Dryer stops after about 10 minutes. It does get hot. If I set it on "normal" the timer automatically picks 45 minutes. Then after about 10 minutes it stops on 35 or so minutes and flashes the AD error. If I just set the left dial to a certain amount of minutes it still stops after about 10 or 15 minutes and all the lights on the right blink but no error code.
I wonder if this could be the control panel but I don't want to order an expensive part if I don't need it. thank you!
