Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Takes too long to dry (http://forum.appliancepartspros.com/dryer-repair/544331-takes-too-long-dry.html)
DDEBRUS 01-19-2014 12:20 PM
i have replaced the cycling thermostats and continue to have issues with it taking too long to dry clothes. Would it help to replace the thermo fuse?
fairbank56 01-19-2014 01:36 PM
Double check the model number, doesn't come up. If dryer is heating, thermal fuse is ok.
Eric
denman 01-20-2014 03:12 AM
The most common cause of long dry times is a partially plugged vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
