Discuss
Maytag No Heat
 in
Dryer Repair
I have read some other posts of dryers with no heat. Mine is a Maytag, model MGD9700SB0, gas. The dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag No Heat
  #1 (permalink)
Old 10-22-2013, 08:17 PM
Junior Member
tasmith5 is on a distinguished road
Default Maytag No Heat
Model Number: MGD9700SB0   Brand: Maytag   Age: 1 - 5 years
I have read some other posts of dryers with no heat. Mine is a Maytag, model MGD9700SB0, gas. The dryer will run, a complete cycle, timed or auto, however without heat. This has been a progressive complaint by my wife that drying times have increased over the past year. I have cleaned the dryer duct work and am confident there is no lint or other restrictions.
I have checked continuity of the thermofuze, high temp thermostat, and the igniter. I then pulled the two coils and both have continuity across leads.
Normally, there is an audible "click" when the drying cycle begins - which I think indicates the coils opening the gas valve. This does not happen... but the dryer runs, meaning the motor turns and the timer counts down.
Now my dryer is torn apart, each item as described above shows continuity and I'm at a loss as to what the problem is.
Any ideas/ help would be greatly appreciated.
Cheers.
Related Models
Maytag MGD9700SB0 Gas Dryer
Maytag MGD9700SQ0 Gas Dryer
Maytag MGD9800TB0 Gas Dryer
Maytag MGD9800TK0 GAS DRYER
Maytag MGD9800TQ0 GAS DRYER
Maytag MGDB200VQ0 GAS DRYER
Maytag MGDB400VQ0 GAS DRYER
Maytag MGDB700VQ0 GAS DRYER
Maytag MGDB800VB0 GAS DRYER
Maytag MGDB800VQ0 GAS DRYER
Maytag MGDB800VU0 GAS DRYER
Maytag MGDB850WB0 GAS DRYER
Maytag MGDB850WL0 GAS DRYER
Maytag MGDB850WQ0 GAS DRYER
Maytag MGDB850WR0 GAS DRYER
Maytag MGDC100WQ0 29" GAS DRYER
Maytag MGDC400VW0 29" GAS DRYER
Maytag MGDC500VW0 29" GAS DRYER
Maytag MGDC500VW1 29" GAS DRYER
Maytag MGDC700VJ0 27" GAS DRYER
Maytag MGDC700VJ1 27" GAS DRYER
Maytag MGDC700VW0 27" GAS DRYER
Maytag MGDC700VW1 27" GAS DRYER
Maytag MGDE200XW0 27" GAS DRYER
Maytag MGDE300VF0 29" GAS DRYER
Maytag MGDE300VF1 29" GAS DRYER
Maytag MGDE300VF2 29" GAS DRYER
Maytag MGDE300VF3 29" GAS DRYER
Maytag MGDE300VW0 29" GAS DRYER
Maytag MGDE300VW1 29" GAS DRYER
Maytag MGDE300VW3 29" GAS DRYER
Maytag MGDE400XR0 29" GAS DRYER
Maytag MGDE400XW0 29" GAS DRYER
Maytag MGDE500VF0 29" GAS DRYER
Maytag MGDE500VF1 29" GAS DRYER
Maytag MGDE500VP0 29" GAS DRYER
Maytag MGDE500VP1 29" GAS DRYER
Maytag MGDE500VW0 29" GAS DRYER
Maytag MGDE500VW1 29" GAS DRYER
Maytag MGDE500VW2 29" GAS DRYER
Maytag MGDE500WJ0 29" GAS DRYER
Maytag MGDE500WJ1 29" GAS DRYER
Maytag MGDE500WR0 29" GAS DRYER
Maytag MGDE500WR1 29" GAS DRYER
Maytag MGDE900VJ0 29" GAS DRYER
Maytag MGDE900VJ1 29" GAS DRYER
Maytag MGDE900VJ2 29" GAS DRYER
Maytag MGDE900VW0 29" GAS DRYER
Maytag MGDE900VW1 29" GAS DRYER
Maytag MGDE900VW2 29" GAS DRYER
Maytag MGDX500XL0 27" GAS DRYER
Maytag MGDX500XW0 27" GAS DRYER
Maytag MGDX550XW0 27" GAS DRYER
Maytag MGDX600XW0 27" GAS DRYER
