Discuss
Dryer cyles, no heat, trips circuit breaker leg
 in
Dryer Repair
My Estate dryer recently stopped drying. The drum tumbles, but no heat. Timer also doesn't work. Below is what I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer cyles, no heat, trips circuit breaker leg
  #1 (permalink)
Old 01-01-2014, 05:07 PM
Junior Member
kwillie is on a distinguished road
Default Dryer cyles, no heat, trips circuit breaker leg
Model Number: TEDS840JQ2   Brand: Whirlpool   Age: 5 - 10 years
My Estate dryer recently stopped drying. The drum tumbles, but no heat. Timer also doesn't work. Below is what I tested and replaced:
1. All three thermostats, heating element and fuse have continuity
2. Timer (3979617) had an open circuit between BK and R terminals. I replaced with a new one. Timer still doesn't work, no heat, and one leg on the house circuit breaker continues to trip when I turn on the dryer. Also, can you tell me what the T vs TM terminals on the timer represent? My dryer had a brown timer wire connected to the T terminal. The replacement timer and videos I have watched, have the wire connected to the TM terminal.
3. Could the High/Med/Low temperature switch cause the problem?
4. It seems something in the dryer is shorting out and causing the house circuit breaker to trip and not provide the power to the timer circuit and/or other circuitry.
any recommendations?
Thanks,
Kent W.
Related Models
 TEDS840JQ2 DRYER
 TEDS840JQ3 29"ELECTRIC DRYER
 TEDS840PQ0 29"ELECTRIC DRYER
 TEDS840PQ1 29"ELECTRIC DRYER
 TEDX340RW0 29" ELECTRIC DRYER
 TEDX340RW1 29" ELECTRIC DRYER
 TEDX340RW2 29" ELECTRIC DRYER
Whirlpool TEDX540RQ0 29" ELECTRIC DRYER
 TEDX540RQ1 29" ELECTRIC DRYER
 TEDX640EQ0 ELECTRIC DRYER
 TEDX640EQ1 DRYERS
 TEDX640EQ2 ELECTRIC DRYER
 TEDX640JQ0 ELECTRIC DRYER
 TEDX640JQ1 DRYER
 TEDX640JQ2 29"ELECTRIC DRYER
 TEDX640PQ0 29" ELECTRIC DRYER
 TEDX640PQ1 29"ELECTRIC DRYER
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BU4 ELECTRIC RANGE
Tappan TEF242BU5 ELECTRIC RANGE
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF242BW4 ELECTRIC RANGE
Tappan TEF242BW5 ELECTRIC RANGE
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF303BWF RANGE
Tappan TEF303BWG RANGE
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Tappan TEF317BWF ELECTRIC RANGE
Tappan TEF317BWG ELECTRIC RANGE
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FBB ELECTRIC RANGE
Tappan TEF326FBC ELECTRIC RANGE
Tappan TEF326FSA Tappan/range
Tappan TEF326FSB ELECTRIC RANGE
Tappan TEF326FSC ELECTRIC RANGE
Tappan TEF326FSD ELECTRIC RANGE
Tappan TEF326FSE ELECTRIC RANGE
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Tappan TEF351EWD ELECTRIC RANGE
Tappan TEF351EWE ELECTRIC RANGE
Tappan TEF351EWF ELECTRIC RANGE
Tappan TEF351EWG ELECTRIC RANGE
Tappan TEF351EWH ELECTRIC RANGE
Tappan TEF351EWJ TAPPAN/ELECTRIC RANGE
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
  #2 (permalink)
Old 01-01-2014, 08:22 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
There are two brown wires coming off the timer motor. One should go to the BU terminal and the other to the TM terminal. Doesn't matter which is which. The T terminal should have a tan wire from the wire harness. You need to check for a ground on the L-2 heater circuit. L-2 is red wire from power cord connection block to motor connector, through motor switch when motor is running, to heater coil. Timer isn't running because you have no L-2 when breaker trips. May be heater coil is grounding out. Temp switch is not the problem. Timer terminal designations are wire colors (T for tan, W for white, BU for blue...etc.), TM means Timer Motor.
Eric
  #3 (permalink)
Old 01-02-2014, 04:32 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
See the attachment for the wiring diagram.
Does the timer advance in timed dry?
Perhaps try setting the unit to air only and timed dry mid cycle.
Does the breaker still trip?
if not does the timer advance? It should as it is connected directly across the 240 volts (L1 to L2).
Note: this timer runs off of the 240 volts.
As fairbank56 said it could be a grounded heating element.
Unplug the unit and both wires to the heating element.
Measure across the heating element, should be around 8 to 12 ohms.
Then measure from each side of the element to the heater case.
Both should be infinite ohms, if not the heater is grounded and needs replacing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer trips circuit breaker for heat yoshica Dryer Repair 5 08-11-2013 08:27 AM
Elec. Dryer Trips Circuit Breaker MacKenrick Dryer Repair 5 08-10-2012 10:38 AM
Dryer trips circuit breaker after 15min David H Dryer Repair 3 07-21-2010 12:53 PM
Dryer trips heating element circuit breaker omygosch Dryer Repair 0 08-23-2009 11:40 AM
Dryer trips circuit breaker garyr1950 Dryer Repair 2 01-22-2009 05:07 AM
