OK...Turn on the dryer, drum spins, glow element turns on, Gas valve opens, then has flame for about 10 seconds...then flame goes out. Found one website that says flame sensor should have continuity at room temperature and it does....Also the thermistor should be around 11.9 K Ohms at room temperature. I'm getting around 11.5K or 12.5K ...It was late last night and I don't quite remember now, I just remember that the reading I got was only about 500 ohms off. Any suggestions where else to look or what else to test ?
