hi, I have a whirlpool duet dryer. when you turn it on the gas comes on for about 15 seconds and shuts off. I ran a diagnostic test and it displays an E3 error code. I tried way too many thing and am very frustrated, hopefully someone can help me out. fortunately my old dryer has many compatible parts, but I replaced the thermal fuse, the thermistor, the high temp thermostat, coils, and flame sensor all with the same results. than I opened the top and removed the control panel. the service manual states an E3 code means a wrong part is installed. the control panel I removed is sn 3978918, however it looks like someone has refurbished this or made some changes there is marking on it with a sharpee. Help im at my wits end and ready to use it as a boat achor, if it wasn't so heavy sincerely john
