Discuss
PLEASE HELP! Melting dryer plug
 in
Dryer Repair
I have an older Kenmore dryer. About a week & a half ago while drying clothes I noticed a burning
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » PLEASE HELP! Melting dryer plug
  #1 (permalink)
Old 11-04-2013, 01:49 PM
Junior Member
LeighAnn is on a distinguished road
Default PLEASE HELP! Melting dryer plug
Brand: Kenmore   Age: More than 10 years
I have an older Kenmore dryer. About a week & a half ago while drying clothes I noticed a burning rubber smell; I stopped the dryer and examined and saw that the dryer plug was melting (the rubber around one of the plugs prongs). I thought it was just a problem with the plug/cord itself so I replaced the entire cord/plug as well as tightened the outlet box. When running the 1st load after replacing the cord within 10 minutes the same thing happened- one of the prongs had the rubber cord melting around it. I then thought that it was something with the electric either in the wall or the outlet itself, however my landlords handyman came by and tested the outlet and said that there wasn't a problem with the electric or outlet..he said it was something wrong with the dryer causing the plug to overheat..but wasn't exactly sure what...Please..Pretty Please help so I can fix!!!!
Thanks a bunch!
Leigh
  #2 (permalink)
Old 11-04-2013, 05:48 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Call a tech out it's something you can't diagnose over a computer and it's a fire hazard if misdiagnosed.
  #3 (permalink)
Old 11-05-2013, 01:15 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Get the landlord to send in an electrician.
You did not say so I am assuming this is a 240 volt electric dryer.
If the homes electrical is properly wired re: fuses or with circuit breakers then the fuse/breaker should trip if the dryer is puling too much current. The cord is rated for at least 30 amps but it will carry higher amperage without overheating. UL approved devices have a built in safety factor.
My gut says that you have a problem with the wall receptacle.
It is not something you can see.
Also it is not easy to troubleshoot unless you have the correct tools and know how to use them.
Below is my reasoning.
If there is a bad connection between the receptacle and the plug prong inside the receptacle, electricity sees this as a resistance. As current flows through this resistance it generates heat and I think this is what is causing your plug to melt.
The dryer does not blow the breaker so I doubt that it is drawing too much current unless you have a bad breaker and also an electrical problem in the dryer. This is unlikely but not unheard of.
Since you are renting I would not tackle this yourself due to liability if you mess up.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 5 12-09-2013 06:43 PM
Dryer Plug weikel1 Dryer Repair 1 12-20-2012 12:32 PM
Electrolux gas dryer melting clothes lmtuttle Dryer Repair 1 03-19-2012 10:34 AM
Convert Kitchen Aid Dryer from 3 Prong Plug to 4 Prong Plug edd225 Dryer Repair 2 04-16-2009 06:59 PM
Help,kenmore dryer plug melting!!!! ncrabbithunter Dryer Repair 2 10-05-2008 04:08 PM
