Discuss
Maytag Epic Dryer stops mid cycle on auto
 in
Dryer Repair
Hello, I have a Maytag MED9700SB0 Electric dryer that I got used without any knowledge about its history. Its pretty
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Epic Dryer stops mid cycle on auto
  #1 (permalink)
Old 12-10-2013, 11:20 AM
Junior Member
sjacobs4 is on a distinguished road
Default Maytag Epic Dryer stops mid cycle on auto
Model Number: MED97000SB0   Brand: Maytag   Age: 5 - 10 years
Hello, I have a Maytag MED9700SB0 Electric dryer that I got used without any knowledge about its history. Its pretty clean inside and out, so seemingly well taken care of.
Anyway, when I run the dryer on any of the automatic settings the "sensing" light comes on and the dryer will run from a few to maybe 10 minutes and then shut off with the "cycle complete" light on. I have yet to see either the "wet" or "damp" lights on, it just skips them, says cycle complete and leaves me with warm wet clothes.
One time with wet towels it was running for nearly 10 minutes and "sensing." So i opened the door, took a wet towel and rubbed it against the sensor bars, closed the door, started the dryer again, and within about 10 seconds the dryer turned off with the "cycle complete" light on.
If I run it on timed dry it completes the cycle without issue.
I have tried cleaning the sensor bars with rubbing alcohol, an eraser, an emery board, and some high-grit sandpaper. The last seemed to extend how long it runs before completing the cycle, but it still only runs for a short time.
Further research says that if dryer doesn't detect moisture by 10 minutes in auto mode that it will shut down. So do I need to replace just the sensor bars, or is there something more that they connect to that is not working properly?
having done a little research, other's experiences seem to point to the temperature thermistor or the moisture sensor bars themselves.
any idea?
thanks for your help
Sean
Related Models
Maytag MED9700SB0 ELECTRIC DRYER
Maytag MED9700SQ0 ELECTRIC DRYER
Maytag MED9800TK0 Electric Dryer
Maytag MED9800TQ0 ELECTRIC DRYER
Maytag MEDB200VQ0 27" ELECTRIC DRYER
Maytag MEDB400VQ0 27" ELECTRIC DRYER
Maytag MEDB700VQ0 27" ELECTRIC DRYER
Maytag MEDB800VB0 27" ELECTRIC DRYER
Maytag MEDB800VQ0 27" ELECTRIC DRYER
Maytag MEDB800VU0 27" ELECTRIC DRYER
Maytag MEDB850WB0 27" ELECTRIC DRYER
Maytag MEDB850WL0 27" ELECTRIC DRYER
Maytag MEDB850WQ0 27" ELECTRIC DRYER
Maytag MEDB850WR0 27" ELECTRIC DRYER
Maytag MEDC400VW0 29" ELECTRIC DRYER
Maytag MEDC500VW0 29" ELECTRIC DRYER
Maytag MEDC500VW1 29" ELECTRIC DRYER
Maytag MEDC700VJ0 27" ELECTRIC DRYER
Maytag MEDC700VW0 27" ELECTRIC DRYER
Maytag MEDE200XW0 27" ELECTRIC DRYER
Maytag MEDE200XW1 27" ELECTRIC DRYER
Maytag MEDE250XL0 27" ELECTRIC DRYER
Maytag MEDE300VF0 29" ELECTRIC DRYER
Maytag MEDE300VF1 29" ELECTRIC DRYER
Maytag MEDE300VF2 29" ELECTRIC DRYER
Maytag MEDE300VW0 29" ELECTRIC DRYER
Maytag MEDE300VW1 29" ELECTRIC DRYER
