Discuss
Timer not advancing, but the timer is good.
 in
Dryer Repair
I have an old dryer that I got for free. And when I say old, I mean REALLY old. It's
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Timer not advancing, but the timer is good.
  #1 (permalink)
Old 12-17-2013, 01:42 AM
Junior Member
skylux is on a distinguished road
Default Timer not advancing, but the timer is good.
Model Number: LHI6901N0   Brand: Whirlpool   Age: More than 10 years
I have an old dryer that I got for free. And when I say old, I mean REALLY old. It's so old that the Sears Parts Direct website didn't even list it!! I don't know any of its history. I took EVERY nut and bolt off and COMPLETELY restored it and it is literally as clean as a brand new unit, inside and out. Lubed the pulleys and motor and just really cleaned it up.
I had to replace a gas solenoid but other than that it seems to work perfectly. Except, I noticed that the timer does not seem to advance when using the AUTO cycle. On the TIMED cycle, it does advance correctly so the timer is not bad. I put my volt meter on the timer and it does get 115 volts in the TIMED cycle. But here's the weird part, in the AUTO cycle, my meter read only 94 volts AC. Huh?? I have heard that some units have a large resistor that power gets shunted to. Mine does not have this anywhere behind the control panel so I dont think thats the culprit. So then I thought that there is a thermostat and/or thermal fuse that power has to go through to allow the timer to get voltage. Clearly any fuse can't be blown as no voltage would reach the timer. Why would it only get 94 volts during this cycle? I can hear the timer trying to run but maybe 94 volts isn't enough to juice to actually advance it. I've search all over the internet but can't find this exact problem. Any ideas? I have an ohm and volt meter and very used to testing things so hit me with ideas.
Thanks!!
Related Models
Whirlpool LHI7501W0 Residential Dryer
Whirlpool LHI9801W2 Residential Dryer
Whirlpool LHW0050PQ0 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ1 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ2 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ3 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ4 COMPACT AUTOMATIC WASHER
General Electric LISR310CW0WW Washer
General Electric LISR310CW1WW Washer
Whirlpool LJD1306LQ0
Whirlpool LJD1306LT0
Bosch LK100-010
Bosch LK100-020
Bosch LK100-110
Bosch LK100-120
Bosch LK320-010
Bosch LK320-020
Bosch LK320-030
Bosch LK400-010
Bosch LK400-020
Bosch LK400-030
Amana LKG-170 ROOM AIR CONDITIONER
Amana LKG-171 ROOM AIR CONDITIONER
Amana LKG-240 ROOM AIR CONDITIONER
Amana LKG-240H ROOM AIR CONDITIONER
Amana LKG-241 ROOM AIR CONDITIONER
Amana LKG-241H ROOM AIR CONDITIONER
Amana LKG-300 ROOM AIR CONDITIONER
Amana LKG-300H ROOM AIR CONDITIONER
Amana LKG-340 ROOM AIR CONDITIONER
Amana LKG-340HE ROOM AIR CONDITIONER
Amana LKG-341 ROOM AIR CONDITIONER
Amana LKG-470 ROOM AIR CONDITIONER
Amana LKG-470HE ROOM AIR CONDITIONER
Amana LKG-471 ROOM AIR CONDITIONER
Amana LKG-471HE ROOM AIR CONDITIONER
Amana LKG-621 ROOM AIR CONDITIONER
Amana LKG601-617 ROOM AIR CONDITIONER
Amana LKG601H-617 ROOM AIR CONDITIONER
Amana LKI721 RANGE- F/S STD GAS
Amana LKU-617 RANGE- S/C S/I DDRAFT GAS
Amana LKU-617A RANGE- S/C S/I DDRAFT GAS
Bosch LL010-000
Whirlpool LLC7244AN0
Whirlpool LLC7244AQ0
Whirlpool LLC7244AW0
Whirlpool LLC7244AZ0
Whirlpool LLC7244BQ0
Whirlpool LLC7244BQ1
Whirlpool LLC7244BZ0
Whirlpool LLC7244BZ1
Whirlpool LLC8244DQ0
Whirlpool LLC8244DZ0
Whirlpool LLN8233BN0
Whirlpool LLN8233BN1
Whirlpool LLN8233BQ0
Whirlpool LLN8233BQ1
Whirlpool LLN8233BW0
Whirlpool LLN8233BW1
Whirlpool LLN8244AN0
Whirlpool LLN8244AW0
Whirlpool LLN8244BN0
Whirlpool LLN8244BW0
Admiral LLR1100AJQ RANGE- F/S STD GAS
Admiral LLR1100AJW RANGE- F/S STD GAS
Admiral LLR1415AJS RANGE- F/S STD GAS
Admiral LLR1415AJW RANGE- F/S STD GAS
Admiral LLR4451AJS RANGE- F/S STD GAS
Admiral LLR4451AJW RANGE- F/S STD GAS
Whirlpool LLR5144BQ0
Whirlpool LLR5144BQ1
Whirlpool LLR5144BW0
Whirlpool LLR6144AN0
Whirlpool LLR6144AQ0
Whirlpool LLR6144AW0
Whirlpool LLR6144BN0 WASHER
