| » Whirpool Duet Dryer Error code F25 |
Model Number: WED9200SQ0 Brand: Whirlpool Age: 1 - 5 years
Whirpool Electric Dryer Gets error code "F25". Dryer will not start stays in sensing mode. It is 1.5 years old. Worked perfect till this point. Any help would be much apprecieated.
UPDATE I ohm'ed the following:
The Dryer heater coil has continuity Overheat Snap disk on heater coil housing reads continuity Is another smaller snap disk on the heater coil housing has continuity 2 sensers on the return air (dryer filter front) Both of these seners are open with no continuity Again thanks for any assisance with F25 error code |
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WED9200SQ0 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene in previous post gave very good diagnosis.
For others future reference. The actual problem was that the lint got caught up in the fan cage by coating the fins on the fan hence making it mor and more difficult to move the air. thus making dryer real hot and blowing the finger fuse. I had replaced every sensor and limit switch in the dryer for about $35 (still cheeper than calling service man) But, the problem was not with any of the switches or limits It is becuse the newer cheepe made machines do not have the power the old ones had to blow the air out. I had a 35 foot vent run wich now that this machine is 1 year old is borderline moving the air out even with a clean vent tube. I purchased a dryer booster to help the dryer push the air out on my so called long 35 foot run. It might be overkill by adding the booster fan but it prevent the dryer from overheating blowing fuses and runing clothes sice dryer gets real real hot inside with restricted air flow... In short... if you get the f 25 error code clean you vent line all the way till the end also the blower squirle cage make sure fins in the cage are completely lint free, Buy another finger fuse you should be good to go... Last edited by sy_base : 12-01-2009 at 05:27 AM. |
Thank you for the feedback and sharing your repair with us. It is very important to keep the vent clean for good dryer performance and safety. Good luck with your dryer.
__________________
| Display Modes | |
| whirlpool duet dryer not turning on-error code 3E | kmsewell | Dryer Repair | 2 | 04-14-2013 09:41 PM |
| F1 Error Code Whirpool Cabrio | mani | Washer Repair | 6 | 08-24-2012 04:05 PM |
| whirpool duet show error msg( FH) | mani | Washer Repair | 1 | 07-22-2009 05:54 PM |
| whirpool duet show error msg( FH) | mani | Washer Repair | 2 | 07-21-2009 05:31 PM |
| error code E1 F2 on whirpool gas range | siciliano | Oven Repair (including Ranges and Cooktops) | 5 | 11-09-2008 08:11 AM |
