Dan71
#1 Posted : Sunday, October 11, 2009 9:03:15 AM(UTC)
Dan71
The timer on our maytag electric dryer will not advance no matter which setting it is on. Cleaned all the duct work, still not working. Replaced the start switch, timer and buzzer since it quit working also and the new timer still does not avdance. Wherever you set it to, it stays there until you manually turn it off. What am I overlooking or what else needs replaced to solve this issue? Thanks for any help.
sidfink43
#2 Posted : Tuesday, October 13, 2009 3:10:03 PM(UTC)
sidfink43
Well I am as mystified as you must be. If the machine operates and the timer does not advance in any cycle, including no heat I can only conclude that either your replacement timer is also bad or that there is a problem in the wiring to the timer.
Dan71
#3 Posted : Tuesday, October 13, 2009 5:59:17 PM(UTC)
Dan71
Finally found the reply from sidfink43. My wife used the dryer today and it worked great on timed dry cycle. Plenty of heat and everything worked as it should. It always heats great and gets clothes dry the timer just decides not to work. Should I go ahead and replace both thermostats? What do you think? Thanks alot for your input.
sidfink43
#4 Posted : Tuesday, October 13, 2009 6:01:24 PM(UTC)
sidfink43
Gosh, check again, here it is and the reply is there.
http://forum.appliancepartspros...timer-not-advancing.html
Electric dryer, timer not advancing in auto mode (Dryer Repair)
by joet60 1/29/2017 7:20:59 AM(UTC)
Whirlpool Dryer Timer not advancing (Dryer Repair)
by jconkl02 5/9/2016 9:47:22 AM(UTC)
Kenmore washer timer not advancing (Washer Repair)
by sherlockbill 9/7/2015 9:37:23 PM(UTC)
by mjlj 7/6/2015 8:18:13 AM(UTC)
No heat, timer not advancing on autosense (Dryer Repair)
by fgaggia 9/5/2014 12:48:30 PM(UTC)
Maytag MDE7658BYW Timer not advancing/dryer will not shut off (Dryer Repair)
by countrybois 6/13/2014 10:47:30 AM(UTC)
Frigidare stackable timer not advancing (Washer Repair)
by aford89 3/12/2014 8:06:17 AM(UTC)
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
timer not advancing and no heat (Dryer Repair)
by elymoe 1/12/2014 8:44:11 AM(UTC)
Timer not advancing, but the timer is good. (Dryer Repair)
by skylux 12/17/2013 12:42:42 AM(UTC)
Roper dryer not heating and timer not advancing (Dryer Repair)
by kennethgore 12/2/2013 7:09:15 AM(UTC)
Timer not advancing (Washer Repair)
by andyvh1959 4/17/2013 7:33:49 PM(UTC)
Roper Dryer Auto timer not advancing (Dryer Repair)
by Cheryl_A 9/14/2012 7:50:11 AM(UTC)
by Ehoff 8/30/2012 11:15:28 AM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
