Discuss
Kenmore Dryer Doesn't Heat
 in
Dryer Repair
So I'm a new homeowner and was given this Kenmore Dryer by a co-worker since the previous homeowner took the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer Doesn't Heat
  #1 (permalink)
Old 10-15-2009, 10:28 AM
Junior Member
noob_homeowner is on a distinguished road
Default Kenmore Dryer Doesn't Heat
Model Number: 41779042991   Brand: Kenmore   Age: 5 - 10 years
So I'm a new homeowner and was given this Kenmore Dryer by a co-worker since the previous homeowner took the dryer with him on the day that we received the keys.
Unfortunately the Kenmore Dryer doesn't heat up. I had the gas guy come out to see if it was the gas line that was causing the problem. He said gas was good...and he was even kind enough to open the access panel in the back and noticed that the ignitor was working as well. His guess was that it was the solenoid (gas valve coil???) that was busted. How do I actually get access to replace the solenoid?
Any help for this noob is appreciated. Thanks!
Ads By Google
Related Models
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
Kenmore 41789390800 COMBINATION WASHER/DRYER
Kenmore 41789390801 COMB, WASHER/DRYER
Kenmore 41789390810 COMBINATION WASHER/DRYER
Kenmore 41789395100 WASHER-DRYER
Kenmore 41789395101 COMBINATION WASHER/DRYER
Kenmore 41789395110 COMBINATION WASHER/DRYER
Kenmore 41789395600 WASHER-DRYER
Kenmore 41789395701 COMBINATION WASHER/DRYER
Kenmore 41789395710 COMBINATION WASHER/DRYER
Kenmore 41789395800 WASHER-DRYER
Kenmore 41789395801 COMBINATION WASHER/DRYER
Kenmore 41793042202 DRYER
Kenmore 41793052202 DRYER
Kenmore 41793142202 DRYER
Kenmore 41793702201 SEARS/LAUNDRY CENTER
Kenmore 41793802201 LAUNDRY CENTER
Kenmore 41793812200 LAUNDRY CENTER
Kenmore 41793812201 LAUNDRY CENTER
Kenmore 41793814200 LAUNDRY CENTER
Kenmore 41793814201 LAUNDRY CENTER
Kenmore 41793862200 LAUNDRY CENTER
Kenmore 41793862201 LAUNDRY CENTER
Kenmore 41793872200 LAUNDRY CENTER
Kenmore 41793872201 LAUNDRY CENTER
Kenmore 41794802300 LAUNDRY CENTER
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
  #2 (permalink)
Old 10-15-2009, 12:55 PM
Junior Member
mrwanzek is on a distinguished road
Default Replace the Gas Valve Coils
They should be easy to access once you take off the front of the dryer. They are two black cylinders on the burner assembly. A common version of the part is about $16 from APP.
  #3 (permalink)
Old 10-15-2009, 01:36 PM
Junior Member
Default
So how do I actually remove the front of the dryer???
Completely noob at this...I don't see any screws in the front that would just "pop" it off...
  #4 (permalink)
Old 10-15-2009, 01:37 PM
Junior Member
Default
  #5 (permalink)
Old 10-15-2009, 02:27 PM
Junior Member
Default
There are two clips in the front that hold the top down. Take a putty knife or something else flat and, in the little gap between the top and the front of the dryer, press in to release the clips. You should be able to lift up the front of the lid. There may be a screw or two inside the dryer along with a couple of clips that just pull out that hold the front on to the rest of the dryer. Make sure to support the drum when you pull off the front. Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer Will Not Heat Up mastaone Dryer Repair 1 11-09-2009 03:45 AM
No Heat From Kenmore Gas Dryer grazzin Dryer Repair 2 09-16-2009 03:40 PM
Kenmore dryer will not heat lpennock Dryer Repair 2 05-11-2009 06:19 AM
Kenmore Dryer will not heat T.A.M. Dryer Repair 1 02-10-2009 06:28 PM
Kenmore Dryer No Heat mishdeme Dryer Repair 3 01-23-2008 06:56 PM
