Discuss
Erratic touchpad test results for failing Kenmore Elite Dryer
 in
Dryer Repair
The touchpad on this dryer has at times not responded at all, or worked perfectly, worked after unplugging, worked after
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Erratic touchpad test results for failing Kenmore Elite Dryer
  #1 (permalink)
Old 01-13-2014, 06:49 PM
Junior Member
gmilo2 is on a distinguished road
Question Touchpad not responding / erratic test results
Model Number: 11062052100   Brand: Kenmore   Age: More than 10 years
The touchpad on this dryer has at times not responded at all, or worked perfectly, worked after unplugging, worked after working the buttons, beeped erratically during drying, worked after heating the back/front of the touchpad and/or control panel with a heat gun, etc. It has not worked consistently for more than 2 weeks at a time (usually stops responding to touchpad keys completely), in a long time. I have done the various key matrix resistance checks on the individual buttons, and at times all but a few of the buttons are bad (and it is not always the same buttons that are bad). Then I have tested it other times, and all test out good and the touchpad works perfectly.
UPDATE: Replacing the touchpad/control assembly fixed the problem.
Related Models
Kenmore 11062052100 DRYER
Kenmore 1106205250 KENMORE AUTOMATIC WASHER
Kenmore 1106205252 KENMORE AUTOMATIC WASHER
Kenmore 1106205253 KENMORE AUTOMATIC WASHER
Kenmore 1106205254 KENMORE AUTOMATIC WASHERS
Kenmore 1106205255 KENMORE AUTOMATIC WASHERS
Kenmore 1106205300 KENMORE AUTOMATIC WASHER
Kenmore 1106205303 KENMORE AUTOMATIC WASHER
Kenmore 1106205304 KENMORE AUTOMATIC WASHER
Kenmore 1106205305 KENMORE AUTOMATIC WASHER
Kenmore 1106205306 KENMORE AUTOMATIC WASHERS
Kenmore 1106205307 KENMORE AUTOMATIC WASHERS
Kenmore 1106205350 KENMORE AUTOMATIC WASHER
Kenmore 1106205354 KENMORE AUTOMATIC WASHER
Kenmore 1106205355 KENMORE AUTOMATIC WASHER
Kenmore 1106205356 KENMORE AUTOMATIC WASHERS
Kenmore 1106205357 KENMORE AUTOMATIC WASHERS
Kenmore 1106205400 KENMORE AUTOMATIC WASHERS
Kenmore 1106205401 KENMORE AUTOMATIC WASHER
Kenmore 11062054100 DRYER
Kenmore 1106205450 KENMORE AUTOMATIC WASHERS
Kenmore 1106205500 KENMORE AUTOMATIC WASHER
Kenmore 1106205501 KENMORE AUTOMATIC WASHER
Kenmore 1106205502 KENMORE AUTOMATIC WASHER
Kenmore 1106205550 KENMORE AUTOMATIC WASHER
Kenmore 1106205551 KENMORE AUTOMATIC WASHER
Kenmore 1106205600 KENMORE AUTOMATIC WASHERS
Kenmore 1106205601 KENMORE AUTOMATIC WASHER
Kenmore 1106205602 KENMORE AUTOMATIC WASHER
Kenmore 1106205603 KENMORE AUTOMATIC WASHER
Kenmore 11062056100 DRYER
Kenmore 1106205650 KENMORE AUTOMATIC WASHERS
Kenmore 1106205651 KENMORE AUTOMATIC WASHER
Kenmore 1106205653 KENMORE AUTOMATIC WASHER
Kenmore 1106205700 KENMORE AUTOMATIC WASHER
Kenmore 1106205701 KENMORE AUTOMATIC WASHER
Kenmore 1106205702 KENMORE AUTOMATIC WASHER
Kenmore 1106205703 KENMORE AUTOMATIC WASHER
Kenmore 1106205704 KENMORE AUTOMATIC WASHER
Kenmore 1106205710 KENMORE AUTOMATIC WASHER
Kenmore 1106205720 KENMORE AUTOMATIC WASHER
Kenmore 1106205750 KENMORE AUTOMATIC WASHER
Kenmore 1106205751 KENMORE AUTOMATIC WASHER
Kenmore 1106205752 KENMORE AUTOMATIC WASHER
Kenmore 1106205753 KENMORE AUTOMATIC WASHER
Kenmore 1106205754 KENMORE AUTOMATIC WASHER
Kenmore 1106205760 KENMORE AUTOMATIC WASHER
Kenmore 1106205800 KENMORE AUTOMATIC WASHER
