Discuss
No heat from Whirlpool Dryer
 in
Dryer Repair
I would appreciate any help of. Our dryer turns on and tumbles, but has no heat. We looked through the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat from Whirlpool Dryer
  #1 (permalink)
Old 01-13-2014, 01:19 PM
Junior Member
MRich is on a distinguished road
Default No heat from Whirlpool Dryer
Model Number: Wgd 6200sw1   Brand: Whirlpool   Age: 1 - 5 years
I would appreciate any help of. Our dryer turns on and tumbles, but has no heat. We looked through the little peep hole and see no glow, or flame. We also checked the thermal fuse, thermal cut-off, and high limit thermostat with an ohm meter, it is reading all 3 are bad. Will those 3 elements being bad, cause the coils not to work? Should I be replacing those 3 elements and then the coils will work, or should I be replacing the coils first. Thanks for any help
Related Models
Whirlpool WGD4750XQ0 29" GAS DRYER
Whirlpool WGD4750XQ1 29" GAS DRYER
Whirlpool WGD4800XQ0 DRYER
Whirlpool WGD4850XQ0 29" GAS DRYER
Whirlpool WGD4890XQ0 29" GAS DRYER
Whirlpool WGD4900XW0 29" GAS DRYER
Whirlpool WGD4910XQ0 29" GAS DRYER
Whirlpool WGD5000VQ1 29" GAS DRYER
Whirlpool WGD5100SQ0 29" GAS DRYER
Whirlpool WGD5100VQ0 29" GAS DRYER
Whirlpool WGD5100VQ1 29" GAS DRYER
Whirlpool WGD5200TQ0 29" GAS DRYER
Whirlpool WGD5200VQ0 29" GAS DRYER
Whirlpool WGD5200VQ1 29" GAS DRYER
Whirlpool WGD5300SQ0 29"GAS DRYER
Whirlpool WGD5300ST0 29"GAS DRYER
Whirlpool WGD5300VW0 29" GAS DRYER
Whirlpool WGD5300VW1 29" GAS DRYER
Whirlpool WGD5310SQ0 29"GAS DRYER
Whirlpool WGD5320SQ0 29"GAS DRYER
Whirlpool WGD5321SQ0 29"GAS DRYER
Whirlpool WGD5500SQ0 29"GAS DRYER
Whirlpool WGD5500ST0 29"GAS DRYER
Whirlpool WGD5500XL0 27" ELECTRIC DRYER
Whirlpool WGD5500XL1 27" ELECTRIC DRYER
Whirlpool WGD5500XW0 27" ELECTRIC DRYER
Whirlpool WGD5500XW1 27" ELECTRIC DRYER
Whirlpool WGD5510VQ0 29"GAS DRYER
Whirlpool WGD5510VQ1 29"GAS DRYER
Whirlpool WGD5520SQ0 29" GAS DRYER
Whirlpool WGD5521SQ0 29"GAS DRYER
Whirlpool WGD5530SQ0 29"GAS DRYER
Whirlpool WGD5540SQ0 29"GAS DRYER
Whirlpool WGD5540ST0 29"GAS DRYER
Whirlpool WGD5550SQ0 29" GAS DRYER
Whirlpool WGD5550ST0 29" GAS DRYER
Whirlpool WGD5550XW0 27" GAS DRYER
Whirlpool WGD5550XW1 27" GAS DRYER
Whirlpool WGD5560SQ0 29" GAS DRYER
Whirlpool WGD5590VQ0 29" GAS DRYER
Whirlpool WGD5590VQ1 29" GAS DRYER
Whirlpool WGD5600SQ0 29" GAS DRYER
Whirlpool WGD5600ST0 29" GAS DRYER
Whirlpool WGD5600VQ0 29" GAS DRYER
Whirlpool WGD5600XW0 27" GAS DRYER
Whirlpool WGD5600XW1 27" GAS DRYER
Whirlpool WGD5610XW0 27" GAS DRYER
Whirlpool WGD5610XW1 27" GAS DRYER
Whirlpool WGD5700SW0 29" GAS DRYER
Whirlpool WGD5700VH0 29" GAS DRYER
Whirlpool WGD5700VH1 29" GAS DRYER
Whirlpool WGD5700VW0 29" GAS DRYER
Whirlpool WGD5700VW1 29" GAS DRYER
Whirlpool WGD5700XL0 27" GAS DRYER
Whirlpool WGD5700XL1 27" GAS DRYER
Whirlpool WGD5700XW0 27" GAS DRYER
Whirlpool WGD5700XW1 27" GAS DRYER
Whirlpool WGD5790SQ0 29" GAS DRYER
