Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Maytag Performa dryer not running (http://forum.appliancepartspros.com/dryer-repair/535611-maytag-performa-dryer-not-running.html)
bluex 09-19-2013 01:11 PM
Hello
Today while doing a load of laundry the dryer quit. The wife says it smelled like something was burning and the clothes do have an electrical burnt smell to them.
I currently have the dryer torn completely apart tying to locate why it wont run. The first thing I checked is the door switch, it works as normal. I then checked the timer and it seems to be working as needed as well. Using the diagram in the timer housing I have followed the circuits (I'm an industrial maintenance technician) and it appears I have power everywhere where needed but the motor wont run and therefore the heaters don't turn on either. I finally located the thermal fuse and it checks good as well. The heater element ohms out to about 11.5-11.6 ohms which also should be good from what I've read.
When I test the motor plug I'm getting 120v on the purple wire when the start button is pushed and also 120v on the orange when its released. If I was at work I'd change the motor, but since I have to buy one at $140ish I wanted another opinion before spending the money. Is there anything else I should check before buying a motor? It spins freely (which I know doesn't mean much) and ohms at 1.7 ohms between the windings.
Thanks,
Paul
Maytag PYET344AYW
denman 09-20-2013 02:00 AM
When measuring the voltage across the motor, where is the reference lead of the meter?
If it is on the white wire at the motor connector then I would say that the motor is toast.
bluex 09-26-2013 03:12 PM
That was my error, I was measuring voltage to ground not neutral.
I removed the thermal fuse and checked it again and it was bad. I guess trying to get my hands and the meter leads down in there it was touching them together. I just finished putting a new thermal fuse, thermostat and heater assembly in and it works great now. I also cleaned the lint out of the dryer and all my piping to the outside of the house. I was actually shocked by how much was clogged up in there. No doubt that was what caused it to overheat.
Thanks for the help.
