Discuss
Dryer hums won't start
 in
Dryer Repair
I have read dozens of posts and can't find anything that would explain why my dryer won't run after replacing
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer hums won't start
  #1 (permalink)
Old 12-10-2013, 05:06 PM
Junior Member
HOYTGRIMES is on a distinguished road
Default Dryer hums won't start
Model Number: SDE305DAYW   Brand: Maytag   Age: 5 - 10 years
I have read dozens of posts and can't find anything that would explain why my dryer won't run after replacing all of the parts. I replaced the motor, timer, thermal fuse and thermostat and all it does is hum and turn without the drum in when i hold down the start button. I have also checked the power source and continuity on all of the wires. Do you think I bought a bad motor?
Related Models
Maytag SDE305DAYW DRYER- ELE
Maytag SDE305DAZW DRYER- ELE
Maytag SDE3606AYQ DRYER- ELE
Maytag SDE3606AYW DRYER- ELE
Maytag SDE3606AZW DRYER- ELE
Maytag SDE4000AYW DRYER- ELE
Maytag SDE4000AZW DRYER- ELE
Maytag SDE405DAYW DRYER- ELE
Maytag SDE4606AYW DRYER- ELE
Maytag SDE4606AZW DRYER- ELE
Maytag SDE505DAYQ DRYER- ELE
Maytag SDE505DAYW DRYER- ELE
Maytag SDE505DAZW DRYER- ELE
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
  #2 (permalink)
Old 12-11-2013, 02:26 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Sorry but I do not understand the above, could you explain it differently.
The way that I interpret the above is that you get a hum and the motor turns without the drum installed. The hum may be just the normal running noise f the motor.
What was the original problem/symptoms with the unit?
What are the current symptoms?
Looking at the parts you replaced it could be a heating or a motor problem.
__________________
  #3 (permalink)
Old 12-11-2013, 03:06 AM
Junior Member
Default
Sorry, the dryer stopped working so I started buying parts. It appears that the motor shorted out and burned up all of the parts. Now when I hold in the start button with the drum out the motor will turn slow but won't kick in and run. When the drum is in it just hums and won't turn the drum.
  #4 (permalink)
Old 12-11-2013, 07:54 AM
Senior Expert
APP Volunteer
Default
Sounds like you either received a bad motor or hooked it up wrong.
it should be useful to double check how te motor is hooked up.
The motor should go full speed with the drum out.
Make sure that the unit is set on a non heating cycle when doing this otherwise you could blow a thermal fuse or cutout due to no air flow over the heating coil.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 28 12-10-2013 05:04 PM
Ge Dryer hums but won't start douglas_kb Dryer Repair 1 06-01-2012 06:10 PM
Ge Dryer Hums But Won't Start douglas_kb Dryer Repair 3 05-28-2012 05:14 AM
Dryer hums, won't start spearmint Dryer Repair 4 01-18-2011 08:08 PM
Dryer hums, but won't start mvcampbell8 Dryer Repair 5 05-25-2010 07:28 AM