Maytag MEDE400XR0 29" ELECTRIC DRYER
Maytag MEDE400XW0 29" ELECTRIC DRYER
Maytag MEDE500VF0 29" ELECTRIC DRYER
Maytag MEDE500VF1 29" ELECTRIC DRYER
Maytag MEDE500VP0 29" ELECTRIC DRYER
Maytag MEDE500VP1 29" ELECTRIC DRYER
Maytag MEDE500VW0 29" ELECTRIC DRYER
Maytag MEDE500VW1 29" ELECTRIC DRYER
Maytag MEDE500WJ0 29" ELECTRIC DRYER
Maytag MEDE500WR0 29" ELECTRIC DRYER
Maytag MEDE900VJ0 29" ELECTRIC DRYER
Maytag MEDE900VJ1 29" ELECTRIC DRYER
Maytag MEDE900VW0 29" ELECTRIC DRYER
Maytag MEDE900VW1 29" ELECTRIC DRYER
Maytag MEDX500XL0 27" ELECTRIC DRYER
Maytag MEDX500XW0 27" ELECTRIC DRYER
Maytag MEDX550XW0 27" ELECTRIC DRYER
Maytag MEDX600XW0 27" ELECTRIC DRYER
Maytag MEDZ400TQ1 27" Electric Dryer
Maytag MEDZ400TQ2 27" Electric Dryer
Maytag MEDZ600TB1 27" Electric Dryer
Maytag MEDZ600TB2 27" ELECTRIC DRYER
Maytag MEDZ600TE2 27" ELECTRIC DRYER
Maytag MEDZ600TK1 27" Electric Dryer
Maytag MEDZ600TK2 27" ELECTRIC DRYER
Maytag MEDZ600TW1 27" Electric Dryer
Maytag MEDZ600TW2 27" ELECTRIC DRYER
Maytag MEDZ600WR0 27" ELECTRIC DRYER
Frigidaire MEF200PBDA Frg(v2) / Electric Range
Frigidaire MEF200PBDB Frg(v1) / Electric Range
Frigidaire MEF200PBWA Frg(v1) / Electric Range
Frigidaire MEF200PBWB Frg(v2) / Electric Range
Frigidaire MEF203PBDA Frg(v4) / Electric Range
Frigidaire MEF203PBDB Frg(v3) / Electric Range
Frigidaire MEF203PBWA Frg(v3) / Electric Range
Frigidaire MEF203PBWB Frg(v4) / Electric Range
Frigidaire MEF300PBDA Frg(v1) / Electric Range
Frigidaire MEF300PBDB Wwh(v1) / Electric Range
Frigidaire MEF300PBDC Wwh(v2) / Electric Range
Frigidaire MEF300PBDD Frg(v1) / Electric Range
Frigidaire MEF300PBDE Frg(v1) / Electric Range
Frigidaire MEF300PBDF Frg(v1) / Electric Range
Frigidaire MEF300PBDG Frg(v1) / Electric Range
Frigidaire MEF300PBDH Frg(v1) / Electric Range
Frigidaire MEF300PBDJ Frg(v1) / Electric Range
Frigidaire MEF300PBDK Frg(v1) / Electric Range
Frigidaire MEF300PBWA Frg(v2) / Electric Range
Frigidaire MEF300PBWB Wwh(v3) / Electric Range
Frigidaire MEF300PBWC Wwh(v4) / Electric Range
Frigidaire MEF300PBWD Kel(v14) / Electric Range
Frigidaire MEF300PBWE Frg(v2) / Electric Range
Frigidaire MEF300PBWF Frg(v2) / Electric Range
Frigidaire MEF300PBWG Frg(v2) / Electric Range
Frigidaire MEF300PBWH Frg(v2) / Electric Range
Frigidaire MEF300PBWJ Frg(v2) / Electric Range
Frigidaire MEF300PBWK Frg(v2) / Electric Range
Frigidaire MEF300PXWA Frg(v0) / Electric Range
Frigidaire MEF300PXWB Frg(v0) / Electric Range
Frigidaire MEF300PXWC Frg(v0) / Electric Range
Frigidaire MEF300PXWD Frg(v0) / Electric Range
Frigidaire MEF300PXWE Frg(v0) / Electric Range
Frigidaire MEF300PXWF Frg(v1) / Electric Range
Frigidaire MEF300PXWG Frg(v2) / Electric Range
Frigidaire MEF300PXWH Frg(v3) / Electric Range
Frigidaire MEF301PBDA Frg(v3) / Electric Range
Frigidaire MEF301PBDB Wwh(v1) / Electric Range
Frigidaire MEF301PBDC Wwh(v2) / Electric Range
Frigidaire MEF301PBDD Kel(v15) / Electric Range
Frigidaire MEF301PBDE Frg(v3) / Electric Range
