Discuss
Access to thermal fuse
 in
Dryer Repair
The dryer does not have a removable back panel. It appears that the back and sides are all one piece.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Access to thermal fuse
  #1 (permalink)
Old 01-13-2014, 12:01 PM
Junior Member
Chunder is on a distinguished road
Default Access to thermal fuse
Model Number: NDE5805AYW   Brand: Amana   Age: 5 - 10 years
The dryer does not have a removable back panel. It appears that the back and sides are all one piece. The front does not look simple to remove. There are no external screws on the front panel. The top comes off pretty easily, but does not give access down to the heater/duct area where I believe the fuse is located. This is a very poor design. I'll be sure that my next dryer has a removable back panel and is easier to diagnose and service for a novice. The dryer will not run, but has power as evidenced by the door light. The door switch is fine. The timer/push to start unit is too complicated for me and too expensive to replace on a 2006 dryer. That left the thermal fuse as the last thing to check before this unit goes out the door. Thanks for an insight on internal access. Every video shows dryers that have nice, accessible cabinets with components that pop in and out. Mine is a real fortress.
Related Models
Amana NDE5805AYW DRYER- ELE
Amana NDE5805AZW DRYER- ELE
Maytag NDE6800AYW DRYER- ELE
Amana NDE7800AYW DRYER- ELE
Amana NDE7800AZW DRYER- ELE
Amana NDE8805AYW DRYER- ELE
Amana NDE8805AZW DRYER- ELE
Amana NDG2330AWW DRYER- GAS
Amana NDG2335AWW DRYER- GAS
Amana NDG5800AWW DRYER- GAS
Amana NDG5805AWW DRYER- GAS
Maytag NDG6800AWW DRYER- GAS
Amana NDG7800AWW DRYER- GAS
Amana NDG8805AWW DRYER- GAS
Maytag NDNS229F REF - SXS/I&W
Maytag NDNS229FA REF - SXS/I&W
Maytag NDNS229FH REF - SXS/I&W
Maytag NDNS229G REF - SXS/I&W
Maytag NDNS229GA REF - SXS/I&W
Maytag NDNS229GH REF - SXS/I&W
Maytag NDNS229GZA REF - SXS/I&W
Maytag NDNS229GZH REF - SXS/I&W
Maytag NDNS229GZN REF - SXS/I&W
Maytag NDNS229J REF - SXS/I&W
Maytag NDNS229JA REF - SXS/I&W
Maytag NDNS229JH REF - SXS/I&W
Maytag NDNS249G REF - SXS/I&W
Maytag NDNS249GA REF - SXS/I&W
Maytag NDNS249GH REF - SXS/I&W
Maytag NDNS249GZ REF - SXS/I&W
Maytag NDNS249GZA REF - SXS/I&W
Maytag NDNS249GZH REF - SXS/I&W
Maytag NDNS249J REF - SXS/I&W
Maytag NDNS249JA REF - SXS/I&W
Maytag NDNS249JH REF - SXS/I&W
Maytag NDNT189J REF - TOP MOUNT/ I&W
Maytag NDNT189JA REF - TOP MOUNT/ I&W
Maytag NDNT229G REF - TOP MOUNT/ I&W
Maytag NDNT229GA REF - TOP MOUNT/ I&W
Maytag NDNT229GH REF - TOP MOUNT/ I&W
Maytag NDNT229GX REF - TOP MOUNT/ I&W
Maytag NDNT229GXA REF - TOP MOUNT/ I&W
Maytag NDNT229GXH REF - TOP MOUNT/ I&W
Maytag NDNT229J REF - SXS/I&W
Maytag NDNT229JA REF - SXS/I&W
Maytag NDNT229JH REF - SXS/I&W
Norge NDU2CA-01 DISHWASHER- UNDERCOUNTER
Norge NDU2CA-20 DISHWASHER- UNDERCOUNTER
Norge NDU2CA-25 DISHWASHER- UNDERCOUNTER
Norge NDU2CA-35 DISHWASHER- UNDERCOUNTER
Norge NDU2J-CAN DISHWASHER- UNDERCOUNTER
Norge NDU450B DISHWASHER- UNDERCOUNTER
Norge NDU450V DISHWASHER- UNDERCOUNTER
Norge NDU4CA-40 DISHWASHER- UNDERCOUNTER
Norge NDU4CA-45 DISHWASHER- UNDERCOUNTER
Norge NDU4CA-48 DISHWASHER- UNDERCOUNTER
Norge NDU4J DISHWASHER- UNDERCOUNTER
Norge NDU4K DISHWASHER- UNDERCOUNTER
Norge NDU5CA-01 DISHWASHER- UNDERCOUNTER
Norge NDU5CA-20 DISHWASHER- UNDERCOUNTER
Norge NDU5CA-25 DISHWASHER- UNDERCOUNTER
Norge NDU5CA-35 DISHWASHER- UNDERCOUNTER
Norge NDU5CA-40 DISHWASHER- UNDERCOUNTER
Norge NDU5CA-45 DISHWASHER- UNDERCOUNTER
Norge NDU5CA-48 DISHWASHER- UNDERCOUNTER
Norge NDU5J DISHWASHER- UNDERCOUNTER
Norge NDU5J-CAN DISHWASHER- UNDERCOUNTER
Norge NDU655P DISHWASHER- UNDERCOUNTER
Norge NDU7CA-01 DISHWASHER- UNDERCOUNTER
Norge NDU7CA-20 DISHWASHER- UNDERCOUNTER
Norge NDU7CA-25 DISHWASHER- UNDERCOUNTER
Norge NDU7CA-35 DISHWASHER- UNDERCOUNTER