Maytag MGDZ400TQ1 27" GAS DRYER
Maytag MGDZ400TQ2 27" GAS DRYER
Maytag MGDZ600TB1 27" GAS DRYER
Maytag MGDZ600TB2 27" GAS DRYER
Maytag MGDZ600TE2 27" GAS DRYER
Maytag MGDZ600TK1 27" GAS DRYER
Maytag MGDZ600TK2 27" GAS DRYER
Maytag MGDZ600TW1 27" GAS DRYER
Maytag MGDZ600TW2 27" GAS DRYER
Maytag MGDZ600WR0 27" GAS DRYER
Frigidaire MGF200PBDA Frg(v2) / Gas Range
Frigidaire MGF200PBDB Frg(v1) / Gas Range
Frigidaire MGF200PBWA Frg(v1) / Gas Range
Frigidaire MGF200PBWB Frg(v2) / Gas Range
Frigidaire MGF240GSA GAS RANGE
Frigidaire MGF300PBDA Frg(v1) / Gas Range
Frigidaire MGF300PBDB Wwh(v17) / Gas Range
Frigidaire MGF300PBDC Kel(v1) / Gas Range
Frigidaire MGF300PBDD Frg(v1) / Gas Range
Frigidaire MGF300PBDE Frg(v1) / Gas Range
Frigidaire MGF300PBDF Frg(v1) / Gas Range
Frigidaire MGF300PBDG Frg(v2) / Gas Range
Frigidaire MGF300PBDH
Frigidaire MGF300PBWA Frg(v2) / Gas Range
Frigidaire MGF300PBWB Wwh(v18) / Gas Range
Frigidaire MGF300PBWC Kel(v2) / Gas Range
Frigidaire MGF300PBWD Frg(v2) / Gas Range
Frigidaire MGF300PBWE Frg(v2) / Gas Range
Frigidaire MGF300PBWF Frg(v3) / Gas Range
Frigidaire MGF300PBWG Frg(v4) / Gas Range
Frigidaire MGF300PBWH
Frigidaire MGF301SBDA Frg(v1) / Gas Range
Frigidaire MGF301SBWA Frg(v2) / Gas Range
Frigidaire MGF303PGDA Frg(v1) / Gas Range
Frigidaire MGF303PGDC Frg(v1) / Gas Range
Frigidaire MGF303PGDD Frg(v2) / Gas Range
Frigidaire MGF303PGDE Frg(v3) / Gas Range
Frigidaire MGF303PGDG Universal/gas Range
Frigidaire MGF303PGDH Universal/gas Range
Frigidaire MGF303PGDJ Universal/gas Range
Frigidaire MGF303PGDK Universal/gas Range
Frigidaire MGF303PGDL Universal/gas Range
Frigidaire MGF303PGWA Frg(v2) / Gas Range
Frigidaire MGF303PGWC Frg(v4) / Gas Range
Frigidaire MGF303PGWD Frg(v5) / Gas Range
Frigidaire MGF303PGWE Frg(v6) / Gas Range
Frigidaire MGF303PGWG Universal/gas Range
Frigidaire MGF303PGWH Universal/gas Range
Frigidaire MGF303PGWJ Universal/gas Range
Frigidaire MGF303PGWK Universal/gas Range
Frigidaire MGF303PGWL Universal/gas Range
Frigidaire MGF311SBDA Frg(v3) / Gas Range
Frigidaire MGF311SBDB Wwh(v19) / Gas Range
Frigidaire MGF311SBDC Frg(v1) / Gas Range
Frigidaire MGF311SBDD Frg(v1) / Gas Range
Frigidaire MGF311SBDE Frg(v1) / Gas Range
Frigidaire MGF311SBDF Frg(v1) / Gas Range
Frigidaire MGF311SBWA Frg(v4) / Gas Range
Frigidaire MGF311SBWB Wwh(v20) / Gas Range
Frigidaire MGF311SBWC Frg(v2) / Gas Range
Frigidaire MGF311SBWD Frg(v2) / Gas Range
Frigidaire MGF311SBWE Frg(v2) / Gas Range
Frigidaire MGF311SBWF Frg(v2) / Gas Range
Frigidaire MGF312SBDA Frg(v1) / Gas Range
Frigidaire MGF312SBDC Frg(v1) / Gas Range
Frigidaire MGF312SBWA Frg(v2) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag No heat jprince Dryer Repair 0 11-07-2010 01:38 PM
Maytag no heat xenon68 Dryer Repair 1 07-15-2010 11:51 AM
Maytag NO HEAT GEARHEAD Dryer Repair 3 05-27-2009 06:14 AM
maytag MW does not heat SHAWN1001 Microwave Repair 0 03-30-2009 08:21 PM
Maytag MW won't Heat. Jimmyd Microwave Repair 1 12-01-2008 06:44 PM