Kenmore 1106205801 KENMORE AUTOMATIC WASHER
Kenmore 1106205802 KENMORE AUTOMATIC WASHER
Kenmore 1106205803 KENMORE AUTOMATIC WASHER
Kenmore 1106205804 KENMORE AUTOMATIC WASHER
Kenmore 1106205805 KENMORE AUTOMATIC WASHER
Kenmore 1106205806 KENMORE AUTOMATIC WASHER
Kenmore 1106205807 KENMORE AUTOMATIC WASHERS
Kenmore 1106205808 KENMORE AUTOMATIC WASHER
Kenmore 1106205850 KENMORE AUTOMATIC WASHER
Kenmore 1106205851 KENMORE AUTOMATIC WASHER
Kenmore 1106205852 KENMORE AUTOMATIC WASHER
Kenmore 1106205853 KENMORE AUTOMATIC WASHER
Kenmore 1106205854 KENMORE AUTOMATIC WASHER
Kenmore 1106205855 KENMORE AUTOMATIC WASHER
Kenmore 1106205856 KENMORE AUTOMATIC WASHER
Kenmore 1106205857 KENMORE AUTOMATIC WASHERS
Kenmore 1106205858 KENMORE AUTOMATIC WASHER
Kenmore 11062062100 DRYER
Kenmore 11062062101 ELECTRIC DRYER
Kenmore 11062062102 ELECTRIC DRYER
Kenmore 11062062103 RESIDENTIAL DRYER
Kenmore 11062064100 DRYER
Kenmore 11062064101 ELECTRIC DRYER
Kenmore 11062064102 ELECTRIC DRYER
Kenmore 11062064103 RESIDENTIAL DRYER
Kenmore 11062066100 DRYER
Kenmore 11062066101 ELECTRIC DRYER
Kenmore 11062066102 ELECTRIC DRYER
Kenmore 11062066103 RESIDENTIAL DRYER
Kenmore 1106207400 KENMORE GAS DRYER
Kenmore 1106207401 KENMORE GAS DRYER
Kenmore 1106207420 KENMORE GAS DRYER
Kenmore 1106207421 KENMORE GAS DRYER
Kenmore 1106207430 KENMORE GAS DRYER
Kenmore 1106207431 KENMORE GAS DRYER
Kenmore 1106207432 KENMORE GAS DRYER
Kenmore 1106207433 KENMORE GAS DRYER
Kenmore 1106207500 KENMORE GAS DRYER
Kenmore 1106207501 KENMORE GAS DRYER
Kenmore 1106207502 KENMORE GAS DRYER
Kenmore 1106207511 KENMORE GAS DRYER
Kenmore 1106207600 KENMORE GAS DRYER
Kenmore 1106207601 KENMORE GAS DRYER
Kenmore 1106207700 KENMORE GAS DRYER
Kenmore 1106207701 KENMORE GAS DRYER
Kenmore 1106207702 KENMORE GAS DRYER
Kenmore 1106207703 KENMORE GAS DRYER
Kenmore 1106207704 KENMORE GAS DRYER
Kenmore 1106207705 KENMORE GAS DRYER
Kenmore 1106207710 KENMORE GAS DRYER
Kenmore 1106207741 KENMORE GAS DRYER
Kenmore 1106207742 KENMORE GAS DRYER
Kenmore 1106207800 KENMORE GAS DRYER
Kenmore 1106207801 KENMORE GAS DRYER
Kenmore 1106207802 KENMORE GAS DRYER
Kenmore 1106207803 KENMORE GAS DRYER
Kenmore 1106207804 KENMORE GAS DRYER
Kenmore 11062082100 DRYER
Kenmore 11062082101 ELECTRIC DRYER
Kenmore 11062082102 ELECTRIC DRYER
Kenmore 1106208400 KENMORE ELECTRIC DRYER
Kenmore 1106208401 KENMORE ELECTRIC DRYER
Kenmore 11062084100 DRYER
Kenmore 11062084101 ELECTRIC DRYER
Kenmore 11062084102 ELECTRIC DRYER
Kenmore 1106208420 KENMORE ELECTRIC DRYER
Kenmore 1106208430 KENMORE ELECTRIC DRYER
Kenmore 1106208431 KENMORE ELECTRIC DRYER
Kenmore 1106208432 KENMORE ELECTRIC DRYER
Kenmore 1106208433 KENMORE ELECTRIC DRYER
Kenmore 1106208500 KENMORE ELECTRIC DRYER
Kenmore 1106208501 KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 03-21-2014, 05:32 PM
Junior Member
Default
Solved - see edited message.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite S/S freezer cold, fridge erratic erbenson Refrigerator & Freezer Repair 1 06-14-2012 05:20 AM
Kenmore elite touchpad problem? srbakall Washer Repair 1 09-07-2011 01:51 PM
Kenmore Elite Touchpad no power grj8 Dishwasher Repair 3 11-16-2010 05:43 AM
GE Profile Harmony Touchpad Failing applescriptguru Dryer Repair 2 08-23-2010 03:00 PM
Kenmore elite touchpad problem? srbakall Washer Repair 2 09-26-2009 07:34 AM
