Discuss
dryer will not stay running, shuts off every 15 mins.
 in
Dryer Repair
I have a crosley dryer. The dryers runs for 15 mins and shuts off. it is not the timer, Heating
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer will not stay running, shuts off every 15 mins.
  #1 (permalink)
Old 09-24-2013, 11:11 AM
Junior Member
kamt2012 is on a distinguished road
Default dryer will not stay running, shuts off every 15 mins.
Model Number: CDE20T7W   Brand: Crosley   Age: 5 - 10 years
I have a crosley dryer. The dryers runs for 15 mins and shuts off. it is not the timer, Heating elements. when it stays on it does dry the clothes. It heats up, if I set it for 15 it shuts off and buzzes. The clothes are drying if I reset it every 15 mins.
Related Models
Crosley CDE20T7W DRYER- ELE
Crosley CDE20T7WC DRYER- ELE
Crosley CDE20T8A DRYER- ELE
Crosley CDE20T8V DRYER- ELE
Crosley CDE20T8VC DRYER- ELE
Crosley CDE20T8W DRYER- ELE
Crosley CDE22B6M DRYER- ELE
Crosley CDE22B6MC DRYER- ELE
Crosley CDE22B6V DRYER- ELE
Crosley CDE22B6VC DRYER- ELE
Crosley CDE22B7M DRYER- ELE
Crosley CDE22B7V DRYER- ELE
Crosley CDE22B7VC DRYER- ELE
Crosley CDE22B8M DRYER- ELE
Crosley CDE22B8V DRYER- ELE
Crosley CDE22B8VC DRYER- ELE
Crosley CDE25P6A DRYER- ELE
Crosley CDE25P6W DRYER- ELE
Crosley CDE26P6AK DRYER- ELE
Crosley CDE26P6WK DRYER- ELE
Crosley CDE4000FW0 CROSLEY/DRYER
Crosley CDE4205AYJ DRYER- ELE
Crosley CDE4205AYW DRYER- ELE
Crosley CDE4205AZJ DRYER- ELE
Crosley CDE4205AZW DRYER- ELE
Crosley CDE5000FW0 CROSLEY/DRYER
Crosley CDE6000A DRYER- ELE
Crosley CDE6000AZW DRYER- ELE
Crosley CDE6000Q DRYER- ELE
Crosley CDE6000W DRYER- ELE
Crosley CDE6500AZW DRYER- ELE
Crosley CDE6500Q DRYER- ELE
Crosley CDE6500W DRYER- ELE
Crosley CDE6505AZW DRYER- ELE
Crosley CDE6505W DRYER- ELE
Crosley CDE7000W DRYER- ELE
Crosley CDE7500AZW DRYER- ELE
Crosley CDE7500Q DRYER- ELE
Crosley CDE7500W DRYER- ELE
Crosley CDE8000A DRYER- ELE
Crosley CDE8000AZW DRYER- ELE
Crosley CDE8000W DRYER- ELE
Maytag CDE820 RANGE- S/C F/S ELE
Maytag CDE8300ACB RANGE- S/C F/S ELE
Maytag CDE8300ADB RANGE- S/C F/S ELE
Maytag CDE850 RANGE- S/C F/S DDRAFT ELE
Crosley CDE8500AZW DRYER- ELE
Crosley CDE8500W DRYER- ELE
Maytag CDE851 RANGE- S/C F/S DDRAFT ELE
Maytag CDE852 RANGE- S/C F/S DDRAFT ELE
Maytag CDE8520ACB RANGE- S/C F/S DDRAFT ELE
Crosley CDE8630 DRYER- ELE
Crosley CDE8630A DRYER- ELE
Crosley CDE8630H DRYER- ELE
Crosley CDE9500AZW DRYER- ELE
Crosley CDE9500W DRYER- ELE
Crosley CDE9505AZW DRYER- ELE
Crosley CDE9505W DRYER- ELE
Menu Master CDEC14E2 AMANA COMMERCIAL MICROWAVES (COMMERCIAL MICROWAVES)
Menu Master CDEC18E2 AMANA COM MICROWAVES - EXPORT (COMMERCIAL MICROWAVES)
Crosley CDEC400FW0 CROSLEY/DRYER
Crosley CDG2000FW0 CROSLEY/DRYER
Crosley CDG20C7 DRYER- GAS
Crosley CDG20C7A DRYER- GAS
Crosley CDG20C7H DRYER- GAS
Crosley CDG20M6 DRYER- GAS
Crosley CDG20M6A DRYER- GAS
Crosley CDG20M6H DRYER- GAS
Crosley CDG20M8 DRYER- GAS
Crosley CDG20M8A DRYER- GAS
Crosley CDG20P6A DRYER- GAS
Crosley CDG20P6AC DRYER- GAS
Crosley CDG20P6HC DRYER- GAS
Crosley CDG20P6W DRYER- GAS
Crosley CDG20P6WC DRYER- GAS
Crosley CDG20P7A DRYER- GAS
Crosley CDG20P7AC DRYER- GAS
Crosley CDG20P7W DRYER- GAS
Crosley CDG20P7WC DRYER- GAS
Crosley CDG20P8A DRYER- GAS
Crosley CDG20P8AC DRYER- GAS
Crosley CDG20P8D DRYER- GAS
Crosley CDG20P8DC DRYER- GAS
Crosley CDG20P8HC DRYER- GAS
Crosley CDG20P8W DRYER- GAS
Crosley CDG20P8WC DRYER- GAS
Crosley CDG20R7A DRYER- GAS
Crosley CDG20R7AC DRYER- GAS
Crosley CDG20R7H DRYER- GAS
Crosley CDG20R7W DRYER- GAS
Crosley CDG20R7WC DRYER- GAS