Frigidaire MEF301PBDF Frg(v1) / Electric Range
Frigidaire MEF301PBDG Frg(v1) / Electric Range
Frigidaire MEF301PBDH Frg(v1) / Electric Range
Frigidaire MEF301PBDJ Frg(v3) / Electric Range
Frigidaire MEF301PBDK Frg(v3) / Electric Range
Frigidaire MEF301PBWA Frg(v4) / Electric Range
Frigidaire MEF301PBWB Wwh(v3) / Electric Range
Frigidaire MEF301PBWC Wwh(v4) / Electric Range
Frigidaire MEF301PBWD Gib(v10) / Electric Range
Frigidaire MEF301PBWE Frg(v4) / Electric Range
Frigidaire MEF301PBWF Frg(v2) / Electric Range
Frigidaire MEF301PBWG Frg(v2) / Electric Range
Frigidaire MEF301PBWH Frg(v2) / Electric Range
Frigidaire MEF301PBWJ Frg(v4) / Electric Range
Frigidaire MEF301PBWK Frg(v4) / Electric Range
Frigidaire MEF302PBDA Frg(v2) / Electric Range
Frigidaire MEF302PBDB Kel(v1) / Electric Range
Frigidaire MEF302PBDC Wwh(v1) / Electric Range
Frigidaire MEF302PBDD Gib(v11) / Electric Range
Frigidaire MEF302PBDE Frg(v5) / Electric Range
Frigidaire MEF302PBDF Frg(v3) / Electric Range
Frigidaire MEF302PBDG Frg(v1) / Electric Range
Frigidaire MEF302PBDH Frg(v1) / Electric Range
Frigidaire MEF302PBDJ Frg(v1) / Electric Range
  #2 (permalink)
Old 12-11-2013, 03:16 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for MED97000SB0 - AppliancePartsPros.com
Sounds like a problem with the moisture sensor.
The tech sheet has some info on how to test it.
The way that the moisture sensor works is that a low voltage is applied across the metal strips.
When there is moisture between them, this allows a small current to flow.
The board senses this current and holds the timer off.
When the clothes are dry, there is no moisture between the strips therefore no current and the timer advances to off.
Your problem sounds like the unit is not sensing the moisture between the strips so it thinks the clothes are dry re: always infinite resistance. This could be as simple as a wire has come off the sensor strips.
Unplug the unit.
Set your meter to a high resistance scale.
Measure P2-1 to P2-2 at the control board.
Should be either an infinite resistance or ea very high resistance.
Now wet your thumb and place it on the sensor bars.
The resistance should decrease.
If it does there is a problem with the control board.
If it does not then there is an open connection in the sensor bar circuit.
__________________
  #3 (permalink)
Old 12-11-2013, 05:52 AM
Junior Member
Default
Thank you for the information. I will check it out.
Sean
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Epic Z won't start cycle, shuts off jonnybravo_14 Washer Repair 1 03-23-2013 08:36 PM
Whirlpool Gas Dryer, Auto cycle does not advance and timed cycle does not heat Costa Rica Kim Dryer Repair 0 01-25-2012 10:47 AM
Maytag Epic Dryer CSM Denny Dryer Repair 1 12-13-2011 06:49 AM
Maytag Dryer stops in middle of drying cycle tekatoo Dryer Repair 1 01-24-2010 07:33 AM
Maytag SE 1000 washer stops mid cycle or won't start wash cycle katyat Washer Repair 1 09-11-2009 04:15 PM
