jbmilkman
#1 Posted : Saturday, January 11, 2014 8:12:53 AM(UTC)
jbmilkman
please help me out! we have a dryer not heating, i have found the timer control is not shutting off the dryer also, and we have no heat. could the timer be my problem or are there more to all of this
fairbank56
#2 Posted : Saturday, January 11, 2014 9:41:31 AM(UTC)
fairbank56
Groups: Expert
Timer will not advance in auto-dry with no heat. Does the timer advance when in timed dry?
Eric
jbmilkman
#3 Posted : Saturday, January 11, 2014 10:24:53 AM(UTC)
jbmilkman
yes the timer is working when set on timed setting
fairbank56
#4 Posted : Saturday, January 11, 2014 10:59:27 AM(UTC)
fairbank56
Groups: Expert
Do you have a multimeter and experience using it? Are you willing to take part of the dryer apart as you need to observe whats going on with the gas burner and check some things with the multimeter. If you have zero experience at this, you might just as well call a tech.
Eric
jbmilkman
#5 Posted : Saturday, January 11, 2014 11:35:42 AM(UTC)
jbmilkman
well i tore the thing apart vacuumed out the inside and tore apart the blower to clean it . put it back an still no heat . i have little experience with a meter . i was hoping not to call a tec. bummer!!!
jbmilkman
#6 Posted : Saturday, January 11, 2014 11:56:59 AM(UTC)
jbmilkman
by any chance do you think i need a gas valve coil kit
fairbank56
#7 Posted : Saturday, January 11, 2014 12:18:41 PM(UTC)
fairbank56
Groups: Expert
With front panel off, hold the door switch and turn the dryer on. You should be able to see the glow of the igniter in the heater enclosure. If you see it glowing but your getting no gas, then it's possible that one of the coils is bad. If ignitor is glowing, you should then hear the radiant sensor click off, at which point the secondary gas valve should open and the gas should ignite. If you don't see the igniter glowing, then your not getting power to it or it's bad or the radiant sensor is bad. No power could be caused by any number of things such as bad timer, temp switch, cycling thermostat, hi-limit thermostat, motor switch...etc. You can either troubleshoot with multimeter and find the bad component or just throw parts at til it's fixed. I'm a troubleshooter but it's usually a lost cause trying to explain to a total rookie how to do it unless you at least have some experience.
Eric
jbmilkman
#8 Posted : Saturday, January 11, 2014 12:25:36 PM(UTC)
jbmilkman
ok its worth a try thanks for all the help ! Im diving in again!!
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
