| » dyer door closed but light stays on and dryer willnot run |
Replacement parts for WHIRLPOOL LER5620KQ1 | AppliancePartsPros.com Here is the wiring diagram http://www.servicematters.com/docs/w...%208528187.pdf Could be just the door switch actuator needs adjusting so the door closes the switch. Just bend it, but be as gentle as you can you do not want to break it. Could also be the switch is toast.
__________________
| Display Modes | |
| Oven light does not go out when door closed | neurorad | Oven Repair (including Ranges and Cooktops) | 0 | 02-13-2010 12:43 PM |
| GE OTR light/fan remain on constant w/door closed | mlclark67 | Microwave Repair | 1 | 10-28-2009 02:38 PM |
| Microwave light stays on top door latch broken | HollyB | Garbage Disposer Repair | 0 | 09-16-2009 12:29 PM |
| Microwave Stays Partially On When Door Is Closed | eber91 | Microwave Repair | 0 | 04-30-2009 02:08 PM |
| My oven door won't stay shut and the light stays on. The door is loose. | Vanise | Oven Repair (including Ranges and Cooktops) | 2 | 03-24-2008 11:36 AM |
