Discuss
Need help with a gas Maytag dryer
 in
Dryer Repair
Hello, I am looking for some help with my gas Maytag Dryer, it seems to be running hot when on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need help with a gas Maytag dryer
  #1 (permalink)
Old 01-28-2014, 05:40 PM
Junior Member
fixer_man is on a distinguished road
Default Need help with a gas Maytag dryer
Model Number: PYG2300AWW   Brand: Maytag   Age: More than 10 years
Hello,
I am looking for some help with my gas Maytag Dryer, it seems to be running hot when on the low setting. About 1 to 1 1/2 years ago I replaced the control thermostat because it was running hot on high and that seems like it is OK but the low side seems to be affected (it could also be that I haven't noticed it on high). The clothes are very hot when we remove them from the dryer on the low setting.
I have included a copy of the schematics and I don't understand how the unit controls the temperature settings. The dryer has a 3 position heat selector - Air Fluff, Low and Regular but the schematics only show 2 positions, doesn't indicate which positions are what and has a thermostat heater in one of the positions that I have no clue what it does, the 4 wire colors on the schematic are attached to the control thermostat. I also don't see how the dryer controls the low heat vs. the high heat based on the schematic.
I did test the thermostat to the best of my ability - the heater has 7K ohm on it and the thermostat shows 0 ohms with no heat. I tested the temps on both settings and with an empty dryer it is cycling between 100 F to about 200 F on low and 110 F to 215 F on high. I am guessing with the difference in temperatures that the control thermostat is probably working as one of the high limit thermostats would trigger at the same temp all the time.
I'm at a loss as what it could be as I have plenty of air circulation, the unit is pretty clean and the control thermostat seems to be working.
The unit is oldish, has some rust ... I would just like to keep it working a little while longer.
Thanks in advance for your help!
Related Models
Maytag PYG2300AWW DRYER- GAS
Maytag PYG3200AWW DRYER- GAS
Maytag PYG3250AWW DRYER- GAS
Maytag PYG3300AWW DRYER- GAS
Maytag PYG3360AWW DRYER- GAS
Maytag PYG4500AWQ DRYER- GAS
Maytag PYG4500AWW DRYER- GAS
Maytag PYG4557AWW DRYER- GAS
Maytag PYG4558AWW DRYER- GAS
Admiral PYGS244AWW DRYER- GAS
Maytag PYGT244AWW DRYER- GAS
Maytag PYGT344AWW DRYER- GAS
Maytag PYGT444AWW DRYER- GAS
Amana QDO-695 RANGE- S/C S/I DDRAFT GAS
Amana QDO-695D RANGE- S/C S/I DDRAFT GAS
Amana QDO-695E RANGE- S/C S/I DDRAFT GAS
Amana QDO-695F RANGE- S/C S/I DDRAFT GAS
Amana QDO-695G RANGE- S/C S/I DDRAFT GAS
Amana QDO-695H RANGE- S/C S/I DDRAFT GAS
Amana QDU-838 RANGE- S/C S/I DDRAFT GAS
Amana QDU-858 RANGE- S/C S/I DDRAFT GAS
Amana QDU-878 RANGE- S/C S/I DDRAFT GAS
Amana QDU-966 RANGE- S/C S/I DDRAFT GAS
Amana QDU-976 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661B RANGE- S/C S/I DDRAFT GAS
Amana QKO-661C RANGE- S/C S/I DDRAFT GAS
Amana QKO-661D RANGE- S/C S/I DDRAFT GAS
Amana QKO-661E RANGE- S/C S/I DDRAFT GAS
Amana QKO-751 RANGE- S/C S/I DDRAFT GAS
Amana QKO-751A RANGE- S/C S/I DDRAFT GAS
Amana QKU-647 RANGE- S/C S/I DDRAFT GAS
Amana QKU-647A RANGE- S/C S/I DDRAFT GAS
Amana QMC811 WALLOVEN- STD MWAVE ELE
Amana QMD-800 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800E MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-810 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD800 WALLOVEN- STD MWAVE ELE
Amana QMD800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD810 WALLOVEN- STD MWAVE ELE
Amana R-1 RANGE- S/C S/I DDRAFT GAS
Amana R-1H RANGE- S/C S/I DDRAFT GAS
Amana R-1J RANGE- S/C S/I DDRAFT GAS
