Discuss
Auto Sensing Dryer
 in
Dryer Repair
I Have a Estate Model # TEDS840PQ0 electric dryer. My problem is that the auto sensing doesn't quite work well,,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Auto Sensing Dryer
  #1 (permalink)
Old 10-18-2013, 10:33 AM
Junior Member
ViperMI is on a distinguished road
Question Auto Sensing Dryer
Model Number: TEDS840PQ0   Brand: Estate   Age: 1 - 5 years
I Have a Estate Model # TEDS840PQ0 electric dryer. My problem is that the auto sensing doesn't quite work well,, leaving clothing damp.
I replaced the Heating Element assembly, the Thermal Cut Out fuse kit, and the Cycling Thermostat.
I have cleaned the unit thoroughly inside and out. Vents,etc.
If I put it on the timed cycles it seems to work fine,, just problem with the Auto Sensing Selection.
Did I miss anything? Maybe another part that controls the auto sensing function????
Related Models
 TEDS840PQ0 29"ELECTRIC DRYER
 TEDS840PQ1 29"ELECTRIC DRYER
 TEDX340RW0 29" ELECTRIC DRYER
 TEDX340RW1 29" ELECTRIC DRYER
 TEDX340RW2 29" ELECTRIC DRYER
Whirlpool TEDX540RQ0 29" ELECTRIC DRYER
 TEDX540RQ1 29" ELECTRIC DRYER
 TEDX640EQ0 ELECTRIC DRYER
 TEDX640EQ1 DRYERS
 TEDX640EQ2 ELECTRIC DRYER
 TEDX640JQ0 ELECTRIC DRYER
 TEDX640JQ1 DRYER
 TEDX640JQ2 29"ELECTRIC DRYER
 TEDX640PQ0 29" ELECTRIC DRYER
 TEDX640PQ1 29"ELECTRIC DRYER
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BU4 ELECTRIC RANGE
Tappan TEF242BU5 ELECTRIC RANGE
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF242BW4 ELECTRIC RANGE
Tappan TEF242BW5 ELECTRIC RANGE
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF303BWF RANGE
Tappan TEF303BWG RANGE
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Tappan TEF317BWF ELECTRIC RANGE
Tappan TEF317BWG ELECTRIC RANGE
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FBB ELECTRIC RANGE
Tappan TEF326FBC ELECTRIC RANGE
Tappan TEF326FSA Tappan/range
Tappan TEF326FSB ELECTRIC RANGE
Tappan TEF326FSC ELECTRIC RANGE
Tappan TEF326FSD ELECTRIC RANGE
Tappan TEF326FSE ELECTRIC RANGE
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Tappan TEF351EWD ELECTRIC RANGE
Tappan TEF351EWE ELECTRIC RANGE
Tappan TEF351EWF ELECTRIC RANGE
Tappan TEF351EWG ELECTRIC RANGE
Tappan TEF351EWH ELECTRIC RANGE
Tappan TEF351EWJ TAPPAN/ELECTRIC RANGE
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
  #2 (permalink)
Old 10-19-2013, 04:24 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Estate TEDS840PQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
The unit use what could be called a poor mans auto sense.
In timed dry the timer gets power direct from the line (L2 , Timer Switch 0 OR/TM , Timer Motor , Timer contacts BU/BK , L1) so whenever the the timer is not at off it will advance.
In auto mode the timer motor only gets power when the heater is off (L2 , Heater , Timer Switch 0 WB/TM , Timer Motor , Timer contacts BU/BK , L1).
Note that when the heater is on you have L1 power to the left side of the heater in the wiring diagram so the timer motor has L1 voltage on both sides so does not advance.
I am not sure what the problem actually is as you have replaced the parts that would most likely cause this.
You could check the exhaust temperatures on high heat the thermostat should regulate the heat at about 155 degrees F and then shut the heater off. It should come on again at 130 degrees.
When you cleaned it did you clean the blower wheel.
__________________
  #3 (permalink)
Old 10-19-2013, 06:40 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
No, I'll check that today. Am I just looking for lint build up on the wheel??
  #4 (permalink)
Old 10-20-2013, 02:42 AM
Senior Expert
APP Volunteer
Default
Yes
This may be a difficult problem to diagnose.
The heater seems to be shutting off more than it should so the timer advances too quickly in auto modes.
Is the problem the same in both high and low heat settings?
If yes then perhaps the thermostat's internal heater is on all the time.
Are the clothes just damp when taken out of the washer.
I have seen where poor drying ended up being a washer problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
location for a auto sensing switch on a whirlpool washer rebman2005 Washer Repair 1 09-11-2011 06:20 PM
auto sensing setting won't shut off chuckkapl Dryer Repair 1 04-22-2010 04:40 AM
auto sensing setting won't shut off chuckkapl Dishwasher Repair 0 04-21-2010 01:45 PM
Auto Sensing Electric Dryer mrhyde25 Dryer Repair 1 09-24-2009 02:33 PM
Auto Moisture Sensing Plus not working mschmero Dryer Repair 2 01-06-2008 11:55 AM
