Here are your parts, includes a wiring diagram
Parts for Admiral ADE7005AYW Dryer - AppliancePartsPros.comThis unit does not have a fuse that will turn off just the heating element.
I would start by checking the power.
The timer and motor run on 120 volts but the heater requires the full 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
