handylady59
#1 Posted : Sunday, September 22, 2013 6:08:24 AM(UTC)
handylady59
Dryer was working fine, then when we put in the next load, it won't start, this is a GE dryer when you push the on button it makes a sounds like the it wants start but doesn't I already tried by replacing the Rotary start switch but that didn't work:mad: ...any suggestions??:confused:
#2 Posted : Monday, September 23, 2013 2:02:36 AM(UTC)
Parts for GE DBL333EB1WW Dryer - AppliancePartsPros.com
When you say "it makes a sounds like the it wants start", do you mean that the motor hums/buzzes?
If yes.
Try turning the drum in the correct direction.
It should turn fairly easily. You may want to try this on a couple other units to get a feel for it.
Could be the drum is jammed/seized for some reason.
If OK
Open the door and hold the door switch closed.
Hit the start switch and at the same time try rotating the drum in the correct direction.
If it starts up then you have a motor problem.
This may take two people.
Do not let it run very long as running it with the door open can blow thermal fuses.
The motor problem could be a bad motor, this is the most likely.
Could be that the motor is clogged solid with lint and the motors centrifugal switch is stuck in the running position. This disconnects the start winding so the not will not run.
FYI: If the hum is just the timer motor running then it may be as simple as a broken belt. This unit has a belt switch which kills power to the motor if the belt breaks.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
