Discuss
Dryer not getting as hot as it used too
 in
Dryer Repair
The basic problem is that the dryer is not getting as hot as it used to (even on the highest
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer not getting as hot as it used too
  #1 (permalink)
Old 01-12-2014, 07:34 AM
Junior Member
drabeck11 is on a distinguished road
Default Dryer not getting as hot as it used too
Model Number: 110.74994300   Brand: Whirlpool   Age: 5 - 10 years
The basic problem is that the dryer is not getting as hot as it used to (even on the highest setting). The clothes used to come out very hot to the touch but now it take a long time to dry. The dryer works fine other than that.
First off, it is not a link blockage problem. I completely dismantled the dryer and cleaned everything. The exhaust run to the outside is about 2 feet and that is clear, also, internal ducting and piping inside the dryer is clear and the lint screen is also clean and clear.
Here is what I am observing of the operation of the dryer as far as the temperature cycling. I am measuring the exhaust temperature with a thermometer (ran with an empty dryer). On the HIGH temperature setting the exhaust temperature climbs up to 160-170F and then the burner turned off. So Far so good. As the exhaust temperature cools I hear a click at about 140F but nothing happens. Then at about 110F another click and then the ignitor warms up and the burner lights. So the temperature over the cycle goes between 160F and 110F. According to the tech sheet that came with the dryer, the ignitor should come back on when the temperature drops 10-15F below the heat turn off temperature (in this case 160F). It is this wide temperature swing between the burning on and off that I believe is causing the low temperature.
I also measured the temperature cycle on all the other settings with similar findings:
Med High Temp : Burner off 150F, Click at 130F but nothing else, Click at 110F Ignitor lights and burner starts
Med Temp : Burner off 140F, Click at 130F but nothing else, Click at 110F Ignitor lights and burner starts
Low Temp : Burner off 120F, Click at 90-100F Ignitor lights and burner starts
So here is what I have done and what I have replaced so far but nothing has fixed this issue.
Replaced the thermistor (part 8577274)
Replaced the Coils (Part #694540/694539)
Replaced the controller board (part W10116565)
Tested the High Limit (205F) Thermostat and it is fine. Thermostat has a closed circuit (no resistance) until ~ 205F and above this it is an open circuit (very high resistance). Also ran a test where I bypassed the High Limit Thermostat and operated the dryer but still had same problem.
Swapped the Heater relay with the Motor relay (no difference in dryer operation)
Put the dryer into Diagnostic test mode and got a beep upon all the input changes.
Tested Thermal fuse and it is fine.
I haven't tested the resistance of the Ignitor since it seems to be operating properly, but could it be that there is some type of thermal recovery of the Ignitor (or the ignitor is close to failure) that it cannot re-turn on until it has cooled sufficiently and that is why the temperature cycles down to 110F before re-ignition in the test I preformed with and empty dryer?
Any other tests or suggestion of what may be causing this problem of low average dyer temperature? Thanks for any help or feedback.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 01-12-2014, 09:16 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Probably the flame sensor. This is on the burner right next to the ignitor. When the ignitor gets hot, the flame sensor opens allowing the secondary gas valve to open and the gas ignites. The ignitor cannot operate until the flame sensor closes again. Seems like it is taking too long for it to close.
Whirlpool 338906 Flame Sensor - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 01-12-2014, 09:23 AM
Junior Member
Default
Eric,
Thanks for the info. Will try replacing the flame sensor and see if it fixes the issue. Will Post back the results when done. Thanks again.
  #4 (permalink)
Old 01-14-2014, 04:25 PM
Junior Member
Default
Ok, Replaced the flame sensor but still have the same problem. The dryer heats to 160F and then the flame turns off. The dryer starts to cool and at around a 140F I hear a click but nothing happens. Then at about 110F I hear a louder click and the ignitor comes on and the flame then lights.
Any more ideas of what could be causing this issue??
  #5 (permalink)
Old 01-14-2014, 05:29 PM
Expert
APP Volunteer
Default
I assume the loud click you hear at 110 is the heat relay. If so, and ignitor comes on right after that and soon after that, burner lights, it appears the ignitor is working fine. The other click you hear at 140 is likely the flame sensor closing. Seems like the thermistor is not sensing properly. You replaced that, so only other thing is an airflow issue. Did you take the blower wheel off and check inside the blower housing under where the thermistor is mounted?
Eric
  #6 (permalink)
Old 01-14-2014, 06:44 PM
Junior Member
Default
Eric,
I removed the housing around the blower and the housing is completely clean and I can see the thermistor. So that doesn't seem to be and issue. I also measured the resistance of the ignitor and it is 66 ohms so that seems ok.
The only other thing I have also checked was the temperature selector switch. From the different temperature cycling study above that seems to be working properly. However the tech sheet says that for the Med High setting the contacts on the switch should have contacts 3-5 open, contacts 2-4 should be closed and contacts 1-4 should be closed. When I measure it I get contact 3-5 open (as it should be), contacts 2-4 open (not as it should be) and contacts 1-4 closed (as it should be). However when I measure contact 2-5 that is closed. My guess is that the manual is wrong and they should have said contact 2-5 instead of contact 2-4. The reason I believe this is on the medium temp setting they also state that contact 2-4 should be closed and I measure 2-4 open but 2-5 closed.
I really don't think this switch is the issue as for the High temp setting the switch has the correct settings and the temperature rises to the correct level. The temperature just doesn't seem to cycle on fast enough.
Do you have any other ideas of what I should try. Thanks for the help so far.
  #7 (permalink)
Old 01-14-2014, 07:22 PM
Expert
APP Volunteer
Default
Iv'e run out of ideas. Maybe someone else here can offer something.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
