Discuss
Heat does not come on sometimes
 in
Dryer Repair
Recently replaced the igniter after it burned up. Now sometimes the fire does not come on when starting a load
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heat does not come on sometimes
  #1 (permalink)
Old 01-05-2014, 09:48 AM
Junior Member
KaupSusan is on a distinguished road
Default Heat does not come on sometimes
Model Number: LGR4634JQ2   Brand: Whirlpool   Age: 5 - 10 years
Recently replaced the igniter after it burned up. Now sometimes the fire does not come on when starting a load to dry. Does it in both automatic and times mode. Thanks for your ideas.
Related Models
Whirlpool LGR4634JQ2 GAS DRYER
Whirlpool LGR4634JQ3 29" GAS DRYER
Whirlpool LGR4634JT0 GAS DRYER
Whirlpool LGR4634JT1 GAS DRYER
Whirlpool LGR4634JT2 GAS DRYER
Whirlpool LGR4634JT3 29" GAS DRYER
Whirlpool LGR4634JZ0 GAS DRYER
Whirlpool LGR4634JZ1 GAS DRYER
Whirlpool LGR4634PQ0 29" GAS DRYER
Whirlpool LGR4634PQ1 29" GAS DRYER
Whirlpool LGR4634PT0 29" GAS DRYER
Whirlpool LGR4634PT1 29" GAS DRYER
Whirlpool LGR5434AW0 Residential Dryer
Whirlpool LGR5600HQ0 GAS DRYER
Whirlpool LGR5600HZ0 GAS DRYER
Whirlpool LGR5600JQ0 GAS DRYER
Whirlpool LGR5600JQ1 RESIDENTIAL DRYER
Whirlpool LGR5600JT0 GAS DRYER
Whirlpool LGR5600JT1 RESIDENTIAL DRYER
Whirlpool LGR5620KQ0 RESIDENTIAL DRYER
Whirlpool LGR5620KQ1 GAS DRYER
Whirlpool LGR5620KQ2 29"GAS DRYER
Whirlpool LGR5624BN0 GAS DRYER
Whirlpool LGR5624BN1 GAS DRYER
Whirlpool LGR5624BN2 GAS DRYER
Whirlpool LGR5624BW0 GAS DRYER
Whirlpool LGR5624BW1 GAS DRYER
Whirlpool LGR5624BW2 GAS DRYER
Whirlpool LGR5624DQ0 DRYERS
Whirlpool LGR5624DQ1 DRYER
Whirlpool LGR5624DW1 DRYER
Whirlpool LGR5624DZ0 DRYERS
Whirlpool LGR5624DZ1 DRYER
Whirlpool LGR5634AN0 GAS DRYER
Whirlpool LGR5634AQ0 GAS DRYER
Whirlpool LGR5634AQ1 GAS DRYER
Whirlpool LGR5634AQ2 GAS DRYER
Whirlpool LGR5634AW0 Residential Dryer
Whirlpool LGR5634DQ1 DRYER
Whirlpool LGR5634EQ0 GAS DRYER
Whirlpool LGR5634EZ0 GAS DRYER
Whirlpool LGR5634LQ0 RESIDENTIAL DRYER
Whirlpool LGR5635LQ0 29"GAS DRYER
Whirlpool LGR5635LQ1 29"GAS DRYER
Whirlpool LGR5636DW0 DRYER
Whirlpool LGR5636DW1 DRYER
Whirlpool LGR5636EQ0 DRYER
Whirlpool LGR5636EQ1 DRYER
Whirlpool LGR5636EQ2 DRYER
Whirlpool LGR5636EQ3 DRYER
Whirlpool LGR5636EZ0 DRYER
Whirlpool LGR5636EZ1 DRYER
Whirlpool LGR5636EZ2 DRYER
Whirlpool LGR5636EZ3 DRYER
Whirlpool LGR5636JQ0 DRYER
Whirlpool LGR5636JQ1 DRYER
Whirlpool LGR5636JT0 DRYER
