Discuss
timer doesn't advance in Auto Dry Regular mode
 in
Dryer Repair
The timer dial doesn't advance when dyer is in the Auto Dry regular mode. This is the mode we use
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » timer doesn't advance in Auto Dry Regular mode
  #1 (permalink)
Old 01-10-2014, 02:43 PM
Junior Member
Jake53 is on a distinguished road
Default timer doesn't advance in Auto Dry Regular mode
Model Number: MDG69316AWW   Brand: Maytag   Age: 5 - 10 years
The timer dial doesn't advance when dyer is in the Auto Dry regular mode. This is the mode we use mostly. The heat seems normal in the dyer. Auto Dry regular does dry the clothes but timer doesn't advance to shut off. The other three modes on the timer function normally and advance to shut off. Thank You for your time and advice.
Related Models
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
Maytag MDG9606BWQ DRYER- GAS
Maytag MDG9606BWW DRYER- GAS
Maytag MDG9700AWM DRYER- GAS
Maytag MDG9700AWW DRYER- GAS
Maytag MDG9706AWA DRYER- GAS
Maytag MDG9706AWW DRYER- GAS
Maytag MDG9766AWW DRYER- GAS
Maytag MDG9766AXW DRYER- GAS
Maytag MDG9800AWQ DRYER- GAS
Maytag MDG9800AWW DRYER- GAS
Maytag MDG9806AWA DRYER- GAS
Maytag MDG9806AWW DRYER- GAS
Maytag MDG9876AWW DRYER- GAS
Maytag MDGT236AWW DRYER- GAS
Maytag MDGT336AWW DRYER- GAS
Maytag MDGT446AWW DRYER- GAS
Frigidaire MDH13TN2
Frigidaire MDH13TN3
Frigidaire MDH15FN1
Frigidaire MDH15TF1 Frg(v1) / Dehumidifier
  #2 (permalink)
Old 01-10-2014, 03:58 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Recheck that model number, doesn't come up.
Eric
  #3 (permalink)
Old 01-11-2014, 06:55 AM
Junior Member
Default
Eric, sorry my mistake. Model MDG9316AWW. Thank You.
  #4 (permalink)
Old 01-11-2014, 08:08 AM
Expert
APP Volunteer
Default
This is most likely due to a restriction in the venting system, either inside the dryer or the outside exhaust ducting. In order for the timer to advance in auto-dry, the operating thermostat must cycle on/off. When on, the burner is on and you have heat but timer does not advance. As air temp rises, the thermostat cycles off, burner goes off, timer advances while burner is off, dryer cools, thermostat comes back on to light burner and timer stops advancing. Restrictions in the venting will not allow hot air to get to the thermostat which is located on the blower housing. The burner may still be cycling on/off due to the hi-limit thermostat. You will need to take the dryer apart, including blower housing to inspect for lint buildup. If everything is clear, you may have a faulty operating thermostat or a faulty hi-limit thermostat. Only way to tell would be to take some live line voltage checks while dryer is running.
Eric
  #5 (permalink)
Old 01-12-2014, 07:22 AM
Junior Member
Default
Eric, Wow!! great answer. I will make sure all duct work is clear. In the meantime, since I have a tester, can you explain how to test each thermostat and what readings I am looking for? Thanks a million.
jake53
  #6 (permalink)
Old 01-15-2014, 11:36 AM
Junior Member
Default
Quote:
Eric
Eric, I have changed the thermostat on the blower housing, the timer still does not advance. What should be my next move? replace the hi limit thermostat or consider the timer? Thanks, jake 53
  #7 (permalink)
Old 01-15-2014, 01:53 PM
Expert
APP Volunteer
Default
You are testing dryer operation with everything put back together, right? You replaced the thermostat, not the fuse, right? Thermostat has blue, orange, white and purple wires on it. Check voltage at timer terminals. With dryer running in auto-dry and temp set to regular, monitor voltage to ground at timer OR terminal. Should be zero with burner on and 120vac when burner cycles off. If you don't get 120vac when burner cycles off, check at BU terminal. If you have 120vac there, check at temp switch white wire. If you have 120vac at timer BU and temp switch white wire when burner has cycled off, then the it wasn't the cycling thermostat that turned the burner off. Either the hi-limit thermostat did it or the gas coils are failing. This all may be over your head but this requires electrical troubleshooting with meter to pinpoint the problem.
Eric
  #8 (permalink)
Old 01-16-2014, 02:56 PM
Junior Member
Default
Understood...Thank You again Eric. I will let you know of the outcome.
  #9 (permalink)
Old 01-17-2014, 03:02 PM
Junior Member
Default
Hello again Eric. Here is the situation. They dryer now has two new thermostats, cycling and hi-limit. Also, I purchased and installed two new coils. I tested the OR terminal to ground while the dyer and burner were running per your instructions. The reading is 0.38vac or 383mvac. However I can not test while the burner is off because it never shuts off!! I let the dryer run for 15 minutes and the burner never shut off. There is plenty of heat. I also checked the continuity on the thermal fuse, it seems fine. If the timer, in auto mode only, moves when the burner cycles off, I can now understand why the timer is not advancing. Shouldn't the burner have cycled off at least once in that 15 minute period? Anyway...any idea what the problem is? temperature switch? Thanks for all your help, I do really appreciate it. Jake53
  #10 (permalink)
Old 01-17-2014, 03:51 PM
Expert
APP Volunteer
Default
Wouldn't be the temp switch. That actually turns on a heater (resistor) inside the cycling thermostat so that it cycles faster, giving you the medium and low heat function. Check air temp coming out of dryer exhaust (at dryer exit).
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer won't advance in Auto Mode deeonline Dryer Repair 0 09-30-2013 10:41 PM
Amana Dryer Timer Does Not Advance in Auto Mode splehigh Dryer Repair 2 03-11-2013 06:43 PM
GE dryer timer won't advance in auto mode jwysocky Dryer Repair 7 02-25-2010 02:54 PM
Timer does not advance in auto mode rman Dryer Repair 1 06-27-2009 01:39 PM
Timer does not advance in auto dry mode Teager Dryer Repair 8 06-19-2009 04:27 AM
