Discuss
rsortore
 in
Dryer Repair
is there any test to see if control board is bad thanks Richard Related Models Kenmore  11084821300  ELECTRIC DRYER Kenmore
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » rsortore
  #1 (permalink)
Old 01-27-2014, 11:03 AM
Junior Member
richardsortore@bellsouth. is on a distinguished road
Default rsortore
Model Number: 11084821300   Brand: Kenmore   Age: 5 - 10 years
Related Models
Kenmore 11084821301 RESIDENTIAL DRYER
Kenmore 11084831300 ELECTRIC DRYER
Kenmore 11084831301 RESIDENTIAL DRYER
Kenmore 11084832200 ELECTRIC DRYER
Kenmore 11084832201 ELECTRIC DRYER
Kenmore 11084832202 RESIDENTIAL DRYER
Kenmore 11084834200 ELECTRIC DRYER
Kenmore 11084834201 ELECTRIC DRYER
Kenmore 11084834202 RESIDENTIAL DRYER
Kenmore 11084836200 ELECTRIC DRYER
Kenmore 11084836201 ELECTRIC DRYER
Kenmore 11084836202 RESIDENTIAL DRYER
Kenmore 11084870100 AUTOMATIC WASHER
Kenmore 11084870110 AUTOMATIC WASHER
Kenmore 11084870300 AUTOMATIC WASHER
Kenmore 11084870600 AUTOMATIC WASHER
Kenmore 11084870610 AUTOMATIC WASHER
Kenmore 11084870700 AUTOMATIC WASHER
Kenmore 11084870800 AUTOMATIC WASHER
Kenmore 11084870810 AUTOMATIC WASHER
Kenmore 11084904 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11085081400 RESIDENTIAL DRYER
Kenmore 11085081401 RESIDENTIAL DRYER
Kenmore 11085087400 DRYER
Kenmore 11085087401 RESIDENTIAL DRYER
Kenmore 11085088400 DRYER
Kenmore 11085088401 RESIDENTIAL DRYER
Kenmore 11085089400 DRYER
Kenmore 11085089401 RESIDENTIAL DRYER
Kenmore 11085091400 RESIDENTIAL DRYER
Kenmore 11085091401 RESIDENTIAL DRYER
Kenmore 11085155100 SEARS ELECTRIC WASHER
Kenmore 11085156100 SEARS ELECTRIC WASHER
Kenmore 11085165100 SEARS ELECTRIC WASHER
Kenmore 11085165400 SEARS ELECTRIC WASHER
Kenmore 11085165600 SEARS ELECTRIC WASHER
Kenmore 11085165800 SEARS ELECTRIC WASHER
Kenmore 11085166100 ELECTRIC WASHER
Kenmore 11085175100 SEARS ELECTRIC WASHER
Kenmore 11085175200 SEARS ELECTRIC WASHER
Kenmore 11085175400 SEARS ELECTRIC WASHER
Kenmore 11085175600 SEARS ELECTRIC WASHER
Kenmore 11085175800 SEARS ELECTRIC WASHER
Kenmore 11085185100 SEARS ELECTRIC WASHER
Kenmore 11085185400 SEARS ELECTRIC WASHER
Kenmore 11085185600 SEARS ELECTRIC WASHER
Kenmore 11085185800 SEARS ELECTRIC WASHER
Kenmore 11085257100 ELECTRIC WASHER
Kenmore 11085365100 WASHER
Kenmore 11085365200 WASHER
Kenmore 11085365400 WASHER
Kenmore 11085365600 WASHER
Kenmore 11085365800 WASHER
Kenmore 11085861400 RESIDENTIAL DRYER
Kenmore 11085861401 RESIDENTIAL DRYER
Kenmore 11085862400 RESIDENTIAL DRYER
Kenmore 11085862401 RESIDENTIAL DRYER
Kenmore 11085866400 RESIDENTIAL DRYER
Kenmore 11085866401 RESIDENTIAL DRYER
Kenmore 11085871400 RESIDENTIAL DRYER
Kenmore 11085872400 RESIDENTIAL DRYER
Kenmore 11085872401 RESIDENTIAL DRYER
Kenmore 11085874400 RESIDENTIAL DRYER
Kenmore 11085874401 RESIDENTIAL DRYER
Kenmore 11085876400 RESIDENTIAL DRYER
Kenmore 11085876401 RESIDENTIAL DRYER
