Discuss
Beko water pump issue, no power to it?
 in
Dryer Repair
I recently found out my water pump was not working. After getting a new part, it was still not working.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Beko water pump issue, no power to it?
  #1 (permalink)
Old 10-26-2013, 01:57 AM
Junior Member
Bigking97 is on a distinguished road
Default Beko water pump issue, no power to it?
Brand: -brand-   Age: 1 - 5 years
I joined the wires directly to the pump and it still did not spin.
Have I lost the power to the pump from the circuit board?
Is there any other factors that has to happen before the pump will spin? The way I was testing it was by manually pressing the micro switch on 'extra dry' mode during a spin.
Everything else works fine
  #2 (permalink)
Old 10-26-2013, 03:29 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Beko looks like a UK unit.
A model number may help others help you.
I probably will not be able to find any technical data on it.
This site deals mostly with North American units so I do not know where to find other tech data.
Not sure what wires you are referring to.
Without a wiring diagram I cannot comment.
Check the pump winding with a meter to see if there is continuity.
You could also usea cheater cord to hook it directly to power butagain I am not sure what power this pump requires so a direct hook up may blow it.
Sorry but again cannot comment.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Cabrio Pump issue deigo Washer Repair 3 09-21-2013 07:12 PM
Ice maker water supply pump has no power dojetdriver Refrigerator & Freezer Repair 0 09-24-2010 10:02 PM
Beko rope hinge please help jenxy@talktalk.net Dishwasher Repair 0 10-06-2009 10:49 AM
Draining issue - don't think it's the pump paddle6 Dishwasher Repair 0 06-09-2009 12:44 PM
Bosch washer pump issue (already replaced pump!) wdt Washer Repair 0 12-02-2008 06:26 AM