Whirlpool WGD5790ST0 29" GAS DRYER
Whirlpool WGD5790VQ0 29" GAS DRYER
Whirlpool WGD5790VQ1 29" GAS DRYER
Whirlpool WGD5800SG0 29"GAS DRYER
Whirlpool WGD5800SW0 29"GAS DRYER
Whirlpool WGD5810SW0 29"GAS DRYER
Whirlpool WGD5820SW0 29"GAS DRYER
Whirlpool WGD5821SW0 29"GAS DRYER
Whirlpool WGD5830SW0 29"GAS DRYER
Whirlpool WGD5840SG0 29"GAS DRYER
Whirlpool WGD5840SW0 29"GAS DRYER
Whirlpool WGD5850SG0 29"GAS DRYER
Whirlpool WGD5850SW0 29"GAS DRYER
Whirlpool WGD5856SG0 29"GAS DRYER
Whirlpool WGD5860SW0 29"GAS DRYER
Whirlpool WGD5900SB0 29" GAS DRYER
Whirlpool WGD5900SW0 29" GAS DRYER
Whirlpool WGD6200SW0 29"GAS DRYER
Whirlpool WGD6200SW1 29" GAS DRYER
Whirlpool WGD6200SW2 29" GAS DRYER
Whirlpool WGD6400SB0 29"GAS DRYER
Whirlpool WGD6400SB1 29"GAS DRYER
Whirlpool WGD6400SB2 29" GAS DRYER
Whirlpool WGD6400SG0 29"GAS DRYER
Whirlpool WGD6400SG1 29"GAS DRYER
Whirlpool WGD6400SG2 29" GAS DRYER
Whirlpool WGD6400SW0 29"GAS DRYER
Whirlpool WGD6400SW1 29"GAS DRYER
Whirlpool WGD6400SW2 29" GAS DRYER
Whirlpool WGD6600VU0 29" GAS DRYER
Whirlpool WGD6600VU1 29" GAS DRYER
Whirlpool WGD6600VW0 29" GAS DRYER
Whirlpool WGD6600VW1 29" GAS DRYER
Whirlpool WGD6600WL0 29"GAS DRYER
Whirlpool WGD7300XW0 27" ELECTRIC DRYER
Whirlpool WGD7400XW0 27" GAS DRYER
Whirlpool WGD7600XW0 27" GAS DRYER
Whirlpool WGD7800XB0 27" GAS DRYER
Whirlpool WGD7800XL0 27" GAS DRYER
Whirlpool WGD7800XW0 27" GAS DRYER
Whirlpool WGD7990XG0 DRYER
Whirlpool WGD8200YW0 DRYER
Whirlpool WGD8300SB0 27" GAS DRYER
Whirlpool WGD8300SB1 27" GAS DRYER
Whirlpool WGD8300SB2 27" GAS DRYER
Whirlpool WGD8300SE2 27" GAS DRYER
Whirlpool WGD8300SW0 27" GAS DRYER
Whirlpool WGD8300SW1 27" GAS DRYER
Whirlpool WGD8300SW2 27" GAS DRYER
Whirlpool WGD8410SW0 27"GAS DRYER
Whirlpool WGD8410SW1 27" GAS DRYER
Whirlpool WGD8500SR0 27"GAS DRYER
Whirlpool WGD8500SR1 27" GAS DRYER
Whirlpool WGD8600YW0 DRYER
Whirlpool WGD8800YC0 27" GAS DRYER
Whirlpool WGD8800YW0 27" GAS DRYER
Whirlpool WGD9050XW0 27" GAS DRYER
Whirlpool WGD9050XW1 GAS DRYER
Whirlpool WGD9150WW0 27" GAS DRYER
Whirlpool WGD9150WW1 27" GAS DRYER
Whirlpool WGD9151YW0 27" GAS DRYER
Whirlpool WGD9200SQ0 GAS DRYER
  #2 (permalink)
Old 01-13-2014, 02:31 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
If either one of those are open, the gas coils will not work. Did you make sure your meter is working by touching the probes together? There is an MOV (surge protector) across the wires at the burner harness connector. Unplug the connector and check continuity across the protector to make sure it's not shorted.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up NVChickey Dryer Repair 1 02-25-2012 11:52 PM
Whirlpool Dryer, getting Heat on NO heat setting. gph1 Dryer Repair 1 09-24-2010 01:09 PM
Whirlpool Gas Dryer won't heat wartrue Dryer Repair 0 10-29-2009 07:41 AM
Whirlpool dryer - no heat verruckt Dryer Repair 9 12-14-2008 04:26 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
