Discuss
Testing Continuity on 5 pole thermostat
 in
Dryer Repair
I have reason to believe my thermostat (#131539400) needs replacing. I would like to confirm with continuity check. Since there
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Testing Continuity on 5 pole thermostat
  #1 (permalink)
Old 12-12-2013, 06:36 AM
Junior Member
embimp is on a distinguished road
Default Testing Continuity on 5 pole thermostat
Model Number: 131539400   Brand: Frigidaire   Age: More than 10 years
I have reason to believe my thermostat (#131539400) needs replacing. I would like to confirm with continuity check. Since there are five leads, I'm not sure which to check.
Related Models
Roper 1315W0A Range (gas)*
Roper 1315W1A Range (gas)*
Roper 1315W2A Range (gas)*
Amana 1325.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1325.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1325.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1325.004 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1330
Amana 1330.001 MWAVE - FAMILY SIZE (60 HZ)
Roper 1333*0A GAS RANGE
Roper 1333*1A GAS RANGE
Roper 1333W0A GAS RANGE
Roper 1335*0A GAS RANGE
Roper 1335*1A GAS RANGE
Roper 1335*3A GAS RANGE
Amana 1335.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 1335W3A GAS RANGE
Hoover 1340
Amana 1340.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1341.002 MWAVE - FAMILY SIZE (60 HZ)
Roper 1346*0A GAS RANGE
Roper 1346W0A GAS RANGE
Roper 1347*0A GAS RANGE
Roper 1347W0A GAS RANGE
Hoover 1348
Hoover 1348-002
Roper 1352W06 Range (gas)*
Roper 1353*0A GAS RANGE
Roper 1353*1A GAS RANGE
Roper 1353*2A GAS RANGE
Roper 1353*3A Range (gas)*
Roper 1353*4A Range (gas)*
Roper 1353W0A GAS RANGE
Roper 1353W1A GAS RANGE
Roper 1353W2A GAS RANGE
Roper 1353W4A Range (gas)*
Roper 1355*0A GAS RANGE
Roper 1355*1A GAS RANGE
Roper 1355*2A GAS RANGE
Roper 1355*3A Range (gas)*
Roper 1355W0A GAS RANGE
Roper 1355W1A GAS RANGE
Roper 1355W2A GAS RANGE
Roper 1355W3A Range (gas)*
Admiral 1365H-EZW WALLOVEN- S/C ELE
Admiral 1365HW-EZW WALLOVEN- S/C ELE
Admiral 1370H-KLZW WALLOVEN- CONT CLEAN GAS
Admiral 1375H-KLZW WALLOVEN- CONT CLEAN GAS
Admiral 1375HW-KLZW WALLOVEN- CONT CLEAN GAS
Admiral 1375HW-KZW WALLOVEN- STD GAS
Roper 1393*0A GAS RANGE
Roper 1393*1A GAS RANGE
Roper 1393*2A GAS RANGE
Roper 1393*3A GAS RANGE
Roper 1393*4A GAS RANGE
Roper 1393W0A GAS RANGE
Roper 1393W1A GAS RANGE
Roper 1393W2A GAS RANGE
Whirlpool 1393W3A
Whirlpool 1393W4A
Whirlpool 1393^3A
Whirlpool 1393^4A
Roper 1395*0A GAS RANGE
Roper 1395*1A GAS RANGE
Roper 1395*2A GAS RANGE
Roper 1395*3A GAS RANGE
Roper 1395W0A GAS RANGE
Roper 1395W1A GAS RANGE
Roper 1395W2A GAS RANGE
Roper 1395W3A GAS RANGE
Frigidaire 14-025A1
Frigidaire 14-025A2
Frigidaire 14-030A1
Frigidaire 14-030A2
Frigidaire 14-040A1
Frigidaire 14-040A2