Kenmore 11086015100 ELECTRIC DRYER
Kenmore 11086015110 ELECTRIC DRYER
Kenmore 11086015120 ELECTRIC DRYER
Kenmore 11086030100 ELECTRIC DRYER
Kenmore 11086030110 ELECTRIC DRYER
Kenmore 11086030120 ELECTRIC DRYER
Kenmore 11086070100 ELECTRIC DRYER
Kenmore 11086070110 ELECTRIC DRYER
Kenmore 11086070200 ELECTRIC DRYER
Kenmore 11086070210 ELECTRIC DRYER
Kenmore 11086070400 ELECTRIC DRYER
Kenmore 11086070410 ELECTRIC DRYER
Kenmore 11086070600 ELECTRIC DRYER
Kenmore 11086070610 ELECTRIC DRYER
Kenmore 11086070800 ELECTRIC DRYER
Kenmore 11086070810 ELECTRIC DRYER
Kenmore 11086071100 ELECTRIC DRYER
Kenmore 11086071110 ELECTRIC DRYER
Kenmore 11086071120 ELECTRIC DRYER
Kenmore 11086071130 ELECTRIC DRYER
Kenmore 11086071200 ELECTRIC DRYER
Kenmore 11086071210 ELECTRIC DRYER
Kenmore 11086071220 ELECTRIC DRYER
Kenmore 11086071230 ELECTRIC DRYER
Kenmore 11086071400 ELECTRIC DRYER
Kenmore 11086071410 ELECTRIC DRYER
Kenmore 11086071420 ELECTRIC DRYER
Kenmore 11086071430 ELECTRIC DRYER
Kenmore 11086071600 ELECTRIC DRYER
Kenmore 11086071610 ELECTRIC DRYER
Kenmore 11086071620 ELECTRIC DRYER
Kenmore 11086071630 ELECTRIC DRYER
Kenmore 11086071800 ELECTRIC DRYER
Kenmore 11086071810 ELECTRIC DRYER
Kenmore 11086071820 ELECTRIC DRYER
Kenmore 11086071830 ELECTRIC DRYER
Kenmore 11086082100 ELECTRIC DRYER
Kenmore 11086082110 ELECTRIC DRYER
Kenmore 11086082120 ELECTRIC DRYER
Kenmore 11086082200 ELECTRIC DRYER
Kenmore 11086082210 ELECTRIC DRYER
Kenmore 11086082220 ELECTRIC DRYER
Kenmore 11086082400 ELECTRIC DRYER
Kenmore 11086082410 ELECTRIC DRYER
Kenmore 11086082420 ELECTRIC DRYER
Kenmore 11086082600 ELECTRIC DRYER
Kenmore 11086082610 ELECTRIC DRYER
Kenmore 11086082620 ELECTRIC DRYER
Kenmore 11086082800 ELECTRIC DRYER
Kenmore 11086082810 ELECTRIC DRYER
Kenmore 11086082820 ELECTRIC DRYER
Kenmore 11086093100 ELECTRIC DRYER
Kenmore 11086093110 ELECTRIC DRYER
  #2 (permalink)
Old 01-27-2014, 11:56 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You can determine if the control board is the problem by troubleshooting to eliminate other components in the dryer as the source of the problem. What is the problem with the dryer?
Eric
  #3 (permalink)
Old 01-27-2014, 12:08 PM
Expert
APP Volunteer
Default
Ok, just read your other post. With P1 plugged into board, check for 120vac between pin 3 and 5 (black and blue wires). If you don't have it there but do have it between 5 and 2 (black and white), then your door switch is bad. If door switch is ok, check for 120vac between 3 and 4 (light blue and blue) after pressing start button. You say you hear a click when pressing start button, but if your not getting 120vac at 3 and 4 of P1, then board is bad.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
rsortore richardsortore@bellsouth. Dryer Repair 0 01-26-2014 08:14 PM
rsortore richardsortore@bellsouth. Dryer Repair 0 01-25-2014 03:14 PM
rsortore richardsortore@bellsouth. Dryer Repair 1 01-23-2014 01:12 PM
