Discuss
amana dryer not heating
 in
Dryer Repair
good morning. My wife and I just bought a new ( to us) home and just moved in 2 days ago.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » amana dryer not heating
  #1 (permalink)
Old 02-12-2008, 09:04 AM
KelleyJ KelleyJ is offline
Junior Member
KelleyJ is on a distinguished road
Question amana dryer not heating
Model Number: unknown at this time   Brand: Amana   Age: 1 - 5 years
good morning. My wife and I just bought a new ( to us) home and just moved in 2 days ago. it came with a (newer) washer and dryer
they are amana super capacity +
the dryer says something along the lines of industrial size or somthing of that nature on it.
my wife went to do a load of laundry last night and the dryer is not heating up at all. we let it run till it stopped. although, it was still running when we went to bed and when i got up this morning it was still running. the timer never shut off and i stopped the dryer and opened it up it was still not warm.
im uncertain if it is a gas or electric dryer, if i had to guess id say its electric as ther eis the standard large 220 plug behind it and i didnt see any gas line running to it
my question is this, if the heating element is bad. 1) where can i get a new one and 2) if the dryer isnt getting hot will it continue to run or is the timer also faulty?
thanks in advance
Kelley S.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-12-2008, 09:30 AM
old repair old repair is offline
Junior Member
old repair is on a distinguished road
Default
hi, check the filter, turn power off at panel 30 amp breaker. this may reset if it's a electronic unit. check the temperture setting make sure it's not on air dry or fluff dry good luck
  #3 (permalink)
Old 02-12-2008, 10:02 AM
Junior Member
Default
Quote:
thanks, its a model # ale443raw
ill try that though, if that dosent help, what likely is the culprit, the heating element, thermostat or timer or all three
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana dryer top removal gremlin Dryer Repair 2 08-05-2008 06:47 PM
Amana Dryer Problem js02673 Dryer Repair 1 01-28-2008 11:33 AM
Amana dryer gas augie0629 Dryer Repair 1 12-16-2007 07:55 PM
High Pitched squeak in Dryer - AMANA Tmcjury Dryer Repair 0 11-06-2007 12:23 PM
Amana Electric Dryer- No Heat didier Dryer Repair 1 10-26-2007 08:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
