AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Help! Checked everything but can't figure out why Dryer won't heat!
Ok. I haven't seen a solution to this problem. Perhaps you can help!
This dryer used to work fine but something has failed and now it takes about 3 cycles to dry. The amount of heat coming out the exhaust doesn't seem very warm/hot. The airflow volume is good. The flame fires up and seems to work fine. I come back to check 20, 30, 45 minutes later and the flame is always on but the clothes still do not dry.
I have vacuumed all lint from the back out so airflow is good and I replaced the solenoids but no improvement. It seems like the solution should be to turn a dial and increase the flame size but I doubt that's a possibility. Could I have a restricted gas flow?
Let me know what you think! Thanks!
Dryer Repair
