SXS
Maytag NENS227FH REF - SXS
Maytag NENS227G REF - SXS
Maytag NENS227GA REF - SXS
Maytag NENS227GH REF - SXS
Maytag NENS228GZA REF - SXS
Maytag NENS228GZH REF - SXS
Maytag NENS228GZW REF - SXS
Maytag NENS248GZA REF - SXS
Maytag NENS248GZH REF - SXS
Maytag NENS248GZW REF - SXS
Maytag NENT156E REF - TOP MOUNT
Maytag NENT156EA REF - TOP MOUNT
Maytag NENT156EH REF - TOP MOUNT
Maytag NENT156G REF - TOP MOUNT
Maytag NENT156GA REF - TOP MOUNT
Maytag NENT156GH REF - TOP MOUNT
Maytag NENT156HA REF - TOP MOUNT
Maytag NENT156HH REF - TOP MOUNT
Maytag NENT156HW REF - TOP MOUNT
Maytag NENT176H REF - TOP MOUNT
Maytag NENT176HA REF - TOP MOUNT
Maytag NENT176HH REF - TOP MOUNT
Maytag NENT196H REF - TOP MOUNT
Maytag NENT196HA REF - TOP MOUNT
Maytag NENT196HH REF - TOP MOUNT
Maytag NENT198H REF - TOP MOUNT
Maytag NENT198HA REF - TOP MOUNT
Maytag NENT198HH REF - TOP MOUNT
Maytag NENT198K REF - TOP MOUNT
Maytag NENT198KA REF - TOP MOUNT
Maytag NENT217F REF - TOP MOUNT
Maytag NENT217FA REF - TOP MOUNT
Maytag NENT217FH REF - TOP MOUNT
Maytag NENT238H REF - TOP MOUNT
Maytag NENT238HA REF - TOP MOUNT
Maytag NENT238HH REF - TOP MOUNT
Norge NER1360ACW RANGE- F/S STD ELE
Admiral NER1360AGH RANGE- F/S STD ELE
Norge NER3540ACW RANGE- S/C F/S ELE
Norge NER3760ACW RANGE- S/C F/S ELE
Bosch NES732 UC
Bosch NES735 UC
Bosch NES736 UC
Bosch NES932 UC
Bosch NES935 UC
Bosch NES936 UC
Norge NEW2G1 RANGE- F/S STD ELE
Norge NEW2H0 RANGE- F/S STD ELE
Norge NEW2H1 RANGE- F/S STD ELE
Norge NEW3G1 RANGE- F/S STD ELE
Norge NEW3G8AC RANGE- S/C F/S ELE
Norge NEW3G8CV RANGE- S/C F/S ELE
Norge NEW3G8CX RANGE- S/C F/S ELE
Norge NEW3G8DEV RANGE- S/C F/S ELE
Norge NEW3G8DX RANGE- S/C F/S ELE
Norge NEW3G8EV RANGE- S/C F/S ELE
Norge NEW3G8EVW RANGE- S/C F/S ELE
Norge NEW3H2EX RANGE- F/S STD ELE
Norge NEW3H8CVW RANGE- S/C F/S ELE
Norge NEW3H8CX RANGE- S/C F/S ELE
Norge NEW3H8STVW-EV RANGE- S/C F/S ELE
Norge NEW3J8EV RANGE- S/C F/S ELE
Norge NEW6G6CLW RANGE- F/S CONT CLEAN ELE
Norge NEW6H6CLW RANGE- F/S CONT CLEAN ELE
Bosch NEZ1000
Bosch NEZ1010
Bosch NEZ1020
Bosch NEZ1050
Bosch NEZ1055
Bosch NEZ1070
Bosch NEZ1075
Bosch NEZ1100
Frigidaire NFTR18X4LB0 REFRIGERATOR
Frigidaire NFTR18X4LB1 REFRIGERATOR
Frigidaire NFTR18X4LB2 REFRIGERATOR
Frigidaire NFTR18X4LB4 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LB6 REFRIGERATOR
Frigidaire NFTR18X4LS2 REFRIGERATOR
Frigidaire NFTR18X4LS3 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LS4 REFRIGERATOR
Frigidaire NFTR18X4LS5 REFRIGERATOR
Frigidaire NFTR18X4LS6 REFRIGERATOR
Frigidaire NFTR18X4LW0 REFRIGERATOR
Frigidaire NFTR18X4LW1 REFRIGERATOR
Frigidaire NFTR18X4LW2 REFRIGERATOR
Frigidaire NFTR18X4LW4 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LW6 REFRIGERATOR
Maytag NFW7200TW10 AUTOMATIC WASHER
Maytag NFW7200TW11 AUTOMATIC WASHER
Maytag NFW7300WW00 AUTOMATIC WASHER
Maytag NFW7500VM00 AUTOMATIC WASHER
  #2 (permalink)
Old 01-29-2014, 02:46 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag NED7200TW10 Dryer - AppliancePartsPros.com
Since the heater runs off of the 240 and everything else runs off of 120 the first thing to do is check your power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If you have 240 then unplug the unit and check the heating coil, hi-limit thermostat and the thermal cut-off for resistance.
Note : If the cut-off is open then there are other tests you should do before replacing it.
If the above parts are OK then check the thermistor for resistance.
If it is OK unplug the wires for the heater relay contacts and check across the contacts. Should be infinite ohms (open). If closed you may have to replace the board as the relay contacts are welded together. You may be able to just replace the heater relay if you have a little electronics soldering experience and can find the relay.
If the relay checks out OK then you have two possible causes.
1. The control board is shot and is keeping the heater relay closed.
2. The motor's centrifugal switch for the motor is not closing. Check that the motor is clean. One way to confirm a bad switch is to short the wires to the switch together. Plug the unit in and give it a try. Just be sure that the wires cannot short to anything else (tape them) and that they cannot get caught by a moving part.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana sbs oneyoungmunson Refrigerator & Freezer Repair 2 01-11-2012 02:57 AM
amana ricouse Oven Repair (including Ranges and Cooktops) 0 10-29-2011 07:44 AM
Amana RR-810 R. Owens Microwave Repair 0 11-23-2010 01:18 PM
amana djfrankiet1 Refrigerator & Freezer Repair 0 05-23-2010 09:51 PM
Amana bercegeayb Heating, Ventilation, and Air Conditioning (HVAC) 0 08-08-2009 05:29 PM