Crosley CDG20T6A DRYER- GAS
Crosley CDG20T6W DRYER- GAS
Crosley CDG20T7A DRYER- GAS
Crosley CDG20T7W DRYER- GAS
Crosley CDG20T8A DRYER- GAS
Crosley CDG20T8V DRYER- GAS
Crosley CDG20T8W DRYER- GAS
Crosley CDG22B6M DRYER- GAS
Crosley CDG22B6V DRYER- GAS
Crosley CDG22B7M DRYER- GAS
Crosley CDG22B7V DRYER- GAS
Crosley CDG22B8M DRYER- GAS
Crosley CDG22B8V DRYER- GAS
Crosley CDG4000FW0 CROSLEY/DRYER
Crosley CDG4205AWJ DRYER- GAS
Crosley CDG4205AWW DRYER- GAS
Crosley CDG5000FW0 CROSLEY/DRYER
Crosley CDG6000A DRYER- GAS
Crosley CDG6000Q DRYER- GAS
Crosley CDG6000W DRYER- GAS
Crosley CDG6500Q DRYER- GAS
Crosley CDG6500W DRYER- GAS
Crosley CDG6505W DRYER- GAS
Crosley CDG7000W DRYER- GAS
Crosley CDG7500Q DRYER- GAS
Crosley CDG7500W DRYER- GAS
Crosley CDG8000A DRYER- GAS
Crosley CDG8000W DRYER- GAS
Crosley CDG8500W DRYER- GAS
  #2 (permalink)
Old 09-25-2013, 07:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Crosley CDE20T7W Dryer - AppliancePartsPros.com
Sorry but I do not understand your post, could you please expain the problem differently.
Is it shutting off because the timer advances to Off?
Does the trimer advance or does it stay at the same position?
How do you know?
Did you replace these parts?
Is this in timed dry?
Does it run the 15 minutes, timer gets to Off and then it shuts down?
OR
It shuts down right away if the timer is at this setting?
Can the unit be restarted as soon as it shuts off or do you have to wait several minutes before it will restart?
What do you have to do to get it to restart?
Is it just a matter of pushing the start button?
__________________
  #3 (permalink)
Old 09-25-2013, 08:02 PM
Junior Member
Default
If I set the dry to 60 mins. it runs for 15 mins and shuts off. No It doesn't shut off at Off, at that point and yes. I just push the button and it con't to dry. If I set it to 15mins, it goes the 15 and shuts off at off. When I view the heating element it is red hot. and the senor was replaced.
  #4 (permalink)
Old 09-26-2013, 06:44 AM
Senior Expert
APP Volunteer
Default
I am stumped on this one.
The timer gets power through different circuit paths when in timed dry and auto modes.
Timed Dry is Neutral through the M/TM timer contacts, the timer motor and then L/M contacts to power.
Auto is L2 , centrifugal switch , heater coil , resistor , A/TM timer contacts , timer motor , M/L contacts to L1 power. Note that the timer advances when the heater is off.
I cannot see anything in the circuit that would cause it to shut off other than the timer. At least anything that would consistently shut off after 15 minutes.
A common cause of a unit shutting down is the motor overheating and tripping it's internal breaker. You then have to wait for the motor to cool down and the breaker to reset before you can restart the unit.
But you said that it restarts right away so it cannot be the motor.
Another common problem can be if the door is not closing properly. Then when clothes hit the door it opens a little and opens the door switch shutting the unit off but again this would not be consistently 15 minutes.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dryer Shuts off within 5 mins! haloboyvash Dryer Repair 5 08-02-2011 08:47 AM
shuts off in 2 mins Glojefink Dryer Repair 0 07-06-2010 07:32 PM
Dryer runs, heats, then shuts off 15 mins mafia007 Dryer Repair 0 06-23-2010 06:43 PM
gas dryer fires up but gas shuts off after 4 mins. geno630 Dryer Repair 5 06-23-2009 06:05 AM
dryer runs for few mins then shuts down MJM Dishwasher Repair 7 07-30-2008 10:16 PM
