I my dryer will run for about 15 min then shut off. I have clean pipe into the wall and at the exterior of my house. The inside of the drum is very hot smells almost like something is on fire when it shuts off. It will then restart and run anywhere from a moment to a few minutes again. Now the kicker is sometimes on the first load it will shut off after only 5 min or so before the drum gets hot. The screen will display paused when it shuts down from either of the above situations. There are no error codes on the machine as of this post.
Thanks Vince
