Discuss
220 plug sparked when unplugged
 in
Dryer Repair
My (electric) dryer quit heating up-when I went to unplug the 220 (I had to jiggle it to get it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » 220 plug sparked when unplugged
  #1 (permalink)
Old 09-29-2013, 02:12 PM
Junior Member
fstop61 is on a distinguished road
Default 220 plug sparked when unplugged
Brand: Whirlpool   Age: 5 - 10 years
My (electric) dryer quit heating up-when I went to unplug the 220 (I had to jiggle it to get it loose) it started to spark-there is a little burnt spot on one of the prongs-is this cord still usable?
Thanks!
  #2 (permalink)
Old 09-29-2013, 03:27 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Ohm all the wires out and make sure you have no visible signs of burn marks or cracks in the wires. Then check receptacle and make sure your connections are good and that there's no burn marks or damage to the receptacle wires inside. Also make sure you have a ground if you don't have a ground those sparks could of been your life if it didn't go back to the panel while touching the machine.
  #3 (permalink)
Old 10-02-2013, 12:55 PM
Junior Member
Farmer85 is on a distinguished road
Default
Are you sure the dryer wasn't still on? Even if not running if something inside dryer was on, the elements for instance and there was a load on that ckt, then it will arc every time you unplug it. And it will absolutely put a burn mark on the prongs. It's because the current is still trying to jump as your unplugging to get to where its trying to go. For sure check your ground. Simplest way is to take a voltmeter and check it from the center ground hole to each of the outside pin holes. If you show 120 +\- volts on each technically your good to go.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer sparked near cord hookup KWas Dryer Repair 1 02-13-2013 01:50 PM
Replaced door lock,and sparked wires nate dog Washer Repair 2 11-09-2011 08:41 AM
Whirlpool oven just crackled, sparked and burned out ! Matt N. Oven Repair (including Ranges and Cooktops) 0 08-06-2011 05:22 PM
Plug Sparked when plugged in! baysedge1121 Oven Repair (including Ranges and Cooktops) 1 02-10-2011 09:07 AM
Whirlpool stove sparked and stopped working??? estiefaye1 Oven Repair (including Ranges and Cooktops) 0 08-07-2009 03:02 PM