Amana NE2113 WASHER-TOP LOADING
Amana NE3313 WASHER-TOP LOADING
Amana NE3513 WASHER-TOP LOADING
Amana NE4313 WASHER-TOP LOADING
Amana NE4513 WASHER-TOP LOADING
Amana NE4613 WASHER-TOP LOADING
Amana NE4713 WASHER-TOP LOADING
Amana NE4813 DRYER- ELE
Amana NE5313 WASHER-TOP LOADING
Amana NE5513 WASHER-TOP LOADING
Amana NE6313 WASHER-TOP LOADING
Amana NE6333 WASHER-TOP LOADING
Amana NE6513 WASHER-TOP LOADING
Amana NE6533 WASHER-TOP LOADING
Amana NE6613 WASHER-TOP LOADING
Amana NE6813 DRYER- ELE
Amana NE7313 WASHER-TOP LOADING
Amana NE7513 WASHER-TOP LOADING
Amana NE8333 WASHER-TOP LOADING
Amana NE8533 WASHER-TOP LOADING
Amana NE8633 WASHER-TOP LOADING
Amana NE8833 DRYER- ELE
Norge NEA2G1 RANGE- F/S STD ELE
Norge NEA2H0 RANGE- F/S STD ELE
Norge NEA2H1 RANGE- F/S STD ELE
Norge NEA3G1 RANGE- F/S STD ELE
Norge NEA3G8AC RANGE- S/C F/S ELE
Norge NEA3G8CV RANGE- S/C F/S ELE
Norge NEA3G8CX RANGE- S/C F/S ELE
Norge NEA3G8DEV RANGE- S/C F/S ELE
Norge NEA3G8DX RANGE- S/C F/S ELE
Norge NEA3G8EV RANGE- S/C F/S ELE
Norge NEA3G8EVW RANGE- S/C F/S ELE
  #2 (permalink)
Old 01-13-2014, 12:48 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You can check the thermal fuse by opening the control panel and checking resistance between timer M terminal and GY terminal. If fuse is good, you will read through motor run winding which should only be a couple ohms. If you read open, the fuse is likely bad. With dryer top panel opened, you should see two screws holding front panel. Remove them and then lift front panel off being careful about drum falling out and door switch wiring.
Eric
  #3 (permalink)
Old 01-13-2014, 01:05 PM
Junior Member
Default Thanks, Eric.
Eric, I didn't think to check the fuse from up top wire access. I will try to figure that out. Also, if all else fails, thanks for the clue on the front panel. I saw those two screws but didn't know if there were more below. Thanks.
  #4 (permalink)
Old 01-14-2014, 07:56 AM
Junior Member
Default Thermal fuse was the culprit!
Eric
Thanks for the info on taking the front panel off. After fiddling around and testing wires, I was somewhat confident that it was the fuse. I confirmed with a quick test after temporarily joining the fuse wiring after it was removed (and hooking the door switch back in). I see some suggest replacing the other fuse (high limit) at the same time. Would you think this wise? Now that I know how to access these fuses ( can just barely reach back there with the front removed), I'm not so worried about having to go back in if the other fuse goes in the future.
Darrell
  #5 (permalink)
Old 01-14-2014, 08:53 AM
Expert
APP Volunteer
Default
The other two devices are the hi-limit thermostat and cycling thermostat. If the timer is advancing normally in auto-dry setting, then I wouldn't worry about replacing either of them. Your dryer does not have a thermal cutoff/fuse in the heater circuit. In dryers that do, it is recommended that if the fuse has blown, you should replace both the fuse and hi-limit thermostat. Your thermal fuse is in the motor circuit.
Eric
  #6 (permalink)
Old 01-14-2014, 09:23 AM
Junior Member
Default
Thanks for the follow up. I have ordered the thermal fuse and look forward to getting everything back together. I appreciate your helpful advice and timely replies. I'm sure that you have saved a lot of appliances from the junkyard.
Darrell
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Access to Thermal Fuse cbayly59 Dryer Repair 0 01-21-2012 11:35 AM
Access to Whirpool DW Thermal Fuse elmo123 Dishwasher Repair 5 12-11-2011 06:26 AM
Access to thermal fuse charliealec Dryer Repair 0 07-07-2010 03:29 PM
Gaining Access to thermal fuse jloprete Dryer Repair 0 07-06-2010 03:11 PM
Access To Burner/thermal Fuse Gordy C Dryer Repair 2 02-23-2008 07:17 PM