Amana R-1J MWAVE - FAMILY SIZE (60 HZ)
Amana R-2 RANGE- S/C S/I DDRAFT GAS
Amana R-3 RANGE- S/C S/I DDRAFT GAS
Amana R-3 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool R101 Air-conditioner/heat pump
Whirlpool R1011 Air-conditioner/heat pump
Whirlpool R1012 Air-conditioner/heat pump
Whirlpool R1013 AIR CONDITIONER
Whirlpool R1014 AIR CONDITIONER
Whirlpool R121 Air-conditioner/heat pump
Whirlpool R1211 Air-conditioner/heat pump
Whirlpool R1212 AIR CONDITIONER
Whirlpool R1213 AIR CONDITIONER
Whirlpool R1231 Air-conditioner/heat pump
 R1404 Air Conditioner
Whirlpool R141A AIR CONDITIONER
Whirlpool R141A1 AIR CONDITIONER
Whirlpool R141F0 AIR CONDITIONER
Whirlpool R141G0 AIR CONDITIONER
Amana R15 MISC / ACCESSORY
Whirlpool R153 Air-conditioner/heat pump
Amana R15A MISC / ACCESSORY
Amana R15L MISC / ACCESSORY
Amana R15LA MISC / ACCESSORY
Whirlpool R183 AIR CONDITIONER
Whirlpool R183A AIR CONDITIONER
Whirlpool R183A1 AIR CONDITIONER
Whirlpool R183A2 AIR CONDITIONER
Whirlpool R183A3 AIR CONDITIONER
Whirlpool R183F0 AIR CONDITIONER
Whirlpool R183G0 AIR CONDITIONER
Whirlpool R183G1 AIR CONDITIONER
Amana R1E MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air R200 SURFACE UNIT- DDRAFT ELE
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 SURFACE UNIT- DDRAFT ELE
Jenn-Air R201-C SURFACE UNIT- DDRAFT ELE
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
Frigidaire R21CL5 Frg(v2) / Electric Range
Frigidaire R21CL6 Frg(v4) / Electric Range
Frigidaire R21CW0 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW1 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW2 Frg(v1) / Electric Range
Frigidaire R21CW3 Frg(v3) / Electric Range
Frigidaire R21CW4 Frg(v5) / Electric Range
Frigidaire R21CW5 Frg(v1) / Electric Range
Frigidaire R21CW6 Frg(v3) / Electric Range
Hoover R226D011 REF - SXS/I&W
Frigidaire R22CW1
Frigidaire R22CW10
Crosley R22CW11 ARCTIC AIR/REFRIGERATOR
Crosley R22CW12 ARCTIC AIR/REFRIGERATOR
Crosley R22CW13 ARTIC AIR/REFRIGERATOR
Frigidaire R22CW2
Frigidaire R22CW3
Frigidaire R22CW4
Frigidaire R22CW5
Frigidaire R22CW6
Frigidaire R22CW7
Frigidaire R22CW8
Frigidaire R22CW9
Crosley R22CWF0 ARCTIC AIR/REFRIGERATOR
Crosley R22CWF1 ARCTIC AIR/REFRIGERATOR
  #2 (permalink)
Old 01-28-2014, 07:58 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Temps are too high. In high heat, the operating thermostat should cycle burner off at 146 and back on at 121. Heat selector L1 to C closed, L1 to 1 open for high heat, both closed for low heat and both open for air fluff (no heat). In low heat, thermostat heater is on. Heater is part of thermostat and will cause thermostat to heat up and cycle off sooner causing an overall lower heat than high. You either have an airflow problem or the thermostat is faulty.
Blower temp on low should be between 105-125 and on high, 110-145
Eric
  #3 (permalink)
Old 01-29-2014, 03:14 AM
Junior Member
Default
Thanks for your help!
There seems to be a lot of air blowing out of the exhaust but that's just based on me being outside and seeing a lot of air movement around the exhaust; I wouldn't know how to measure the airflow correctly.
The temps as I was measuring them did drop fairly rapidly - within a minute or two and then recycled up.
I guess my first thing is I'll look at the exhaust duct and see if there's anything blocking and if not I'll get another control thermostat.
Thanks again!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer Steve McAndrew Dryer Repair 1 02-20-2013 03:32 PM
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 06:18 PM
Maytag Dryer Floyd Wheeler Dryer Repair 0 08-31-2010 10:33 AM
Maytag Gas Dryer lxk8 Dryer Repair 3 07-22-2010 12:06 PM
Maytag gas Dryer Dwasko Dryer Repair 0 06-08-2009 03:15 PM
