Discuss
Whirlpool LER7646EQO makes sound when turned on. Drum does not move
 in
Dryer Repair
Whirlpool LER7646EQO makes sound when turned on. Drum does not move Related Models Whirlpool  LER7646EZ0  DRYER Whirlpool  LER7646EZ1  DRYERS Whirlpool
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool LER7646EQO makes sound when turned on. Drum does not move
  #1 (permalink)
Old 11-21-2013, 05:00 PM
Junior Member
MG1979 is on a distinguished road
Default Whirlpool LER7646EQO makes sound when turned on. Drum does not move
Model Number: LER7646EQO   Brand: Whirlpool   Age: More than 10 years
Related Models
Whirlpool LER7646EZ2 ELECTRIC DRYER
Whirlpool LER7646JQ0 DRYER
Whirlpool LER7646JT0 DRYER
Whirlpool LER7648KQ0 RESIDENTIAL DRYER
Whirlpool LER7648KQ1 RESIDENTIAL DRYER
Whirlpool LER7648KQ2 RESIDENTIAL DRYER
Whirlpool LER7648KQ3 29"ELECTRIC DRYER
Whirlpool LER7648KT0 RESIDENTIAL DRYER
Whirlpool LER7648KT1 RESIDENTIAL DRYER
Whirlpool LER7648KT2 RESIDENTIAL DRYER
Whirlpool LER7648KT3 29"ELECTRIC DRYER
Whirlpool LER7648PQ0 29" ELECTRIC DRYER
Whirlpool LER7648PQ1 29" ELECTRIC DRYER
Whirlpool LER7648PT0 29" ELECTRIC DRYER
Whirlpool LER7648PT1 29" ELECTRIC DRYER
Whirlpool LER7848DQ0 ELECTRIC DRYER
Whirlpool LER7848DQ1 ELECTRIC DRYER
Whirlpool LER7848DZ0 ELECTRIC DRYER
Whirlpool LER7848DZ1 ELECTRIC DRYER
Whirlpool LER7858AN1 ELECTRIC DRYER
Whirlpool LER7858AN2 ELECTRIC DRYER
Whirlpool LER7858AW0 Residential Dryer
Whirlpool LER7858AW1 ELECTRIC DRYER
Whirlpool LER7858AW2 ELECTRIC DRYER
Whirlpool LER8620PG0 29"ELECTRIC DRYER
Whirlpool LER8620PG1 29"ELECTRIC DRYER
Whirlpool LER8620PW0 29"ELECTRIC DRYER
Whirlpool LER8620PW1 29"ELECTRIC DRYER
Whirlpool LER8648LG0 RESIDENTIAL DRYER
Whirlpool LER8648LG1 29"ELECTRIC DRYER
Whirlpool LER8648LQ0 RESIDENTIAL DRYER
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
Whirlpool LER8648PQ1 29"ELECTRIC DRYER
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
Whirlpool LET7646EQ2 ELECTRIC DRYER
Whirlpool LET7646EZ0 ELECTRIC DRYER
Whirlpool LET7646EZ1 DRYERS
  #2 (permalink)
Old 11-21-2013, 05:09 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
If the motor is running but you have no wash or spin actions, the motor coupling is likely worn or broken. There is a video at the link below that will show you how to access, inspect and replace that coupling, should you find it faulty!
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
  #3 (permalink)
Old 11-22-2013, 12:46 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts.
Parts for Whirlpool LER7646EQ0 Dryer - AppliancePartsPros.com
If the sound is coming from where the motor is it could be a couple things.
If it is a hum then perhaps just the belt has broken.
If the sound is more like a buzz it could be motor problem.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
  #4 (permalink)
Old 11-22-2013, 07:51 AM
Senior Member
Default
Not quite sure how I overlooked that this was a dryer...but I missed the boat! Thank you for the correct information.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Topload won't move-makes whirring sound keiken01 Washer Repair 3 01-29-2013 11:16 AM
Whirlpool makes clicking sound top center when on rookiefixer Microwave Repair 0 01-16-2012 08:03 AM
Whirlpool dryer stopped working LER7646EQO mcf57 Dryer Repair 1 10-14-2011 09:03 AM
Agitator makes a wierd sound and drum won't spin during wash cycles meanmommy Washer Repair 1 04-19-2011 05:26 PM
powers up, drum won't turn & makes buzzing sound sdtrevino Dryer Repair 1 09-10-2009 05:21 PM