Whirlpool LLR6144BN1 AUTOMATIC WASHER
Whirlpool LLR6144BQ0 WASHER
Whirlpool LLR6144BQ1 AUTOMATIC WASHER
Whirlpool LLR6144BW0 WASHER
Whirlpool LLR6233AN0
Whirlpool LLR6233AN1
Whirlpool LLR6233AQ0
Whirlpool LLR6233AW0
Whirlpool LLR6233AW1
Whirlpool LLR7144DQ0
Whirlpool LLR7144DW0
Whirlpool LLR7144DZ0
Whirlpool LLR8233BN0 AUTOMATIC WASHER
Whirlpool LLR8233BN1 AUTOMATIC WASHER
Whirlpool LLR8233BQ0 AUTOMATIC WASHER
Whirlpool LLR8233BQ1 AUTOMATIC WASHER
Whirlpool LLR8233BW0 AUTOMATIC WASHER
Whirlpool LLR8233BW1 AUTOMATIC WASHER
Whirlpool LLR8233DQ0 AUTOMATIC WASHER
Whirlpool LLR8233DW0 AUTOMATIC WASHER
Whirlpool LLR8233DZ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ1 DIRECT-DRIVE WASHER
Whirlpool LLR8233EZ0 AUTOMATIC WASHER
Whirlpool LLR8233EZ1 DIRECT-DRIVE WASHER
Whirlpool LLR8245AW0 Washers
Whirlpool LLR8245BN0 AUTOMATIC WASHER
Whirlpool LLR8245BN1 AUTOMATIC WASHER
Whirlpool LLR8245BW0 AUTOMATIC WASHER
Whirlpool LLR8245BW1 AUTOMATIC WASHER
Whirlpool LLR8245DQ0 AUTOMATIC WASHER
Whirlpool LLR8245DZ0 AUTOMATIC WASHER
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
  #2 (permalink)
Old 12-22-2013, 12:46 PM
Junior Member
apphack is on a distinguished road
Default Similar problem with Kenmore
I have a 15-year old Kenmore dryer doing the same thing. There is a timer switch on my model that changes the timer output from a nearly direct connection to neutral (only the door switch intervenes) to a convoluted connection through some of the ignitor components and the flame switch.
As near as I can tell, the purpose of this connection is to make sure the burner has cooled off before advancing the timer. In my case to OFF.
If I run the dryer in Auto (which I never do), it uses the same convoluted connection, presumably to make sure things have cooled off before advancing.
What I can't tell is whether the timer fails to run in this configuration because there is too much downstream resistance (ignitor failing, for example) or because the timer motor is failing. Both the ignitor and the timer motor have resistance within the range called out on my Kenmore schematic.
  #3 (permalink)
Old 12-22-2013, 02:06 PM
Junior Member
Default
Apphack,
You have a different manufacturer and model number. I also dont know if your problem is the same as mine. Therefore, please create your own thread as I'd rather not confuse the issue in my thread as to the problem with my dryer.
  #4 (permalink)
Old 12-25-2013, 08:39 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Post a photo of your wiring diagram.
Eric
  #5 (permalink)
Old 12-25-2013, 11:07 PM
Junior Member
Default
I wish I could. Nowhere on the inside or out is a wiring diagram. I ohm'ed out the three snap-disc thermostats and one gave weird, fluctuating readings so I replaced it. It was the one that opens at 140 and closes back at 120. Unfortunately, replacing it did not have an affect on the timer receiving low voltage during an AUTO cycle. The thermal fuse tested out good as well.
Not sure how to get a wiring diagram. I've searched all over the internet but didn't find one (this unit is ooold). I took pics of the back of the timer wiring, the gas valve assembly (two wire unit, not three) the motor wiring, back of the control panel and back of t-stat area. If posting those would help, let me know and I'll put them up. We may not have a diagram but that would at least show the actual wiring and colors, etc.
I put a lot of time in restoring this thing so the problem is a little frustrating cuz it's the only one of about 5 issues that didn't get resolved. Now all else works as new with it except this. And since this thing is a REALLY simple design with no fancy circuit boards and digital readouts I was sure I'd find the culprit by now. : (
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer, timer good till rinse-no spin,drain orstop/timer keeps clicking freely partsparts Washer Repair 3 08-23-2010 01:50 AM
Timer not advancing Dan71 Dryer Repair 3 10-13-2009 07:01 PM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Timer not advancing suekea Dryer Repair 3 07-27-2008 08:17 AM
Timer not advancing lparicio Dryer Repair 1 02-24-2008 11:51 AM
