Hi, I am new to this forum. Hoping someone might be able to help me. I have a brand new Electrolux gas dryer that was hit by lightning and now I have no power. I took the dryer apart and found a black burn spot on the main circuit board, so I ordered a new one....installed it and still no power. Where the burn spot was on the board is at a wiring harness plug that go's from there to a second circuit board on the front cover panel....could this be the problem? I can see no burn marks on this second circuit board. Also was wondering if there is a thermo fuse or some fuse stopping the power. I have power going into the dryer I already checked this. I did not check for continuity at the harness but it looks good....hope someone can help thank you :confused:
