acess3880
#1 Posted : Tuesday, October 13, 2009 7:40:27 AM(UTC)
acess3880
Well this has me think'n. My dryer times down and stays running till I turn timer or open door. It heats up and drys great. I have so far replaced timer,thermal fuse,thermal-cut off,high and low thermostats,cycle thermostat. Still won't shut off. Could have bought a new one for what I spent already. But like to tinker.
Doug
sidfink43
#2 Posted : Wednesday, October 14, 2009 6:44:56 AM(UTC)
sidfink43
Well, if you like to tinker and don't mind spending the money here's the likely cullprit, but you won't know until you replace it.
Part number: AP2997390
acess3880
#3 Posted : Wednesday, October 14, 2009 9:12:45 AM(UTC)
acess3880
Thanks for the information. I ordered a switch and will see how it goes.
Thanks again. I'll post the results.
Doug
sidfink43
#4 Posted : Wednesday, October 14, 2009 9:25:03 AM(UTC)
sidfink43
Good, we will be interested to hear how it turns out since this is a somewhat common problem and I have had success in the past with new start switches.
acess3880
#5 Posted : Tuesday, October 20, 2009 3:58:59 AM(UTC)
acess3880
Changed the switch.Dryer times down and at the end wont shutoff.
Doug
sidfink43
#6 Posted : Tuesday, October 20, 2009 9:44:07 AM(UTC)
sidfink43
Well darn, there is not much left to change out.
Try to check out the wiring, and test to see if it does this in all cycles, particular a no heat cycle if you have one.
