Discuss
Wire connecting heating element and high limit thermostat burned
 in
Dryer Repair
My dryer has stopped heating. Removing the back panel revealed that the wire connecting heating element and high limit thermostat
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Wire connecting heating element and high limit thermostat burned
  #1 (permalink)
Old 09-27-2013, 03:55 PM
Junior Member
stubarnes4prez is on a distinguished road
Default Wire connecting heating element and high limit thermostat burned
Model Number: ler8857eq1   Brand: Whirlpool   Age: 5 - 10 years
My dryer has stopped heating. Removing the back panel revealed that the wire connecting heating element and high limit thermostat burned through completely through at the heating element terminal and almost through at the high limit thermostat terminal. I checked both parts with a multimeter and they both showed continuity so I'm not quite sure which is the culprit. Are there any other parts I should check? Should I just replace both parts?
For reference, I replaced high limit thermostat and the thermal fuse around a year and half ago and the dryer had been working well up until this point.
Thanks in advance for any advice and suggestions!
Related Models
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
Whirlpool LET7646EQ2 ELECTRIC DRYER
Whirlpool LET7646EZ0 ELECTRIC DRYER
Whirlpool LET7646EZ1 DRYERS
Whirlpool LET7646EZ2 ELECTRIC DRYER
Whirlpool LET7848AQ0 Residential Dryer
Whirlpool LET7848AQ1 ELECTRIC DRYER
Whirlpool LET7848AQ2 ELECTRIC DRYER
Whirlpool LET7848AW0 Residential Dryer
Whirlpool LET7848AZ1 ELECTRIC DRYER
Whirlpool LET7848AZ2 ELECTRIC DRYER
Whirlpool LET7848DQ0 ELECTRIC DRYER
Whirlpool LET7848DQ1 ELECTRIC DRYER
Whirlpool LET7848DZ0 ELECTRIC DRYER
Whirlpool LET7848DZ1 ELECTRIC DRYER
Whirlpool LET8858AN1 ELECTRIC DRYER
Whirlpool LET8858AN2 ELECTRIC DRYER
Whirlpool LET8858AQ0 ELECTRIC DRYER
Whirlpool LET8858AQ1 ELECTRIC DRYER
Whirlpool LET8858AQ2 ELECTRIC DRYER
Whirlpool LET8858AW0 Residential Dryer
Whirlpool LET8858AW1 ELECTRIC DRYER
Whirlpool LET8858AW2 ELECTRIC DRYER
Whirlpool LET8858AZ0 ELECTRIC DRYER
Whirlpool LET8858AZ1 ELECTRIC DRYER
Whirlpool LET8858AZ2 ELECTRIC DRYER
Whirlpool LET8858DQ0 ELECTRIC DRYER
Whirlpool LET8858DQ1 ELECTRIC DRYER
Whirlpool LET8858DZ0 ELECTRIC DRYER
Whirlpool LET8858DZ1 ELECTRIC DRYER
Amana LEU108 RANGE- S/C S/I DDRAFT GAS
Whirlpool LEV4434AW0 Residential Dryer
Whirlpool LEV4436AW0 Residential Dryer
Whirlpool LEV4624BG0 ELECTRIC DRYER
Whirlpool LEV4624BN0 ELECTRIC DRYER
Whirlpool LEV4624BW0 ELECTRIC DRYER
Whirlpool LEV4634JQ0 ELECTRIC DRYER
Whirlpool LEV4634JQ1 RESIDENTIAL DRYER
Whirlpool LEV4634JQ2 29" ELECTRIC DRYER
Whirlpool LEV4634JT0 ELECTRIC DRYER
Whirlpool LEV4634JT1 RESIDENTIAL DRYER
Whirlpool LEV4634PQ0 29" ELECTRIC DRYER
Whirlpool LEV4634PQ1 29" ELECTRIC DRYER
Whirlpool LEV5634AG1 ELECTRIC DRYER
Whirlpool LEV5634AN1 ELECTRIC DRYER
Whirlpool LEV5634AW0 Residential Dryer
  #2 (permalink)
Old 09-27-2013, 07:39 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
if they just burned you have a problem things don't burn in a dryer for no reason. Is it gas or electric?
  #3 (permalink)
Old 09-28-2013, 06:29 AM
Junior Member
Default
It's an electric.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned wire - heating element issues MJQUEST1 Dryer Repair 2 06-04-2012 10:23 PM
Wire connection to high limit thermostat ctweedy Dryer Repair 1 05-08-2012 02:31 AM
Heating Element Wire Burned Off KenPaul Dishwasher Repair 2 05-24-2011 03:29 PM
Replacing heating element, thermal cutoff and high limit thermostat courtney Dryer Repair 0 08-30-2010 11:41 AM
Connecting hi-limit thermostat to new heating coil daleser Dryer Repair 0 09-16-2009 08:57 AM
