Discuss
Whirlpool Dryer not drying good
 in
Dryer Repair
Dryer will not dry well. Have to run item more than once. Vents are clear and clean. What might be
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer not drying good
  #1 (permalink)
Old 02-12-2008, 09:16 AM
hmfary1 hmfary1 is offline
Junior Member
hmfary1 is on a distinguished road
Default Whirlpool Dryer not drying good
Model Number: LER5636EQ3   Brand: Whirlpool   Age: Less than 1 year
What might be the problem?
Hugh
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-12-2008, 08:58 PM
subcultures10 subcultures10 is offline
Junior Member
subcultures10 is on a distinguished road
Default
what do you mean by clear and clean? How strong is the pressure at the outside vent cap? Are the any dips & bends/90degree turns in the vent? Whats the vents distance its ran? Is it hard vent or soft coil vent piping?
Try putting a flex pipe on the dryer, about 4 feets worth, get a bucket put some water in it & put the vent pointing inside the bucket & run it for a cycle & see if its better. If so you know its the vent, if not? Then you know its in the dryer..
The water in the bucket will act like a magnet for the lint & dust. And the heat will be released in the air. Just try it for a load and see what happens and go from there...Full load of clothes ( Ex-large on the washer) should take 45-55mins normally. Mine takes 40, but my vent is 2 ft long straight out!
__________________
It can be fixed 90% of the time
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer not drying losanft Dryer Repair 0 02-03-2008 09:43 AM
dryer not drying enough lt3 Dryer Repair 5 01-04-2008 11:38 AM
Dryer not drying mariebw Dryer Repair 3 12-30-2007 05:39 PM
Dryer not drying sue1759 Dryer Repair 5 11-02-2007 06:09 PM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