Whirlpool LGR5636JT1 DRYER
Whirlpool LGR5636KQ0 DRYER
Whirlpool LGR5636KQ1 DRYER
Whirlpool LGR5636KT0 DRYER
Whirlpool LGR5636KT1 DRYER
Whirlpool LGR5636LG0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ1 29"GAS DRYER
Whirlpool LGR5636LT0 RESIDENTIAL DRYER
Whirlpool LGR5636LT1 29"GAS DRYER
Whirlpool LGR5636LW0 RESIDENTIAL DRYER
Whirlpool LGR5636PQ0 29"GAS DRYER
Whirlpool LGR5636PQ1 29"GAS DRYER
Whirlpool LGR5636PT0 29"GAS DRYER
Whirlpool LGR5636PT1 29"GAS DRYER
Whirlpool LGR5638AN1 GAS DRYER
Whirlpool LGR5638AN2 GAS DRYER
Whirlpool LGR5638AN3 GAS DRYER
Whirlpool LGR5638AW0 Residential Dryer
Whirlpool LGR5638AW1 GAS DRYER
Whirlpool LGR5638AW2 GAS DRYER
Whirlpool LGR5638AW3 GAS DRYER
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2 GAS DRYER
Whirlpool LGR5644AW0 Residential Dryer
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2 GAS DRYER
Whirlpool LGR5644EQ0 GAS DRYER
Whirlpool LGR5644EQ1 DRYERS
Whirlpool LGR5644EQ2 GAS DRYER
Whirlpool LGR5644EQ3 GAS DRYER
Whirlpool LGR5644EZ0 GAS DRYER
Whirlpool LGR5644EZ1 DRYERS
Whirlpool LGR5644EZ2 GAS DRYER
Whirlpool LGR5644EZ3 GAS DRYER
Whirlpool LGR5644JQ0 GAS DRYER
Whirlpool LGR5644JQ1 RESIDENTIAL DRYER
Whirlpool LGR5644JQ2 GAS DRYER
Whirlpool LGR5644JQ3 29" GAS DRYER
Whirlpool LGR5644JT0 GAS DRYER
Whirlpool LGR5644JT1 RESIDENTIAL DRYER
Whirlpool LGR5644JT2 GAS DRYER
Whirlpool LGR5644JT3 29" GAS DRYER
Whirlpool LGR5644PQ0 29" GAS DRYER
Whirlpool LGR5644PQ1 29" GAS DRYER
Whirlpool LGR5700KQ0 DRYER
Whirlpool LGR5700KQ1 DRYER
Whirlpool LGR5700KT0 DRYER
Whirlpool LGR5700KT1 DRYER
Whirlpool LGR5848EQ0 GAS DRYER
Whirlpool LGR5848EQ1 GAS DRYER
Whirlpool LGR5848EQ2 GAS DRYER
Whirlpool LGR5848EQ3 DRYERS
Whirlpool LGR5848EQ4 DRYERS
Whirlpool LGR5848EQ5 GAS DRYER
Whirlpool LGR5848EQ6 GAS DRYER
Whirlpool LGR6611LQ0 RESIDENTIAL DRYER
Whirlpool LGR6611LQ1 29"GAS DRYER
Whirlpool LGR6611PQ0 29" GAS DRYER
Whirlpool LGR6620PQ0 29"GAS DRYER
Whirlpool LGR6620PQ1 29"GAS DRYER
Whirlpool LGR6620PT0 29"GAS DRYER
Whirlpool LGR6620PT1 29"GAS DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave will not heat anymore. Everything works but the heat and turntable dont. Rumpylee Microwave Repair 0 12-08-2013 01:10 AM
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 12:23 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 06:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 03:23 PM
No High Heat, Medium heat work fine! Scubadude Dryer Repair 0 09-07-2010 06:39 PM
