Discuss
dryer element is too hot after replacing
 in
Dryer Repair
after replacing heating element it runs very hot on all settings. what should I check and how? Related Models Kenmore
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer element is too hot after replacing
  #1 (permalink)
Old 12-10-2013, 04:48 PM
Junior Member
kmcentaurgmail.com is on a distinguished road
Default dryer element is too hot after replacing
Model Number: 41794812301   Brand: Kenmore   Age: 5 - 10 years
Related Models
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794862302 LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794872302 LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797042700 DRYER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797812700 LAUNDRY CENTER
Kenmore 41797812701 LAUNDRY CENTER
Kenmore 41797812702 LAUNDRY CENTER
Kenmore 41797812704 LAUNDRY CENTER
Kenmore 41797822700 LAUNDRY CENTER
Kenmore 41797822701 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41797912700 LAUNDRY CENTER
Kenmore 41797912701 LAUNDRY CENTER
Kenmore 41797912702 LAUNDRY CENTER
Kenmore 41797912704 LAUNDRY CENTER
Kenmore 41797922700 LAUNDRY CENTER
Kenmore 41797922701 LAUNDRY CENTER
Kenmore 41797962700 LAUNDRY CENTER
Kenmore 41797962701 LAUNDRY CENTER
Kenmore 41797962702 LAUNDRY CENTER
Kenmore 41797962703 LAUNDRY CENTER
Kenmore 41797962705 LAUNDRY CENTER
Kenmore 41797972700 LAUNDRY CENTER
Kenmore 41797972701 LAUNDRY CENTER
Kenmore 41797972702 LAUNDRY CENTER
Kenmore 41798042700 DRYER
Kenmore 41798042701 DRYER
Kenmore 41798052700 GAS DRYER
Kenmore 41798052701 GAS DRYER
Kenmore 41798056700 DRYER
Kenmore 41798056701 DRYER
Kenmore 41798076700 DRYER
Kenmore 41798076701 DRYER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
Kenmore 41799165100 LAUNDRY CENTER
Kenmore 41799165110 LAUNDRY CENTER
Kenmore 41799165120 LAUNDRY CENTER
Kenmore 41799165130 LAUNDRY CENTER
Kenmore 41799165800 LAUNDRY CENTER
Kenmore 41799165810 LAUNDRY CENTER
Kenmore 41799165820 LAUNDRY CENTER
Kenmore 41799165830 LAUNDRY CENTER
Kenmore 41799170100 LAUNDRY CENTER
Kenmore 41799170110 LAUNDRY CENTER
Kenmore 41799170120 LAUNDRY CENTER
Kenmore 41799170800 LAUNDRY CENTER
Kenmore 41799170810 LAUNDRY CENTER
Kenmore 41799170820 LAUNDRY CENTER
Kenmore 41799175100 LAUNDRY CENTER
Kenmore 41799175110 LAUNDRY CENTER
Kenmore 41799175120 LAUNDRY CENTER
Kenmore 41799175800 LAUNDRY CENTER
Kenmore 41799175810 LAUNDRY CENTER
Kenmore 41799175820 LAUNDRY CENTER
Kenmore 41799180100 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180110 LAUNDRY CENTER
Kenmore 41799180120 LAUNDRY CENTER
  #2 (permalink)
Old 12-11-2013, 02:53 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts.
Parts for Kenmore Washer Dryer Combo 41794812301 - AppliancePartsPros.com
The sears parts site does have actual parts breakdowns but they do not share theses with other parts vendors.
Below is a service manual.
You will have to join the site and be logged in to be able to download the manual.
http://appliancejunk.com/forums/inde...t=13 86758684
The unit was made by Frigidaire. do not have a cross reference of Sears/Kenmore numbers to Frigidaire model numbers so this is a bit of a guess. I think your unit is a close match to the wiring diagram on Page 14.
The Sears site does shoe a very blurry wiring diagram that looks close to the above.
First I would check to be sure that the vent system is OK.
I doubt tis is the problem but it is the easiest thing to check.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Next, I would check the heating element.
Unplug the unit and both wires at the heater.
Measure across the heater.
Should be about 12 ohms.
Now measure from each element connector to the case/frame.
Both should be infinite ohms.
If not the element is grounded and the cycling thermostat cannot regulate it.
Be sure to measure to bare metal on the case/frame.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not heating enough after replacing heat element lfshadow Dryer Repair 3 08-13-2013 05:15 PM
Replacing heating element GE dryer nfntjy Dryer Repair 1 02-18-2011 02:47 PM
Dryer not heating after replacing element rromine Dryer Repair 1 10-17-2010 05:39 AM
Replacing the heating element on Inglis dryer Angelomommie Dryer Repair 0 06-10-2010 11:38 AM
Replacing heating element on Whirlpool dryer GEEMAN Dryer Repair 3 11-08-2009 06:20 PM
