Discuss
1980's era elec dryer - I think I fixed it - somebody respond please
 in
Dryer Repair
After a day of thinking, I decided to try to reattach black wire to the heating element. Initially, the main
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » 1980's era elec dryer - I think I fixed it - somebody respond please
  #1 (permalink)
Old 01-14-2014, 11:56 AM
Junior Member
willtryitchick is on a distinguished road
Default 1980's era elec dryer - I think I fixed it - somebody respond please
Model Number: LDE 212   Brand: Maytag   Age: More than 10 years
Initially, the main power wire looked a little singed (black 2 cm at end of wire). I stripped a bit more of the plastic coating off and used a wire brush to clean the copper wires. I also removed the copper nut from the 'sparkplug white plastic heating element holder thing'. I cleaned the nut too.
I twisted the exposed clean wire, made a loop, covered the rest of exposed with black electric tape, hooked loop onto 'white plastic sparkplug looking heating element holder thing', reattached nut, reattached door open start wires, and replaced front panel. Also cleaned everything out while in there.
I plugged her in. Put a wet towel in and turned her on for about 3-5 minutes. THE OLD TROOPER HEATED UP! YEAH!
BUT, DID I FIX IT OR HAVE I SET MYSELF UP FOR A FIRE!
many thanks for any advice. erika
Related Models
Admiral LDE1000ACE DRYER- ELE
Admiral LDE1000AKE DRYER- ELE
Admiral LDE1000GGE DRYER- ELE
Maytag LDE110 DRYER- ELE
Maytag LDE18CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CA MANUAL, PARTS (DRYER ELE)
Maytag LDE19CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CS MANUAL, PARTS (DRYER ELE)
Maytag LDE19CT MANUAL, PARTS (DRYER ELE)
Maytag LDE210 DRYER- ELE
Maytag LDE212 DRYER- ELE
Maytag LDE21CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE22CS MANUAL, PARTS (DRYER ELE)
Maytag LDE22CT MANUAL, PARTS (DRYER ELE)
Maytag LDE23CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE25CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE26CA MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CS MANUAL, PARTS (DRYER ELE)
Maytag LDE26CT MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE27CA MANUAL, PARTS (DRYER ELE)
Maytag LDE27CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE27CS MANUAL, PARTS (DRYER ELE)
Maytag LDE27CT MANUAL, PARTS (DRYER ELE)
Maytag LDE303 DRYER- ELE
Maytag LDE312 DRYER- ELE
Maytag LDE313 DRYER- ELE
Frigidaire LDE333PBW0 Frg(v0) / Gas Dryer
Frigidaire LDE333PBW1 Frg(v0) / Electric Dryer
Frigidaire LDE333PEW0 Frg(v0) / Electric Dryer
Maytag LDE382 DRYER- ELE
Maytag LDE4000 DRYER- ELE
Maytag LDE4000ACL DRYER- ELE
Maytag LDE4000ACW DRYER- ELE
Maytag LDE4000ADL DRYER- ELE
Maytag LDE4000ADW DRYER- ELE
Maytag LDE410 DRYER- ELE
Maytag LDE412 DRYER- ELE
Maytag LDE482 DRYER- ELE
Maytag LDE490 DRYER- ELE
Maytag LDE4910 DRYER- ELE
Maytag LDE4910ACL DRYER- ELE
Maytag LDE4910ACW DRYER- ELE
Maytag LDE4914ACE DRYER- ELE
Maytag LDE4914ACL DRYER- ELE
Maytag LDE4914ACM DRYER- ELE
Maytag LDE4916ACE DRYER- ELE
Maytag LDE4916ACM DRYER- ELE
Maytag LDE4916ADE DRYER- ELE
Maytag LDE5004ACW DRYER- ELE
Maytag LDE5004ADW DRYER- ELE
Maytag LDE5005ACE DRYER- ELE
Maytag LDE5005ADE DRYER- ELE
Maytag LDE510 DRYER- ELE
Maytag LDE512 DRYER- ELE
Maytag LDE590 DRYER- ELE
Maytag LDE590D DRYER- ELE
Maytag LDE5910 DRYER- ELE
Maytag LDE5910ACL DRYER- ELE
Maytag LDE5910ACW DRYER- ELE
Maytag LDE5914ACE DRYER- ELE
Maytag LDE5914ACL DRYER- ELE
Maytag LDE5914ACM DRYER- ELE
Maytag LDE5916ACE DRYER- ELE