Frigidaire 14-040A4
Frigidaire 14-050A1
Frigidaire 14-2589-00-01 Tap(v1) / Gas Modular Cooktop
Frigidaire 14-2589-32-01 Tap(v2) / Gas Modular Cooktop
Frigidaire 14-2629-00-0A Tap(v2) / Gas Cooktop
Frigidaire 14-2629-00-17 Tap(v2) / Cooktop
Frigidaire 14-2629-00-19 Tap(v1) / Cooktop
Frigidaire 14-2629-08-17 Tap(v1) / Cooktop
Frigidaire 14-2629-08-19 Tap(v3) / Cooktop
Frigidaire 14-2629-23-0A Tap(v3) / Gas Cooktop
Frigidaire 14-2629-23-17 Tap(v3) / Cooktop
Frigidaire 14-2629-23-19 Tap(v2) / Cooktop
Frigidaire 14-2629-32-0A Tap(v1) / Gas Cooktop
Frigidaire 14-2639-00-0A Tap(v2) / Gas Cooktop
Frigidaire 14-2639-00-10 Tap(v2) / Gas Cooktop
Frigidaire 14-2639-08-0A Tap(v1) / Gas Cooktop
Frigidaire 14-2639-08-10 Tap(v1) / Gas Cooktop
Frigidaire 14-2639-23-0A Tap(v3) / Gas Cooktop
Frigidaire 14-2639-23-10 Tap(v3) / Gas Cooktop
Frigidaire 14-3028-00-01 Tap(v1) / Gas Range
Frigidaire 14-3028-00-02 Tap(v1) / Cooktop
Frigidaire 14-3028-00-03 Tap(v1) / Cooktop
Frigidaire 14-3028-08-01 Tap(v6) / Gas Range
Frigidaire 14-3028-08-02 Tap(v4) / Cooktop
Frigidaire 14-3028-08-03 Tap(v3) / Cooktop
Frigidaire 14-3028-23-01 Tap(v2) / Gas Range
Frigidaire 14-3028-23-02 Tap(v2) / Cooktop
Frigidaire 14-3028-23-03 Tap(v2) / Cooktop
Frigidaire 14-3028-45-01 Tap(v4) / Gas Range
Frigidaire 14-3028-57-01 Tap(v5) / Gas Range
Frigidaire 14-3028-66-01 Tap(v3) / Gas Range
Frigidaire 14-3028-66-02 Tap(v3) / Cooktop
Frigidaire 14-3038-00-01 Tap(v1) / Cooktop
Frigidaire 14-3038-00-02 Tap(v1) / Cooktop
Frigidaire 14-3038-00-03 Tap(v2) / Cooktop
Frigidaire 14-3038-08-01 Tap(v6) / Cooktop
Frigidaire 14-3038-08-02 Tap(v4) / Cooktop
Frigidaire 14-3038-08-03 Tap(v1) / Cooktop
Frigidaire 14-3038-23-01 Tap(v2) / Cooktop
Frigidaire 14-3038-23-02 Tap(v2) / Cooktop
Frigidaire 14-3038-23-03 Tap(v3) / Cooktop
Frigidaire 14-3038-45-01 Tap(v4) / Cooktop
Frigidaire 14-3038-57-01 Tap(v5) / Cooktop
Frigidaire 14-3038-66-01 Tap(v3) / Cooktop
  #2 (permalink)
Old 12-13-2013, 02:33 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
You dd not include a model number but below is a wiring diagram for a unit (FDG336RET2) that uses the same thermostat and shows how it is wired.
http://manuals.frigidaire.com/prodin.../131517300.pdf
__________________
  #3 (permalink)
Old 12-13-2013, 05:14 AM
Junior Member
Default
Perfect! Thanks for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer - Won't Start - Thermostat continuity? emod Dryer Repair 5 11-04-2012 11:03 AM
Testing Start Switch Continuity- Which Prongs? socrjul Dryer Repair 1 05-25-2012 02:31 PM
Testing defrost thermostat continuity jyhill Refrigerator & Freezer Repair 6 05-10-2011 09:04 AM
testing for continuity jlmac27 Dryer Repair 5 11-24-2009 03:06 PM
Testing continuity gookamal Refrigerator & Freezer Repair 0 06-11-2009 12:17 PM
