Discuss
Kenmore runs but stops after 15 minutes
 in
Dryer Repair
hello! I have a Kenmore electric dryer about 14-15 yrs old. Model number 110.62802100. I replaced the motor with a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore runs but stops after 15 minutes
  #1 (permalink)
Old 01-19-2014, 07:49 PM
Junior Member
grebma is on a distinguished road
Default Kenmore runs but stops after 15 minutes
Model Number: 110.62802100   Brand: Kenmore   Age: More than 10 years
hello! I have a Kenmore electric dryer about 14-15 yrs old. Model number 110.62802100. I replaced the motor with a genuine Kenmore part from my local appliance guy. It still runs for about 15-20 minutes then stops halfway through the drying cycle. It heats well. I replaced the heating element last year. I cleaned everything, lint trap clear, vent pipe clear, drum rolls nice. I measured the heat coming out of the vent pipe on the back. It heats up to about 185 degrees then cool down to about 140 degrees. I think this is way too hot as the glare from the heating element was bright orange! I checked the 3 thermostats and they all checked out OK with continuity- that is if I checked them correctly. First time I used my voltmeter to check ohms.
Also we noticed that the timer is actually running slower than real time. I timed with a timer to see how long it would go before quitting. My timer showed 18 minutes but the timer control on the dryer only showed that it ran for about 10 minutes.
Any thoughts? I appreciate any time or ideas you may have. My wife is very hesitant to put any more $$$ into it at this point and I agree. we may look to buy new as we feel we've gotten lots of use out of it over the years. But now I just put a new motor in it so thought it may be something simple.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 01-20-2014, 03:10 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Why did you replace the motor?
Was it for this same problem?
When it shuts itself off can you restart it right away?
If not then it is probably the motor overheating and tripping it's internal protect. You then have to wait till the motor cools down before you can restart it.
Check that the drum rotates fairly easily in the correct direction. Could be there is a mechanical problem and the drum is putting too much drag on the motor.
If it is a motor overheating problem. looking at the parts breakdown at the sears site it shows a seal between the blower and the motor if you did not reinstall this when you replaced the motor then it could be that hot air is being blown back onto the motor causing it to overheat.
Your vent temperatures do look too high. The spec on the cycling thermostat is open at 155 degrees and re-close at 130 degrees.
It may need replacing.
I do not understand the timer problem.
But if the unit is in an auto mode the timer only advances when the heater is off so the times will not correspond to dial settings.
__________________
  #3 (permalink)
Old 01-21-2014, 05:24 PM
Junior Member
Default
I replaced the motor as it made a horrible buzzing noise upon startup, was progressively getting louder when it ran, and it would quit working after about 5 minutes. So at least I can get half a load of laundry done now
Thanks for the tip on the seal between the fan and motor. I'll check that. Does not restart right away. Need to wait about 30-45 minutes then it'll start.
I'm leaning towards the operating thermostat too. I read that on another thread too. It is not working properly and therefore the machine heats the element way too high to compensate (or along those lines). Makes sense to me anyway. But I'm no expert. Just trying to save a buck or 2 and gaining some pride in doing it myself.
  #4 (permalink)
Old 01-21-2014, 05:38 PM
Junior Member
Default
ALSO: I just thought of this too. I noticed the belt was pretty frayed and kinda coming apart. Is it possible that the belt is slipping and working the motor too much and then kicking out?
thanks for any info you may have.
  #5 (permalink)
Old 01-22-2014, 02:16 AM
Senior Expert
APP Volunteer
Default
I doubt the belt is causing the problem as if it was slipping it would reduce the load on the motor.
I would replace it as it is just a problem waiting to happen and it will only break when you really, really, really need the dryer.
Also check that the seals and drum supports are in good shape.
__________________
  #6 (permalink)
Old 02-12-2014, 07:01 PM
Junior Member
Default
Okay so here's my latest update. I unplugged the heating element just so see what would happen. It ran for about 48 minutes then shut off. I couldn't restart it so the motor must've been over heated. Which means it may not be the operating thermostat. I really don't know what else to look at. Is there a special grease for the drum wheels? All the seals look to be ok. I have a new operating thermostat that I picked up but I don't want to put it in unless I know for certain that's what the problem is.
How do I test this thermostat? What numbers am I looking for if I test the ohms?
the other thing I just noticed too: my dryer uses the older belt tensioner that has the rubber pad on it- no wheel. It has some grooves on the pad where the belt rubs and the belt is looking pretty frayed. Too much tension or load do you think? I plan to replace the tensioner, belt, and maybe the rollers too. thanks.
  #7 (permalink)
Old 02-13-2014, 03:12 AM
Senior Expert
APP Volunteer
Default
Yes
Click on a parts picture or description and a new page will open with more info.
Sometimes with a Q&A and a video.
At the top of this section there are views of how the belt/idler should look.
I would replace the tensioner with an idler wheel and also the belt.
Part number: AP2911909
The belt is AP2946843. There is a video on the second page.
Check the rear support rollers for slop.
If there is minimal slop and the wheels turn easily they are probably OK.
There is a roller kit available.
AP3098345. It includes 2 rollers and 4 tri-rings.
Checking the rollers shafts is a bit more difficult as often the tri-rings (AP5684740) will break getting them off.
If the shafts (AP5176394) are worn then they should be replaced along with the rollers.
The rollers should not require any lubrication.
If the old rollers and shafts are OK then a drop of oil would not hurt but just a drop as oil will collect lint.
There is also a seal (AP2947135) on the back of the blower (motor side), check that it is OK. It reduces any hot air from the blower being blown back onto the motor.
Also check the front support bearings/rings.
The operating thermostat is harder to check.
The easiest way is to monitor the exhaust temperature when the unit is on.
On regular/high heat it should open at 155 degrees F and re-close at 130 degrees.
The outer two contacts should be 0 ohms at room temperature and infinite ohms at over 155.
The inner two contacts are the built in heater. They should be 5,000 to 20,000 ohms. I cannot find tech info on this unit so cannot give you an exact number. In any case it is only turned on when you use a lower heat setting. It adds heat to the thermostat which causes it to cycle more often, reducing the units heat output.
I hope the above helps.
I am off to the cabin for a few days so will be unavailable.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dryer runs for a few minutes (<5) and then stops jjmac03 Dryer Repair 5 04-11-2012 06:27 PM
Whirlpool runs a few minutes then stops slyf15e Dryer Repair 1 03-13-2012 05:00 AM
Dryer runs for a few minutes and stops. george.henne Dryer Repair 6 02-21-2011 04:52 AM
frigidaire dryer runs 15 minutes and stops phil12357 Dryer Repair 4 11-04-2010 08:11 AM
runs for a few minutes and stops FISHMASTER70 Dryer Repair 8 09-17-2008 07:34 PM