Maytag LDE5916ACM DRYER- ELE
Maytag LDE5916ADE DRYER- ELE
Maytag LDE6004ACW DRYER- ELE
Maytag LDE610 DRYER- ELE
Maytag LDE612 DRYER- ELE
Maytag LDE6914ACE DRYER- ELE
Maytag LDE6914ACL DRYER- ELE
Maytag LDE6914ACM DRYER- ELE
Maytag LDE710 DRYER- ELE
Maytag LDE712 DRYER- ELE
Maytag LDE713 DRYER- ELE
Maytag LDE7304ACE DRYER- ELE
Maytag LDE7304ACL DRYER- ELE
Maytag LDE7304ACM DRYER- ELE
Maytag LDE7304ADE DRYER- ELE
Maytag LDE7304ADL DRYER- ELE
Maytag LDE7304ADM DRYER- ELE
Maytag LDE7304AEE DRYER- ELE
Maytag LDE7304AGE DRYER- ELE
Maytag LDE7304AGL DRYER- ELE
Maytag LDE7304AGM DRYER- ELE
Maytag LDE7314ACE DRYER- ELE
Maytag LDE7314ACL DRYER- ELE
Maytag LDE7314ACM DRYER- ELE
Maytag LDE7314ADE DRYER- ELE
Maytag LDE7334ACE DRYER- ELE
Maytag LDE7334ACL DRYER- ELE
Maytag LDE7334ACM DRYER- ELE
Maytag LDE7400 DRYER- ELE
Maytag LDE7400ACL DRYER- ELE
Maytag LDE7400ACM DRYER- ELE
Maytag LDE7400ACW DRYER- ELE
Maytag LDE7400ADL DRYER- ELE
Maytag LDE7400ADW DRYER- ELE
Maytag LDE7480ACL DRYER- ELE
Maytag LDE7480ACW DRYER- ELE
Maytag LDE7480ADL DRYER- ELE
Maytag LDE7480ADW DRYER- ELE
Maytag LDE7500 DRYER- ELE
Maytag LDE7500ACE DRYER- ELE
Maytag LDE7500ACL DRYER- ELE
Maytag LDE7500ACM DRYER- ELE
Maytag LDE7500ACW DRYER- ELE
Maytag LDE7500ADE DRYER- ELE
Maytag LDE7500ADL DRYER- ELE
Maytag LDE7500ADM DRYER- ELE
Maytag LDE7500ADW DRYER- ELE
Maytag LDE7600 DRYER- ELE
Maytag LDE7600ACG DRYER- ELE
  #2 (permalink)
Old 01-14-2014, 12:09 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You should keep cutting and stripping that wire back until you find clean copper wire strands that do not need wire brushing! If necessary, splice a new wire in but it has to be done with proper size butt connector and crimped with proper crimping tool. The end that attaches to the heater element should have the proper ring terminal lug properly crimped to the wire using proper crimping tool. That heater element is going to draw over 20 amps of current. Any point in that circuit that you have substandard wiring and/or connections, is going to overheat.
Eric
  #3 (permalink)
Old 01-14-2014, 12:45 PM
Junior Member
Unhappy Going to appliance parts store for right parts
Eric - thanks, I had a feeling this was not going to fly for too long . I will get the ring lug connector and wire crimper and check the wire for more singe etc... what is the part called that looks like a sparkplug that the ring lug connector goes on?
Can you tell me - did this short out due to maybe water leaking from drum onto this wire connection? I couldn't find any ring lug connector when I first opened it up - so to be continued. but haven't given up yet.
PS - being safe by unplugging etc.. and will call in pro's if my next effort proves uncertain.
  #4 (permalink)
Old 01-14-2014, 01:17 PM
Expert
APP Volunteer
Default
It's a ceramic standoff. The connection may have gotten wet and then corroded or it was just a bit loose. Either one would produce resistance and that high current through resistance causes the connection to get hot which then makes the connection even worse and it escalates to the point of failure (melting/breaking). You must have good clean and tight connections.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1980's era maytag dryer heating element connections willtryitchick Dryer Repair 0 01-12-2014 01:51 PM
GE Harmony dryer LCD screen won't respond Ricson Dryer Repair 3 11-25-2010 06:39 AM
Kenmore Elite Dryer won't respond rickring01 Dryer Repair 0 09-02-2010 09:16 AM
dryer dead - fixed jptex Dryer Repair 1 10-28-2009 11:58 AM
