Discuss
help
 in
Dryer Repair
my dryer will not shut off the drum spins continually the only way to stop it is to turn the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » help
  #1 (permalink)
Old 01-06-2014, 05:26 PM
Junior Member
mtnmanst is on a distinguished road
Default help
Model Number: se1000   Brand: Maytag   Age: More than 10 years
my dryer will not shut off the drum spins continually the only way to stop it is to turn the beaker off and when u turn the beaker on the drum spins even when the door is open and no heat can you help.
Related Models
Maytag SE1000 STACKED LAUNDRY- ELE
Maytag SE1000T Stacked Laundry - Ele
Maytag SE7800 STACKED LAUNDRY- ELE
Whirlpool SE950PEKW0 Range (gas)*
Whirlpool SE950PEKW1 Range (gas)*
Whirlpool SE950PEPW0 Range (gas)*
Whirlpool SE950PERW0 Range (gas)*
Whirlpool SE950PERW1 Range (gas)*
Whirlpool SE950PERW2 Range (gas)*
Whirlpool SE950PERW3 Range (gas)*
Whirlpool SE950PERW4 Range (gas)*
Whirlpool SE950PERW5 Range (gas)*
Whirlpool SE950PERW6 GAS RANGE
Whirlpool SE950PERW7 Range (gas)*
Whirlpool SE950PERW8 Range (gas)*
Whirlpool SE950PERW9 GAS RANGE
Whirlpool SE950PSKW0 Range (gas)*
Whirlpool SE950PSKW1 Range (gas)*
Whirlpool SE950PSPW0 Range (gas)*
Whirlpool SE953PEKT0 Range (gas)*
Whirlpool SE953PEKT1 Range (gas)*
Whirlpool SE953PSKT0 Range (gas)*
Whirlpool SE953PSKT1 Range (gas)*
Whirlpool SE960PEPW0 Range (gas)*
Whirlpool SE960PEPW1 Range (gas)*
Whirlpool SE960PEPW2 Range (gas)*
Whirlpool SE960PEPW3 Range (gas)*
Whirlpool SE960PEPW4 Range (gas)*
Whirlpool SE960PEPW5 Range (gas)*
Whirlpool SE960PEPW6 Range (gas)*
Whirlpool SE960PEYN3 Range (gas)*
Whirlpool SE960PEYW0 Range (gas)*
Whirlpool SE960PEYW1 Range (gas)*
Whirlpool SE960PEYW2 Range (gas)*
Whirlpool SE960PEYW3 Range (gas)*
Maytag SE9900 STACKED LAUNDRY- ELE
Roper SEC350XW0 Ranges, Electric*
Roper SEC350XX1 30" ELECTRIC RANGE CONTINUOUS CLEAN OVEN
Whirlpool SEDS800HQ0 ELECTRIC DRYER
Whirlpool SEDS800JQ0 DRYER
Whirlpool SEDS800JQ1 DRYER
Whirlpool SEDS800MQ0 29"ELECTRIC DRYER
Whirlpool SEDS800MQ1 29"ELECTRIC DRYER
Whirlpool SEDX600HQ0 ELECTRIC DRYER
Whirlpool SEDX600JQ0 ELECTRIC DRYER
Whirlpool SEDX600JQ1 ELECTRIC DRYER
Whirlpool SEDX600MQ0 29"ELECTRIC DRYER
Whirlpool SEDX600MQ1 29"ELECTRIC DRYER
Amana SEFS65D COMMERCIAL MICROWAVES
Jenn-Air SEG196 RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SEG196-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SEG196W RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SEG196W-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Roper SEP340XX0 Ranges, Electric*
Whirlpool SEP340XX1 30" ELECTRIC RANGE STANDARD CLEAN OVEN
 SEQ7000FS0 DRYER
White Westinghouse SER341AQ0 Dryer - W.west
White Westinghouse SER341AQ1 Dryer - West/grupo Gomo
White Westinghouse SER341AQ2 White Westinghouse/electric Dryer
White Westinghouse SER341AS0 Dryer - W.west
White Westinghouse SER341AS1 Dryer - West/grupo Gomo
White Westinghouse SER341AS2 White Westinghouse/electric Dryer
General Electric SES0730DM1BB MICROWAVE
General Electric SES0730DM1WW MICROWAVE
General Electric SES0732DN1BB MICROWAVE
General Electric SES0732DN1WW MICROWAVE
General Electric SES0732DN2BB MICROWAVE
General Electric SES0732DN2WW MICROWAVE
Roper SES370XX0 ELECTRIC RANGE
Whirlpool SES374HQ0 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool SES374HQ1 ELECTRIC RANGE
Whirlpool SES380MS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool SF0100EKW0 Range (gas)*
Whirlpool SF0100EKW1 Range (gas)*
Whirlpool SF0100EKW2
Whirlpool SF0100ERW0 Range (gas)*
Whirlpool SF0100ERW1 Range (gas)*
Whirlpool SF0100ERW2 Range (gas)*
Whirlpool SF0100ERW3 Range (gas)*
Whirlpool SF0100ERW4 Range (gas)*
Whirlpool SF0100ERW5 Range (gas)*
Whirlpool SF0100ERW6 Range (gas)*
Whirlpool SF0100ERW7 Range (gas)*
Whirlpool SF0100ERW8 Range (gas)*
Whirlpool SF0100SKW0 Range (gas)*
Whirlpool SF0100SKW1 Range (gas)*
Whirlpool SF0100SRW0 Range (gas)*
Whirlpool SF0100SRW1 Range (gas)*
Whirlpool SF0100SRW2 Range (gas)*
Whirlpool SF0100SRW3 Range (gas)*
Whirlpool SF0100SRW4 Range (gas)*
Whirlpool SF0100SRW5 Range (gas)*
Whirlpool SF0100SRW6 Range (gas)*
Whirlpool SF0100SRW7 Range (gas)*
Whirlpool SF0100SRW8 Range (gas)*
Whirlpool SF0100SRW9 Range (gas)*
Whirlpool SF0100SYW0 Range (gas)*
Whirlpool SF0105EPW0 Range (gas)*
Whirlpool SF0105SPW0 Range (gas)*
Whirlpool SF010EERW0 Range (gas)*
Whirlpool SF010EERW1 Range (gas)*
Whirlpool SF010EERW2 Range (gas)*
Whirlpool SF010ESPW0 Range (gas)*
Whirlpool SF010ESRW0 Range (gas)*
Whirlpool SF010ESRW1 Range (gas)*
Whirlpool SF010ESRW2 Range (gas)*
Whirlpool SF0140SRW0 Range (gas)*
Whirlpool SF0140SRW1 Range (gas)*
Whirlpool SF0140SRW2 Range (gas)*
Whirlpool SF0140SRW3 Range (gas)*
Whirlpool SF0140SRW4 Range (gas)*
Whirlpool SF0140SRW5 Range (gas)*
Whirlpool SF0140SRW6 Range (gas)*
Whirlpool SF110AXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF110AXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF110AXSQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
  #2 (permalink)
Old 01-07-2014, 02:57 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for SE1000 - AppliancePartsPros.com
Here is a service manual
http://appliancejunk.com/forums/inde...t=138 9087162
You will have to join the site and be logged in to download the manual.
I would start by looking at the motor relay.
Unplug the unit and check across the relay contacts with a meter.
If they are 0 ohms then the relay contacts are welded together.
If open (infinite ohms) then odds are that the control board is bad.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 01-07-2014, 08:26 AM
Junior Member
Default
That was the conclusion that I came to about15 minutes after I posted ty for the help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
