Dryer will not start has power all buttons light up 88 comes up as i push each button the lights go out. After pushing start button i get a code of 07 all i get is a buss and click in control board. I tested all aspects only thing i found when i took the 5 wire plug off the control board and tested the light blue wire and white wire for 120vac no reading pushed the start button and still no reading does this mean the control board is bad. thanks Richard
