Discuss
LG gas dryer won't heat up
 in
Dryer Repair
Hello all, I have an lg gas dryer that won't heat up. Here's what I know and have done already.first
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG gas dryer won't heat up
  #1 (permalink)
Old 10-02-2013, 11:21 AM
Junior Member
Farmer85 is on a distinguished road
Default LG gas dryer won't heat up
Model Number: DLG5966g   Brand: -other-   Age: 1 - 5 years
Hello all, I have an lg gas dryer that won't heat up. Here's what I know and have done already.first off the dryer starts and runs perfect, only thing is that the cooling lt stays on all the time? Not sure if it did before. It comes on drum spins, igniter lights and it looks like top solenoid is powered up but bottom is not. I replaced the gas solenoid valve ass. And then figured out my fluke was not reading old one out right. So i grabbed another meter. I replaced both control boards thinking that had to be it. Nothing, so i checked all 3 heat limits. 2 on burner shroud and the other in exhaust duct. They showed 9.5k ohms each. The temp rod in exhaust duct shows 1.5 ohms. The other switch, forgot the name, but its a little black box on left side of burner shows 1 ohm. So i believe that all those components are good. Also took the motor centrifugal switch itself apart and contacts are good and i read them out with meter. The centrifugal portion is good with both springs attached and i even oiled it up with light oil thinking maybe it was stuck. Also checked belt off limit and it's good. Door switch is good. And finally vent is not clogged at all. What now? Dynomite?
Related Models
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
General Electric DLL3280SBLWH Gas dryer
General Electric DLL3480SBLAD Gas dryer
General Electric DLL3480SBLWH Gas dryer
General Electric DLL3680SBLAD Gas dryer
General Electric DLL3680SBLWH Gas dryer
General Electric DLL3680SBLWW Gas dryer
General Electric DLL3880SBLAD Gas dryer
General Electric DLL3880SBLWH Gas dryer
General Electric DLL3880SBLWW Gas dryer
General Electric DLL3980SAM Gas dryer
General Electric DLL3980SBM Gas dryer
General Electric DLL6850AAL Electric dryer
General Electric DLL6850ABL Electric dryer
General Electric DLL6850BAL Gas dryer
General Electric DLL6850BBL Gas dryer
General Electric DLL6850BCL Gas dryer
General Electric DLL6850BDL Gas dryer
General Electric DLL6850BEL Gas dryer
General Electric DLL6850BFL Gas dryer
General Electric DLL6850BGL Gas dryer
General Electric DLL6850TA Electric dryer
General Electric DLL7596ABL Electric dryer
General Electric DLLLR23EG0WW ELECTRIC DRYER
General Electric DLLLR23EG1WW ELECTRIC DRYER
General Electric DLLLR23EG2WW ELECTRIC DRYER
General Electric DLLLR23EG3WW ELECTRIC DRYER
General Electric DLLLR23EG4WW ELECTRIC DRYER
General Electric DLLLR23EG5WW ELECTRIC DRYER
General Electric DLLLR23EG6WW ELECTRIC DRYER
General Electric DLLLR23GG0WW GAS DRYER
General Electric DLLLR23GG1WW GAS DRYER
General Electric DLLLR23GG2WW GAS DRYER
General Electric DLLLR23GG3WW GAS DRYER
General Electric DLLLR23GG4WW GAS DRYER
General Electric DLLLR23GG5WW GAS DRYER
General Electric DLLLR23GG6WW GAS DRYER
General Electric DLLLR23GG7WW GAS DRYER
General Electric DLLLR33EJ0WW ELECTRIC DRYER
General Electric DLLLR33EJ1WW ELECTRIC DRYER
General Electric DLLLR33GJ0WW GAS DRYER
General Electric DLLLR33GJ1WW GAS DRYER
General Electric DLLLR33GJ2WW GAS DRYER
General Electric DLLLR33GJ3WW GAS DRYER
General Electric DLLR113ET0WB Electric dryer
General Electric DLLR113ET1WB Electric dryer
General Electric DLLSR33EF0WC Electric dryer
General Electric DLLSR33EF1WC ELECTRIC DRYER
  #2 (permalink)
Old 10-02-2013, 12:33 PM
Junior Member
Default
The flame sensor is what I couldn't think of that shows it's good. Sorry, I'm not a dryer repairman obviously.
  #3 (permalink)
Old 10-02-2013, 06:54 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
It's an LG that's your first problem lol....There's sales pitch is "LIFES GOOD" when they sell things....can i ask you a question after you've torn that unit apart and are staring at it right now in the back of your head are you thinking "Lifes good thanks LG"? lol.......Here's some video's to help you out.
lg gas dryer not heating - YouTube
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 01:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 03:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 10:33 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 05:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 10:44 AM
