Discuss
dryer won't run
 in
Dryer Repair
My dryer wouldn't run the other day.I pushed the start button and thought I heard something and that was all.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer won't run
  #1 (permalink)
Old 01-08-2014, 06:00 PM
Junior Member
dymetz62 is on a distinguished road
Default dryer won't run
Model Number: TEDS740PQ0   Brand: Whirlpool   Age: 5 - 10 years
My dryer wouldn't run the other day.I pushed the start button and thought I heard something and that was all. I ordered a new start switch but that didn't solve it.The door switch sounds fine(clicks when pushed down) I watched the video for the thermal fuse;he said the dryer would still run.I read a post on here that said it might not run.what would be my next step.The dryer is in a tight spot so it won't be easy to get inside to the door switch.
Thank-you
Dan
Related Models
 TEDS740PQ0 29"ELECTRIC DRYER
 TEDS740PQ1 29"ELECTRIC DRYER
 TEDS780JQ0 ELECTRIC DRYER
 TEDS840JQ0 DRYER
 TEDS840JQ1 ELECTRIC DRYER
 TEDS840JQ2 DRYER
 TEDS840JQ3 29"ELECTRIC DRYER
 TEDS840PQ0 29"ELECTRIC DRYER
 TEDS840PQ1 29"ELECTRIC DRYER
 TEDX340RW0 29" ELECTRIC DRYER
 TEDX340RW1 29" ELECTRIC DRYER
 TEDX340RW2 29" ELECTRIC DRYER
Whirlpool TEDX540RQ0 29" ELECTRIC DRYER
 TEDX540RQ1 29" ELECTRIC DRYER
 TEDX640EQ0 ELECTRIC DRYER
 TEDX640EQ1 DRYERS
 TEDX640EQ2 ELECTRIC DRYER
 TEDX640JQ0 ELECTRIC DRYER
 TEDX640JQ1 DRYER
 TEDX640JQ2 29"ELECTRIC DRYER
 TEDX640PQ0 29" ELECTRIC DRYER
 TEDX640PQ1 29"ELECTRIC DRYER
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BU4 ELECTRIC RANGE
Tappan TEF242BU5 ELECTRIC RANGE
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF242BW4 ELECTRIC RANGE
Tappan TEF242BW5 ELECTRIC RANGE
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF303BWF RANGE
Tappan TEF303BWG RANGE
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Tappan TEF317BWF ELECTRIC RANGE
Tappan TEF317BWG ELECTRIC RANGE
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FBB ELECTRIC RANGE
Tappan TEF326FBC ELECTRIC RANGE
Tappan TEF326FSA Tappan/range
Tappan TEF326FSB ELECTRIC RANGE
Tappan TEF326FSC ELECTRIC RANGE
Tappan TEF326FSD ELECTRIC RANGE
Tappan TEF326FSE ELECTRIC RANGE
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Tappan TEF351EWD ELECTRIC RANGE
Tappan TEF351EWE ELECTRIC RANGE
Tappan TEF351EWF ELECTRIC RANGE
Tappan TEF351EWG ELECTRIC RANGE
Tappan TEF351EWH ELECTRIC RANGE
Tappan TEF351EWJ TAPPAN/ELECTRIC RANGE
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
  #2 (permalink)
Old 01-08-2014, 06:42 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The dryer will not run if the thermal fuse is bad. Check continuity on that and on the door switch. The dryer has a thermal fuse and a thermal cutoff. The thermal fuse is in the motor circuit, thermal cutoff is in the heater circuit.
Eric
  #3 (permalink)
Old 01-11-2014, 08:28 PM
Junior Member
Thumbs up dryer won't run
thanks,
As soon as I saw the thermal fuse; I knew it was burn't
thamks for the help
DAN
  #4 (permalink)
Old 01-11-2014, 08:29 PM
Junior Member
thanks,
thanks for the help
DAN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
